Apr 29, 2011 20:06:25 GMT
I've got a problem, it involves Ford Sierras and a short attention span. The cycle is always the same I buy a Sierra then for some reason I get bored with it and sell it (or crash it) then buy something else to fill the car shaped void in my life. Then there is the honey moon period were the "other car" is great and fun, but then after a while comes the realisation that these "other car" no matter how good isn't quite a Sierra. I know this sounds weird but I just love them, they are mechanically simple, parts are cheap, they are easy to modify and personally I love the way they drive. So with that in mind, I recently got offered a Sierra from a mate of a mate of a mate............. and the rest is history! It's a little crusty in the usual places, rear sills and battery tray mainly, but it well solid and seems like a good car. It pulls well, doesn't burn any oil (despite 120,000 miles on the clock). I've already swapped the clear indicators and side repeaters for orange ones, because I prefer them........ ......and I sold the 17" Khan reps which have been replaced for the meantime with 15" TSW Imolas I had laying around. So what are the plans ;D Replace the leaky heater matrix (with a new one I've got) Remove tow bar Weld the diff Lower it (first on cut spring, but I've got plans for a cheap uber stiff setup using transit front springs ) Change the front suspension for re-drilled 4WD hubs to increase caster angle and lock Fit some cool wheels (maybe Wellers or Saab three spoke I've not decided yet) Fabricate some kind of silly shotgun style exhaust pipe Comment and abuse welcome
Last Edit: Sept 12, 2011 19:24:45 GMT by Robinxr4i
v8jim
Apr 29, 2011 20:30:07 GMT
coooooooooool another one do transit springs fit? ?
Max sig pic size: 80px
Apr 29, 2011 21:12:02 GMT
do transit springs fit? ? I think so only way to find out for certain is to actually try and fit them. However I've done some research at work (handy working at a motorfactors sometime). Basically after seeing the rear springs Ryan fitted to his Sierra it got me thinking about what spring I could use to get mine low and hard! So I ordered up a load of van and large car springs and compared them to a heavy duty Sierra spring. I found that Ford Transit 90-00 shape front spring seem to have an almost identical internal and external diameter and are perfectly parallel too. The photo shows the heavy duty Sierra spring on the left, a Transit spring in the middle and a heavy duty Transit spring on the right. As you can see the thickness of the spring is much greater than the Sierra spring and as such is much harder to compress. The plan is it get a pair of second hand springs, offer them up and then cut them to a suitable length. Hopefully paired to some second hand Konis. Then skid skid win win, well thats the plan!
dallow
Apr 29, 2011 21:13:34 GMT
gotta love a saph
rtlkyuubi
Low and Slow
Apr 29, 2011 22:39:24 GMT
yey sierra love! Need to get some twin streeto up cheddar next time I'm in bristol ;D
BiAS
Insert witty comment here
Club RR Member Number: 147
Lovely work sir! I knew you'd be back in the fold, now get it on its ar5e and bring me twin streeto vids
(car+wheels)-rideheight=WIN
mk14dr
Yorkshire and The Humber
Club RR Member Number: 85
yey sierra love! Need to get some twin streeto up cheddar next time I'm in bristol ;D THIS. It seems you've been doing your homework young Robin, those H/D transit springs do look very hardcore for a car though
I've had a couple of GLSis and feel exactly the same way. I crashed my first one and my daughter has never forgiven me. The second had wiring loom issues and drove me daft with flat batts at inopportune moments. There's an Alfa on the drive now that cost about 10 times what my last Sierra did but a large part of me would be just has happy in that old Sierra.
I don't think my back would be up to running those springs though.
Jaguar S-Type 3.0 SE
conrad
Here to fix your cabin.......
niiice. sierras are awesome. says the guy selling his only one he has left.. doh! Oh well i'll get another one, just need something cheap and diesel for the moment.
As for the springs, maybe try the non HD transit ones first, in case the HD ones actually cause you to damage yourself. potential to be a seriously boneshaking ride
Ryan that may lead to some badly bent panels lol! But I'm game. The idea of a pair of twining white and black Sierras makes me happy ;D The Transit springs are only for the rear I just find that every Sierra I've even been in is too softly sprung at the back (even with coilovers) they always do the classic squatting under acceleration thing. I want to use the Sierra to drift and the idea suspension setup involves much stiff rear suspension at the rear than I can find cheaply and off the shelf. At the front I want to again get some Koni or Spax dampers and pair them to some Sierra cosworth lowering springs. For drifting Sierras lack caster and lock, so I want to use 4WD front hubs as they give more caster angle than the 2WD hubs. I had them left over from when I broke the XR4x4 I had. I've already removed the CV joint innards......... .......and to increase lock I want to get the hubs redrilled to change the location of the track rod end. Like this....... .......although I want a tapered hole so I can use the OE track rod ends, instead of the bolt and rose jointed affair I'm the photo. Using 4WD hubs means I must use the pinch bolt type track control arms (which I've also got) and the larger diameter 4WD dampers too (which I don't have).Â
FU*K! Someone should have shown me that picture a week ago when I had the taunus front end apart! I've also felt my sierras have been too soft in the back, but yellow konis stiffens up the rear alot more than most stiff springs i've tried. Combine them with those, and i'm sure it'll be great. Loving your plans for it Bookmarked!
Last Edit: May 1, 2011 20:38:05 GMT by dude
B-8-D
down to one car!!
excelent
glad you got another sierra.. and a twincam too great stuff.. and if you decide to give chedder a go let me know dude id like to take pics of that!!
si
rtlkyuubi
Low and Slow
liking the info on the steering as the next time i see you I'm gonna pick your brains for the parts needed and what to do with them
Made a decision as regards wheels, hopefully picking some Saab three spokes up at the weekend for dirt cheap (ideally I would love Wellers, but they seem to go for much stronger money now than they used too. Plus I don't want to make a carbon copy of Ryan's hatch!) Just need to work out what colour to paint them, I'm swaying towards some kind of horrid bright green ;D
Just need to work out what colour to paint them Horrid Bright Green with pink'n'yellow splatter. You know you want to. ;D
Peach with some luminous splatter.
mk14dr
Another vote for splatter rims,
Another vote for splatter rims, Only if at Area 52, drunk, with a spray can in one hand and a burger in the other..... Come on Robin, you know you need to come back for another fix. While I think of it...so do you Dave. Robin back behind the wheel of a Sierra FTW! Need to see it. In the flesh. On the 20th>22nd - make it happen Dude. ;D
Yup, RAL6018 green on the wheels, bumper stripings and mirrors.
Click picture for more
Prepared a little and dirty photoshop:
