Nov 22, 2015 20:22:17 GMT
Awesome,nearly there then ! Warm the plugs on the radiators in the house for half an hour before you try again,that and a blast of eezi start and i bet she'll go. You might have a blocked jet but one thing at a time !
I once spent a day getting an old Escort to run that had been stood a similar length of time.Strong spark but not even a splutter,Eezi start and it went second attempt.
Nov 23, 2015 21:56:52 GMT
Awesome,nearly there then ! Warm the plugs on the radiators in the house for half an hour before you try again,that and a blast of eezi start and i bet she'll go. You might have a blocked jet but one thing at a time ! I once spent a day getting an old Escort to run that had been stood a similar length of time.Strong spark but not even a splutter,Eezi start and it went second attempt. It stopped raining tonight for long enough for me to have another play about under the bonnet. I checked every individual spark plug again with it's corresponding HT lead and all was fine - except one. Tested another spark plug on it and nothing. Ran a volt test through it with a multimeter; it's gone the way of the dodos. This is sort of good as it helps narrow one more thing down! I'm gonna bite the bullet and buy a new set. Gulp at 40+ pounds for some tiny wires though! Will keep the 'still working' ones as spares. Could the above, i.e. a single spark not firing, be the cause of a no-start? I tried with Easy Start too while bumped up to my running fiesta. I also managed to find TDC on my crank pulley - was a nightmare as it was fully crusted over and had to clean almost the whole thing in an awkward position. I also noticed there is a mark on my dizzy which I thought, when the crank pulley is TDC, the rotor arm on the dizzy pointed to it's own mark? I almost looked like it was 180 degrees out but couldn't say exactly, was just pointing nowhere near the mark for sure! Dare I say it - is this because of the rotation ratio, i.e. crank pulley rotates fully 2 times for everyone distributor rotor arm? Hence I should hand crank the pulley 1 full rotation to get the to line up? This is very confusing for someone who can't even change a tyre! Very interesting though! Thanks
1979 Mk1 Passat Estate 1.6 LS 1996 Mk3.5 Fiesta 1.3 Classic 1997 Mk1 MX5 1.8i 2005 Mazda 3 TS
mad
Nov 23, 2015 22:28:12 GMT
The crank will rotate twice for every single turn of the distributed. So you need to have the engine at Tdc and on the firing stroke of number 1 piston. Although if the car was just parked up and left chances are the timing is fine. It's just putting up a fight to get started.
Nov 23, 2015 22:33:43 GMT
As the 4 stroke engine fires each cylinder every other stroke the distributor as you say runs at half crank speed, therefore at the crank tdc point the distributor can be firing on either cylinder 1 or 4, on a 4 cyl engine, you need to look at the distributor cap and see which lead the rotor arm is pointing to, if you think you have mixed them up then you need to remove the cam cover and check on which cylinder the valves are both closed.
Nov 23, 2015 22:36:02 GMT
Yeah when it hasn't run for 20 years you want everything right,it's asking a lot for it to fire on three cylinders with old leads. New leads will hopefully give you a fatter spark too,there is bound to be resistance and some breakdown in insulation on the old ones.
It was running when it was laid up so i doubt anyones moved the dizzy about,fix one bit a time otherewise you can lose your way if you pull apart too much at once.
Steep learning curve,but your'e doing ok !
Ok great responses thanks. So just to clarify. It doesn't matter if I turn the crank clockwise or anti-clockwise; the rotor arm will only ever turn one way? Is so I should easily be able to sort this particular problem out. Obviously I aligned position 1 on the dizzy cap with piston 1, then the second with 3 etc (firing seq is 1-3-4-2), but this will be doing a fat load of good if it's all 180 degrees out plus a dodgy ht lead. Ordered some new Bosch leads tonight. Will check, again, tomorrow for the TDC on crank and dizzy. Thanks for keeping with this thread! Annoying I know! Also, this is my workspace...
I've got serious brain fade tonight so probably a less than useful post but Kevins right the rotor arm could be lining up with 1 or 4 at TDC and at 4 it would be 180 out. You could check the valves as mentioned to confirm.If you have it with 4 as 1 it just won't start but easy to try the other way round,theres only two possible options.
Nov 24, 2015 10:15:37 GMT
What the buggering heck? So I ordered some ht leads last night from onlinecarparts.co.uk. Got an email this morning asking me to ring them and confirm my order. Baring in mind all this information went into their online system, they wanted my billing address, delivery address, delivery contact, WORK address, card details again, and a copy of either my driving licence or passport. What the hell?
This sounds suspicious as hell, told the clearly Asian woman on the phone I didn't have some of the info so would call back. Tempted to cancel the order, shouldn't have to go through the Spanish inquisition to buy some flipping car parts!
Nov 24, 2015 13:00:34 GMT
Don't like the sound of that at all,sounds more like an ID theft scam. Never used them but some mixed reviews online,it seems those who got parts found them sent from Germany and it took a while. Also this review copied and pasted over:
ā
āāāā WRITE A REVIEW
Written on: 26/09/2014 by Anazar (1 review written)
I bought some car parts from this site and instead of getting confirmation, received this email:
"Dear Customer,
Could you please send us the total amount that you paid with the credit card when placing the order on our website? Also please send us a copy of your credit curd and Id, one side only (wee need just first and last 4 digits and the name on the card). We need it in order to check the payment! This is a security measure in order to prevent credit card fraud! We have received your funds, however we require this information to make sure that you are the card holder as we have had complaints from people who had their cards stolen. Sorry for the inconvenience!
Kind regards"
My bank confirmed that this is fraud and they blocked this transaction, so they did not get my money as they claim above. There are a couple of sites almost exact copy of onlinecarparts.co.uk which look like uk sites but based in Germany. They will ask for your bank, card details, calling you from Germany and london.
Nov 24, 2015 14:52:56 GMT
Order cancelled (hopefully) and bank informed. Luckily my credit card is due payment so there's almost nothing on it if some suspicious activity is attempted in the next few days. Bank should notice now too. Ordered some more HT leads from rexbo who have been good before.
Thanks!
Nov 24, 2015 19:39:03 GMT
Ok. So I've confirmed the engine cranks over clockwise. I've lighned up the crank pulley to TDC as this photo shows. However, the rotor in the distributor is a good 40 degrees away from it's own TDC mark, which you can see here. The mark is the small horizontal dark mark at about 9 oclock on the outer rim. Clearly something has gone wrong here but I've no idea how or why. This also means that when the dizzy cap is on and the crank is at TDC, the rotor arm is directly BETWEEN two contact points, and not starting above point 1, as can be seen here. The rotor arm is pointing at about 6 oclock, while the two nearest contact points on the cap are at 4 and 7 oclock respectively. I'm guessing this is all likely to cause me serious issues with starting the engine...
jpsmit
Nov 24, 2015 19:45:28 GMT
No it won't - first of all the marks line up twice in every spark cycle so, depending on whether the spot you have it now is the point in the cycle where the spark happens, the dizzy could be 180 degrees away. More to the point, engines almost never spark at TDC usually 10 or more degrees before so that the spark is well and truly lit by the time the piston completes its compression stroke. So, the distrubuter is almost certainly correct. In fact, distributers almost never "fall out" of alignment. I would suggest you not adjust it a all, get the new leads, install them properly, get fresh gas and properly gapped plugs, a new battery and I suspect it will start.
Nov 25, 2015 13:56:25 GMT
Thanks.
I've already tried the dizzy at 180 degrees from the pictures above (a full turn of the crank) and still no luck. Assumed this was more likely the TDC as the rotor arm was closer to it's mark. It looks like the original distributor as it's got the old style vacuum unit on, so I can't imagine it's ever been taken out and accidentally put back in wrong. Guess a timing belt was changed at some point and true TDC wasn't found before installing?
Will just have to wait for the new leads to test again. This is getting to be a headache!
Last Edit: Nov 25, 2015 13:58:14 GMT by arsonist
Stu
Nov 25, 2015 15:13:53 GMT
Hi, sounds like good progress is being made. I've only skimmed through the posts but haven't seen it mentioned how to definitely find TDC so I'll document some steps I generally use here which may help: 1. Remove spark plug number 1 - nearest to cam pulley. 2. Insert long thin screw driver, long allen key or similar down plug hole until you feel it touch the piston. Make sure to use something with a handle that can't just drop in the plug hole and disappear! 3. Using a spanner on crank pulley, rotate engine and watch screw driver rise and fall with piston movement. Note point it reaches it's highest lift and then start to fall. It will take a bit of to and fro action to get it to the exact top point. This is TDC. 4. Check mark on crank pulley is aligned to arrow on the block. It should be. 5. Check cam pulley mark (VWs often have a tiny indented circle mark stamped on the inside pulley edge that lines up with a mark on the cam cover) is aligned to where it should be. That means timing belt is fitted properly, top and bottom of the engine are in sync. 6. Remove dizzy cap, check rotor arm is pointing to a little nick / indent in the outer casing. You might have to feel for it with a finger nail, they aren't easy to see. That rotor arm position corresponds to plug lead 1 being active and confirms base / static ignition timing is correct. Don't worry if it isn't spot on to the centre of the rotor arm so long as it's within a few mm either way at this point, that will probably be intentional to set the ignition timing correctly. Hope that helps? Stu EDIT: This pic may help, found via google on VWVortex.
Last Edit: Nov 25, 2015 15:19:00 GMT by Stu
smeden
"Full throttle until you see God,then shift to second"
Nov 25, 2015 16:42:08 GMT
I'm no ekspert when it comes to vw's (or anything else for that matter) On my old buggy, and on my camper there is a fuel cut of valve on the carburator. It's a small valve that shuts of the fuel in the carburtor when there is no ignition on the car. I don't know if there is a simular valve on your car but it's worth checking! It could be powerd from the ignition coil! The car wont start if it's faulty! Keep up the good work! It will start up adventually!
Jaguar xj6 S1 swb manual VW Bay Camper Audi A3 1998 1.8 VW Beach Buggy (sold) Ford Mondeo mrk I RS Celebration (written off) Ford Escort Mrk II RS 2000 (rust in peace)
Nov 25, 2015 17:03:40 GMT
As mentioned given the cars history of running and then laid up there is no real reason to suspect the timing is way off at this stage. However you could just check the dizzy is nipped up tight though.I remember working on an old Kent engine where someone hadn't tightened it up properly and i felt the dizzzy move while i was fitting points and fiddling about.Timing was a mile out,partly because it had moved while i was working on it and it had no doubt moved a bit with engine vibration previously too.
Nov 25, 2015 20:32:50 GMT
Hi, sounds like good progress is being made. I've only skimmed through the posts but haven't seen it mentioned how to definitely find TDC so I'll document some steps I generally use here which may help: 1. Remove spark plug number 1 - nearest to cam pulley. 2. Insert long thin screw driver, long allen key or similar down plug hole until you feel it touch the piston. Make sure to use something with a handle that can't just drop in the plug hole and disappear! 3. Using a spanner on crank pulley, rotate engine and watch screw driver rise and fall with piston movement. Note point it reaches it's highest lift and then start to fall. It will take a bit of to and fro action to get it to the exact top point. This is TDC. 4. Check mark on crank pulley is aligned to arrow on the block. It should be. 5. Check cam pulley mark (VWs often have a tiny indented circle mark stamped on the inside pulley edge that lines up with a mark on the cam cover) is aligned to where it should be. That means timing belt is fitted properly, top and bottom of the engine are in sync. 6. Remove dizzy cap, check rotor arm is pointing to a little nick / indent in the outer casing. You might have to feel for it with a finger nail, they aren't easy to see. That rotor arm position corresponds to plug lead 1 being active and confirms base / static ignition timing is correct. Don't worry if it isn't spot on to the centre of the rotor arm so long as it's within a few mm either way at this point, that will probably be intentional to set the ignition timing correctly. Hope that helps? Stu EDIT: This pic may help, found via google on VWVortex. Thanks for this. I will put the screwdriver test to use later tonight! I aligned the crank pulley marks up, didn't know the cam pulley had them too (that's the one above the crank pulley, right? ) When this was lined up, the dizzy arm was nowhere near it's own notched mark as in your photo, it was a good 40 degrees off. So rotating the dizzy 180 degrees would still make no difference. (Photoed in a post above. They were all taken at the same time without cranking in between photos.) I just found some old (terrible quality) photos from before I removed the old cap. From these I drew a diagram. The diagram matches a photo that highvoltage sent me, conforms to the specified firing order and also goes clockwise. So if I just re-wire the cap as per the drawing, it should all be lined up to before I took the car on? Will also check the fuel kill switch, if there is one! Thanks! Sorry for the terrible quality. This is the diagram is worked out from the above photos. Reckon it's about right?
Nov 26, 2015 21:11:13 GMT
In the diagram, if you start from number one cylinder. the firing sequence is correct at 1342. However I can't tell from the photos which point on distributor cap is for the number one cylinder. But so long as you correctly identify this and then follow your pattern. The firing order should be spot on. ( I hope that makes sense)
And about the rotor arm not matching the the timing marks on distributor body. You can actually move the distributor body with out moving the rotor arm. The body is usually clamped down by a screw. Set all your timing marks again, lining up the cam and crank markings. If the rotor arm is still 40ish degrees out from the marking as you say, turn the body till the markings line up. This should get you timing set up well enough for the car to run. It can be fine tuned with a timing gun later if needs be.
It's been a while since I've done this, so if I've given wrong advice, I apologise and feel free to correct me
1972 viva 'Sparky'
Nov 26, 2015 22:15:04 GMT
In the diagram, if you start from number one cylinder. the firing sequence is correct at 1342. However I can't tell from the photos which point on distributor cap is for the number one cylinder. But so long as you correctly identify this and then follow your pattern. The firing order should be spot on. ( I hope that makes sense) And about the rotor arm not matching the the timing marks on distributor body. You can actually move the distributor body with out moving the rotor arm. The body is usually clamped down by a screw. Set all your timing marks again, lining up the cam and crank markings. If the rotor arm is still 40ish degrees out from the marking as you say, turn the body till the markings line up. This should get you timing set up well enough for the car to run. It can be fine tuned with a timing gun later if needs be. It's been a while since I've done this, so if I've given wrong advice, I apologise and feel free to correct me What do you mean by 'which point on distributor cap is for the number one cylinder'? Do you mean the photos are just such poor quality that you can't work out which wire goes where? Or do you mean which point inside the rotor arm is pointing at? Good tip about rotating the the dizzy though. I'm guessing I just make sure the crank and cam pullies are TCD together, then rotate the dizzy to match? Once everything is lined up, should the arm be pointing directly at number 1 HT lead ready to make contact and fire? Thanks for this, really helpful Sorry for being a constant pain!
Nov 27, 2015 13:15:45 GMT
Yeah, I wasnt particularly clear about what I meant, sorry. Yes once everything is lined up the rotor arm should point directly at the number one ht lead. (that's what I meant to say,I just wasnt very clear) and just double check when you put the ht leads on you start in the right place. Such an easy mistake to make. And don't worry, Your not being a constant pain, your more like mild irritant. Kidding of course, we're all happy to help
1972 viva 'Sparky'
