Dr.AK
Club RR Member Number: 62
Looks a million times better with the stock springs! I do think it could use being a little lower, but you said you're going to swap in RS springs, so that should be sorted eventually. May I ask what kind of money one would need to cough up for an Escort that's clean like this? I do find myself with an awful lot of space in my workshop now that the Ram is gone
ZXRob
Jun 28, 2019 14:47:43 GMT
Looks a million times better with the stock springs! I do think it could use being a little lower, but you said you're going to swap in RS springs, so that should be sorted eventually. May I ask what kind of money one would need to cough up for an Escort that's clean like this? I do find myself with an awful lot of space in my workshop now that the Ram is gone I paid 1300 for this which I didn't think was too bad. I couldn't tell you if that is above or below the normal rate. Did you end up buying a 944 in the end?
Dr.AK
Jun 28, 2019 20:39:44 GMT
Looks a million times better with the stock springs! I do think it could use being a little lower, but you said you're going to swap in RS springs, so that should be sorted eventually. May I ask what kind of money one would need to cough up for an Escort that's clean like this? I do find myself with an awful lot of space in my workshop now that the Ram is gone I paid 1300 for this which I didn't think was too bad. I couldn't tell you if that is above or below the normal rate. Did you end up buying a 944 in the end? That sounds like quite a steal! And yup, I found one! forum.retro-rides.org/thread/209858/1987-porsche-944s
ZXRob
Very nice.
And these non brand specific meets are so much nicer imho.
Nice T-shirt ✅
Traction Avant and others together, yup, I would be happy there.
ZXRob
. Very nice. And these non brand specific meets are so much nicer imho. Nice T-shirt ✅ Traction Avant and others together, yup, I would be happy there. Yeah I think that too. There is always loads of variety there. T shirt was bought on Saturday evening at a Descendents show. Been a fan for 20 years and Saturday was the first chance I got to see them live.
Dr.AK
Ohh, is that the one in Burscheid? A think a friend's grandfather visits there occasionally.
Escort looks so good in the pictures, it's understandable why People would come check it out! It's been forever since I've last seen one in the wild (admittedly, I did see a super clean RS one pull in at Classic Remise last week, but I think it's been easily 5 or more years since I've last seen a low spec Mk3 escort in good nick).
Also, that 911. Can you say coke dealer? <3
ZXRob
Ohh, is that the one in Burscheid? A think a friend's grandfather visits there occasionally. Escort looks so good in the pictures, it's understandable why People would come check it out! It's been forever since I've last seen one in the wild (admittedly, I did see a super clean RS one pull in at Classic Remise last week, but I think it's been easily 5 or more years since I've last seen a low spec Mk3 escort in good nick). Also, that 911. Can you say coke dealer? <3 Yeah that's the one. My mate lives in Köln Brück so we get a nice drive past Altenburger Dom. There's not many better things to do on a Sunday morning!
ZXRob
When I get a new car I like to give it a general once over so that I know that it is at a good level and that I can just use it. Being a mechanic by trade helps with this a lot and what is even cooler is that I now have a boss that lets us use the workshop at work on evenings and Saturdays. Yesterday's jobs were new discs and pads on the front, oil and filter, gearbox oil change, adjust the rear brakes, spark plugs wheels balanced and alignment. I started off with the front brakes, I could have left these for a little while but the discs had quite a big lip on them and they are very cheap for me (another perk of the job.) Out with the old. In with the new OE Ford discs and pads, I am not one of those people who has to have OE parts or whatever but I work in a Ford garage so get them cheap! Next up was to adjust the rear brakes. I forgot to take photos of this but it was a really fun job. When I was an apprentice this was part of my daily life. I worked in a private garage in Chorley and on every service the rear brakes would be opened up, checked for leaky cylinders, cleaned up then adjusted and the lip on the drum filed back. That is exactly what I did to the Escort yesterday and I got lots of cool nostalgic feelings and then thought "Rob you are mental, it is a set of drums!) I balanced the wheels and swapped them front to back and whilst cleaning the back of the wheels up to stick weights on I saw that under the bronze paint they are chrome! Maybe I will remove the paint and have chrome wheels again just like on my S-10! After that I quickly changed the engine and gearbox oils and had a first proper look underneath. This car is so unbelievably clean the gearbox was this dry with no oil on it just a bit of dirt! Dropped the ramp down and put the new spark plugs in. This was needed as I think the old spark plugs where around 10 years old. Sadly no pictures again. Now it was time to drive it over to the other ramp for a bit of wheel alignment. This is something of a speciality for me but I will get to that in a minute. The steering wheel on the car wasn't straight when driving and when I tried a bit of accelerator in the corners it seemed to have a bit of a tree magnet built in that wanted to kill me! After checking the alignment it was obvious why, over 1 degree of negative toe on the right wheel! And the left wasn't much better! I set the toe to a bit of positive on the front. Now looking at that picture I know what you are all thinking "Oi Rob! That's still red so it's wrong" in which you wouldn't be totally wrong in saying. But let's get back to that speciality for a second. My first proper job in Germany was working for a company that specializes in all sorts of wheel, tyre and suspension set ups. I worked on many cars ranging from regular run of the mill cars that had vibration problems, steering problems etc. To cars like 911 gt3 cup contenders that would be set up for outright performance. In the four years working there I learned a lot about the importance of a decent set up and I also learned how to calculate settings and did so many that I can now do it in my head. Like everything things move on and the ideas behind setting up suspension in 1984 are different to what I have researched and developed. That is why my set up is different but I can assure you all it is better for both performance and for tyre wear. Ok enough about me let's get back to the car and more importantly the test drive called my journey home. The car drives 10000% better! The brake pedal feel is perfect and the brakes are sharp enough and pull to a stop surprisingly quick. They will obviously get better after a few hundred KMs but they are brilliant and the adjustment of the rear shoes has also a lot to thank for this. The car now no longer wants to go into trees and I can throw it into a corner and it just takes it in its stride. I am no racer and I have 69hp but the difference from before is night and day. With just a couple of hours work I have changed the car from a perfectly good car to an almost perfect car! Next week is timing belt and new radio time. Cheers for reading. Rob
Last Edit: Jul 7, 2019 8:06:14 GMT by ZXRob
ZXRob
Jul 10, 2019 15:20:46 GMT
The other day I posted on here asking for recommendations for a good radio that wouldn't look out of place in my car. Dr.AK delivered the goods with a top recommendation that I subsequently bought! It arrived yesterday so after work I whacked it in and I feel it suits the car perfectly! Next up is the timing belt. Cheers Rob
Last Edit: Jul 10, 2019 15:23:46 GMT by ZXRob
ZXRob
Jul 12, 2019 16:45:24 GMT
Had a bit of an afternoon play with the Escort after work and managed to check out why the horn wasn't working. First put a bit of power to the horn itself to check if it was alright, it was. After that moved over to the horn push on the indicator stalk and after taking it off I saw the wire for the horn was broken where it goes into the horn. I quickly soldered it back on and jobs a good'un.
After that I thought I would have a play with the notoriously temperamental carb. Mine runs smooth and everything but I saw on the spark plugs that I changed last week that it was running pretty lean (the electrodes were very white) Putting on the emissions tester i saw that I was correct! The mixture screw on these are very sensitive so it only requires a small movement for a big result. I turned it literally 1/14th of a turn and that was enough for it to be running better. Driving it home was a pleasure. I enjoy how this car just keeps getting better.
ZXRob
Jul 19, 2019 15:20:12 GMT
Well as of tomorrow I have owned this car a month. So it treated me this morning to running on roughly half a cylinder! Got it in the workshop after work and found rather quickly that the choke cable had got jammed on so it was on full choke! Re routed it to original position cleaned the plugs and it runs again. Ordered a new distributor cap and rotor arm that will arrive on Monday and tomorrow will do the timing belt.
Phil H
Club RR Member Number: 133
Jul 19, 2019 16:24:31 GMT
I assume this is running the VV carb? They get a lot of stick but when working they're fine..
ZXRob
Jul 19, 2019 16:36:09 GMT
I assume this is running the VV carb? They get a lot of stick but when working they're fine.. Yeah it is. It runs great and I have no problem with it so far.
Dr.AK
Jul 21, 2019 21:30:53 GMT
Cool that you ended up going with my recommendation!! I had thought about getting the same for my 944, but I really wanted something able to play tapes so I got a Blaupunkt from '94.
Sucks to hear about the car acting up, but that's old cars for you! Luckily you seem to be a crack at finding and fixing the problems it has!
cjhillman
Jul 22, 2019 10:50:00 GMT
Interesting about the VV carb. i keep thinking of doing a weber update on mine but its tricky to find the right one for a 1.1 it seems. Are you on electronic ignition on this model? mines on points
ZXRob
Jul 22, 2019 11:08:37 GMT
Cool that you ended up going with my recommendation!! I had thought about getting the same for my 944, but I really wanted something able to play tapes so I got a Blaupunkt from '94. Sucks to hear about the car acting up, but that's old cars for you! Luckily you seem to be a crack at finding and fixing the problems it has! I am proper happy with it it's perfect for what I need. Just need to get some tunes on a USB and then I am sorted.
ZXRob
Jul 22, 2019 11:10:21 GMT
Interesting about the VV carb. i keep thinking of doing a weber update on mine but its tricky to find the right one for a 1.1 it seems. Are you on electronic ignition on this model? mines on points Mine has electronic ignition which I am pretty happy about. Getting a new original cap and rotor later. It's cool ordering the parts from Ford as they are no longer produced but there is a system for old parts that are hanging around in the warehouses of various Ford dealers. Could be handy for your fleet!
cjhillman
Jul 22, 2019 11:15:06 GMT
Will remember this ZXRob I tried a couple of Ford garages in manchester for simple things and they couldnt get me anything, they said to me they only stock parts up to 10 years.
ZXRob
Jul 22, 2019 15:36:02 GMT
Will remember this ZXRob I tried a couple of Ford garages in manchester for simple things and they couldnt get me anything, they said to me they only stock parts up to 10 years. There is a separate system called Ford Edix. That's were they can see if any other Ford dealer in the country has the part.
