Nov 14, 2015 23:46:24 GMT
Hi folks. I recently posted here about inheriting a non-starting passat B1 estate in very good condition, and I've finally had it towed from Surrey to my drive in Chester. I though I'd start a small project log here to keep track of where I am, plus for the million questions that are likely coming your way! I have absolutely zero mechanical/car knowledge (I was pretty impressed I managed to change a tyre myself recently), so this is going to be a steep learning curve for me As said, it currently doesn't start as it's been sat unused in a garage for 20 years. Engine needs a good overhaul, brakes and exhaust are shot, gears feel like stirring porridge, while the clutch sticks like jam. On the bright side, the bodywork is in near mint condition for the age so only needs one or two very minor sport rust repairs and a good coat of underseal. Needs a thorough clean inside and out too - these were taken just after I'd dusted off 20 years of grime with a cloth. Now I need to figure out what's what, what I need, and how to start! Cheers for reading. Arsonist
Last Edit: Feb 18, 2018 19:40:19 GMT by arsonist
1979 Mk1 Passat Estate 1.6 LS 1996 Mk3.5 Fiesta 1.3 Classic 1997 Mk1 MX5 1.8i 2005 Mazda 3 TS
I think you've picked the perfect starter project here. It's mechanically simple, it's got an extraordinarily sound-looking shell, and it's a little bit different. Nice find.
Jings, that's an absolute peach.
Does the engine turn over at all ?, get a socket and a bar on the crank pulley and try to turn it by hand.
Check the timing belt is not rotten, if it is it'll need changed before you try and start the engine, an oil change would be a good idea too, just cheap stuff, put better stuff in once it's running ok.
Fuel will be bad after 20 years but you could bypass the fuel system for now with a gravity feed straight to the carb from a can with fresh fuel in it.
Good luck.
Nov 15, 2015 13:49:47 GMT
Jings, that's an absolute peach. Does the engine turn over at all ?, get a socket and a bar on the crank pulley and try to turn it by hand. Check the timing belt is not rotten, if it is it'll need changed before you try and start the engine, an oil change would be a good idea too, just cheap stuff, put better stuff in once it's running ok. Fuel will be bad after 20 years but you could bypass the fuel system for now with a gravity feed straight to the carb from a can with fresh fuel in it. Good luck. Yeah the engine turns over, just doesn't want to start, although the battery has since given up. Picking up a new one on Monday, although I've yet to learn actually how to diagnose what's wrong! I also know the carb isn't getting fuel though (pipes are dry and the fuel filter pipes are super loose and knackered - when we tried turning over the engine we added some fuel to the carb to see if we could just get a splutter). Would I be able to fill a jerry can and bypass everything including the fuel filter then? I live opposite a petrol station which makes things easier! Cheers.
Last Edit: Nov 15, 2015 13:51:22 GMT by arsonist
MK2VR6
Mk2 Golf GTi 90 Spec
Nov 15, 2015 14:51:52 GMT
Yes to the above. Avoid using underseal unless you want rot to set in. Go for Dynax or Waxoil for a decent job. Looks a peach - good luck with it!
stonio
Nov 15, 2015 15:19:15 GMT
Thats effing awesome right there, lve always wanted a B1 and in yellow its a win win lucky you.. Cant wait to watch this further
Nov 15, 2015 16:26:34 GMT
Very cool car. Not really got anything to say that I haven't already said on uk passats. I'm just commenting for updates really. All the best with it
Stu
Nov 15, 2015 16:51:48 GMT
Looks excellent, glad you got it home ok. I've had various old VWs of this era as have plenty of others on here, so just post up any questions and I'm sure you'll get quick responses and it'll be going in no time. The timing belt on that looks a doddle to change, right at the front under the old type metal cover. I had a 1980 Polo like that but transverse engined, belt change took about 10 mins and was well overdue as it was split when I removed the cover! Takes yours off and inspect before firing it up.
is,sit
Nov 15, 2015 18:54:50 GMT
Wow that clean bud whats your plans??
Nov 15, 2015 19:34:13 GMT
Go for Dynax or Waxoil for a decent job. Looks like my great uncle already did a good job with waxoyl - lots of clear/yellowy rubbery paint on the underside, assuming it's this? Can I just add more over the top to double protect (cleaning anywhere that needs it first)? The timing belt on that looks a doddle to change, right at the front under the old type metal cover. I had a 1980 Polo like that but transverse engined, belt change took about 10 mins and was well overdue as it was split when I removed the cover! Takes yours off and inspect before firing it up. The black panel with the Audi/WV logo on it? Thanks Wow that clean bud whats your plans?? Get it fully cleaned/sealed and de-scuffed inside and out, get the engine going, keep it absolutely stock (for the moment) and use it as a dry weekend outing car If I get it to be a reliable runner, it also means I can give my mk3 fiesta some much needed attention from what I hopefully learn! Rust has started to set in and the last MOT had some scary advisories! Wanting to take the fuel tank off to get it decontaminated inside (plus new fuel lines) so hooked up the dead battery to my other car in the hope the fuel gauge would give me an idea of how much was still in there, but no luck so assuming the engine needs to be going. Any way I can find out before I take it off? On a side not, while the battery was hooked up, I thought I'd see if any electrics still worked. Turned the key to position 1 and bing! Dash lights, headlights, fans, radio and windscreen wiper all buzzed into life! The only thing that didn't work was the brake lights - could this have anything to do with the brakes not physically working themselves? Also pulled out a spark plug, fuel filter and a pipe to hopefully replace. Can't seem to find any on-line though, only options coming up are for a 1.5l diesel, not a 1.6 petrol. Hmm...could I just filter my searches by inputting the 1979 Audi 80 1.6 petrol? Things come up for that... Would post pictures but my internet won't even load facebook at the moment...
Carlosfandango.
Now with added Suffix B Range Rover classic - another bucket list car acquired.
Nov 15, 2015 21:36:34 GMT
arsonist that's really lovely. Great colour and an absolute bonus that it's an estate. Really quite a find, lucky you! After you get it running, any plans aesthetically? Are you planning to keep it standard or changing the look at all? Whatever you do, it's a very cool car. CFD
1966 Fiat 1500 fast road/race conversion 1967 Porsche 912 1968 Fiat 124 Spider 1973 Range Rover Suffix B 1993 Series one Discovery 200TDI 1997 Jaguar XJ6 3.2 sport 2001 P38 Range Rover 2.5 TD Brace of Triumph bikes
Nov 15, 2015 21:45:35 GMT
Would I be able to fill a jerry can and bypass everything including the fuel filter then? I live opposite a petrol station which makes things easier! Cheers. Yes, get a mate to hold the Jerry can higher that the carb whith a length of hose to the carb, gravity feed like this will bypass the pump and filter, pretty much guaranteed the whole fuel system will need refurbed but this will let you get the engine running to see if it's sound. Your plans for the car sound great. Good crowd on here to help you out, keep us all updated
Nov 15, 2015 21:54:43 GMT
The only thing that didn't work was the brake lights - could this have anything to do with the brakes not physically working themselves? Could be if it's a pressure switch that activates the lights, the brakes not working will be down to parts seized or a leak in the system, is the pedal going right to the floor ?, is there fluid in the reservoir ? Brake lights work from either a pressure switch in the pipework or a plunger switch at the brake pedal.
Nov 15, 2015 22:12:12 GMT
Carlosfandango. - Aesthetically I'm hoping to keep it standard. Truth be told, I wouldn't really know what to do with it otherwise! markgenesis - Thanks, that makes sense I'll try this once I figure out the ignition system, e.g. sparks and points/distributor? Think that's what I mean! The pedal does go to the floor but with what feels like 'usual' resistance on working breaks. Not sure about the reservoir - what ever is in there will likely be manky! Also, I'm having trouble identifying which engine I've actually got. This website www.ukpassats.co.uk/phpbb/viewtopic.php?f=6&t=13186&p=692648#p692648 shows the 4 potential different types of 1.6 I might have, but how the heck do I work out which one is mine? I've got the engine code 049 103 373 stamped on the block, but can't see any other markings. Ta.
The brake light switch is a pressure type switch - a hex shaped thingy at the master cylinder with two cables attached. If you bridge the contacts, the brake lights should lit up (even without ignition on - Volkswagen special!). I think the master cylinder is shot, it doesn't build up enough pressure to work the switch. Re engine code: German wikipedia says YN for the 75 hp engine and YP for 85 HP.
I think the master cylinder is shot, it doesn't build up enough pressure to work the switch. Don't condem the MC that quickly. Those switches are notoriously wibblepoo, I could stop my mk1 caddy without turning the brake lights on.
mexicansteve
South West
Club RR Member Number: 31
Nov 16, 2015 10:13:35 GMT
As some of the above say really, sweet ride. Nice to see something different amongst the VW fraternity. And stock is good!
sent from the '70's
BeQuietandDrive
1989 Bedford Astra Van
Nov 16, 2015 12:51:05 GMT
What an awesome find! Don't see many around any more and like others have said the shell looks to be very solid!
Like others say, check the timing belt before trying to start the engine, you don't want it slipping or snapping.
I picked up a 1.8 Mk2 Golf GL from a neighbour which had been sat outside untouched for 15 years, even the battery was still connected (and he wondered why it wouldn't turn over?) Getting mine going took some time, after checking the belt was ok for testing purposes (I believe these are non interference engines anyway). We did the following:
1) Checked the oil and coolant levels 2) Checked for a spark, (removed one spark plug, put the plug lead back on, rest it on the block and turn the engine over, looking for a clean bright spark) 3) Primed the carb with petrol (Remove the plastic airbox cover and put a little petrol down the carb throat whilst holding the throttle open) 4) Crank the engine and pray, but don't keep the starter running for more than 15 seconds or so (to avoid heat damage)
Eventually we got the golf fired up, and after dragging fuel through from the tank it would eventually idle on run on its own, albeit very lumpy on 15 year old petrol! The clutch and gearbox should hopefully free up a little with heat/vibration from the engine.
If it will run from priming but not on its own (as in it cuts out once it burns the small amount of fuel you put in the carb) check that fuel is making it from the carb to the tank, and don't try pouring fuel into the carb whilst the engine is running, it may fire out of the carb! (I learnt the hard way many years ago!)
Good luck and let us know how it goes!
1987 Volkswagen Golf GL 1.8 Auto - Zender special 1981 Honda NX50 Caren - Trial by fire 1993 Volkswagen Polo Genesis 1.0 - Daily runner/Project 1998 Saab 900i Convertible - Girlfriends
G4vBr
Nov 16, 2015 15:35:46 GMT
Wow, that is nice! This is like the big brother to my lemon yellow Mk1 Polo which is also on a '79 V plate. I just wish mine was as clean and tidy. I'm really looking forward to your updates on this. p.s, spotted your map on the other thread - i'd maybe delete that as you never know who's watching.
Nov 16, 2015 17:02:20 GMT
The brake light switch is a pressure type switch - a hex shaped thingy at the master cylinder with two cables attached. If you bridge the contacts, the brake lights should lit up (even without ignition on - Volkswagen special!). I think the master cylinder is shot, it doesn't build up enough pressure to work the switch. Re engine code: German wikipedia says YN for the 75 hp engine and YP for 85 HP. Thanks for this. Popped home at lunch and had a good look in daylight - finally found a small marking with YN etched in. Shame, was hoping for 85bhp but 75 will have to do! At least I know what I've got now. Heading to Halfords/BnQ tonight to get myself an external halogen light so I can finally do some work; always pitch black when I get home! First call of action tonight: Check the timing belt, check the sparks are firing , check the distributor and work out what ignition points are! Also gonna have a crack at hand cranking to check seizure once I've established the condition of the timing belt. Ta people!!
