bazzateer
Imping along sans Vogue
Sept 10, 2007 16:31:59 GMT
Last Edit: Sept 29, 2015 20:25:33 GMT by bazzateer
Sept 10, 2007 17:13:41 GMT
Nice straight looking car with LOTS of potential!
Sept 10, 2007 19:52:26 GMT
I was loving that on the bay, got a bit pricey for me though as i am a tightwad. Nice work!
Sept 10, 2007 20:27:13 GMT
You're the third person to buy that car off of eBay! It appears to be in pretty good nick though.
I'm not sure if it is worth the trouble of going to a Holbay Head cause you then need to change the pistons to keep the compression up, and the inlet ports are smaller so you are basically restricted to the factory twin weber setup unless you fabricate a manifold for bike cars. The Holbay also has a different cam grind.
I'm pretty sure Dave Vizard did an article on porting the stock alloy head that will allow it to produce about as much power as a Holbay.
If you are interested I think I have a twin stromberg inlet and the matching carbs. I've also got the matching exhaust manifold but you'll have to wait for that until I have my recently acquired Sceptre engine swapped into my minx.
I also know someone who has a bunch of bits for these cars, such as OD gearboxes, and possibly a heavier duty antiroll bar.
PM if you are interested.
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
bazzateer
Sept 10, 2007 22:35:18 GMT
You're the third person to buy that car off of eBay! It appears to be in pretty good nick though. I'm not sure if it is worth the trouble of going to a Holbay Head cause you then need to change the pistons to keep the compression up, and the inlet ports are smaller so you are basically restricted to the factory twin weber setup unless you fabricate a manifold for bike cars. The Holbay also has a different cam grind. I'm pretty sure Dave Vizard did an article on porting the stock alloy head that will allow it to produce about as much power as a Holbay. If you are interested I think I have a twin stromberg inlet and the matching carbs. I've also got the matching exhaust manifold but you'll have to wait for that until I have my recently acquired Sceptre engine swapped into my minx. I also know someone who has a bunch of bits for these cars, such as OD gearboxes, and possibly a heavier duty antiroll bar. PM if you are interested. Bit of a bargain in my book, the winning bidder changed his mind and the seller offered it to me at my high bid but we did a deal and I got it for considerably less than my original bid. The mechanical (engine/box) upgrades are for the future when I have a garage to work in. For now it'll be wheels/tyres and a few other bits as money is getting tight again! MRABODY: I'm interested in any bits you may have access to but I cannot find the PM section on here at the moment! Feel free to email me at: bazzateer@hotmail.com Cheers guys Baz
Sept 10, 2007 22:58:19 GMT
Looks cool. What differences are they between this and a humber sceptre of the same body shape?
Matt
bazzateer
Sept 11, 2007 7:15:16 GMT
The Sceptre has a different face with twin headlamps and grille and IIRC it has the o/d box as standard and Twin Strommies. The GLS had the Holbay head and some variants may have had twin 40s (but I may have dreamt that!). I think the Sceptre often had a vinyl roof too along with (probably) a slightly better dash with a tacho?. Here's a Sceptre from last night at the Ace This is all from memory so don't take it as Gospel. Baz
Last Edit: Sept 12, 2007 8:50:58 GMT by bazzateer
Sept 11, 2007 10:49:58 GMT
The Holbay engine which came in the GLS and the H120 had the following changes from stock.
Holbay specific head with smaller inlet ports and revised combustion chambers Holbay specific pistons (to bring the compression ratio back up with the large chambers in the Holbay head) Lumpier Cam Twin 40s Tubular exhaust manifold. Some also came with an alloy sump.
Other engine variants are as follows
Iron head 1496 (I think) came stock in Minx and Gazelles and later low spec Hunters Iron head 1725 was fitted in place of the 1496 in cars equipped with an automatic transmission
Alloy head single carb 1725 standard in Vogue, mid range hunters and fastback Alpine
Alloy head twin carb 1725 standard in Rapier, Hunter GT (and GL?) and Sceptre. Had different cam, and exhaust manifold to the single carb version.
Also, Alloy and Iron head cams don't interchange as they inlet/exhaust valve sequence is different between the two motors.
All 1967 Arrow range vehicles with the 1725 also came with the alloy sump, and probably 1968 cars as well. So your Singer should have one.
Last Edit: Sept 11, 2007 10:51:25 GMT by mrabody
bazzateer
Sept 11, 2007 12:40:56 GMT
All 1967 Arrow range vehicles with the 1725 also came with the alloy sump, and probably 1968 cars as well. So your Singer should have one. I think it does, if I remember to I'll have a look tonight! Thanks for the other info' - at least I wasn't dreaming about the twin 40s, well......not then anyway! Baz
Sept 11, 2007 18:33:51 GMT
Cheers thats great info. What sort of power does an alloy head, twin carb 1725 sceptre engine make?
Matt
Sept 11, 2007 20:24:56 GMT
Cheers thats great info. What sort of power does an alloy head, twin carb 1725 sceptre engine make? Matt About 95 hp I think. Only about 10 or 15 less than the Holbay.
bazzateer
Sept 12, 2007 8:55:11 GMT
Had a look under Madge last night and the sump is ally coloured and ribbed (for her pleasure? ) so I guess it's an ally sump! Baz
Sept 12, 2007 12:57:09 GMT
Chuff me thats quite a lot mine should be fine for driving in traffic then.
Matt
qwerty
Club RR Member Number: 52
Sept 12, 2007 14:50:13 GMT
Got a realy soft spot for Hunters/Vouges they're so unloved but look really cool!! Wheels shouldn't be hard because IIRC they're 4x108 pcd?
bazzateer
Sept 12, 2007 15:00:20 GMT
Picking up a set of 6x13 RS alloys on Friday and may end up with some other ones by the weekend too! Depending on what I get I may be eBaying one or more sets in the next week or so.
Baz
Mr K
Sept 13, 2007 12:21:07 GMT
COOL!
a guy who used to work for us had a sunbeam alpine with a holbay motor on twin 40s; it sat for ages and ages in a shed up at our place after he had it resrayed; it got nearly complete and then he stopped. it must have been in there atleast 15 years. about 6 months ago we needed it gone and i had a nosey around it; it was rotten as a pair and the shed had no roof! what a waste.
a friend tried to buy it but he wanted silly money. its sitting on his driveway now under a sheet having been evicted; god only knows what hes going to do with it!
i like the sound of the nice period tuning parts and mods on this!!
bazzateer
Sept 13, 2007 13:58:32 GMT
Cheers I'm going to have to stop 'shopping' after this weekend as the money is running out fast! I've also got an Imp to look after! Baz
bazzateer
Sept 17, 2007 15:16:33 GMT
These are the wheels I'm going to put on her. Have to wait 'till pay day before I can afford the tyres though! (185-70-13) Maybe next payday actually Baz
Sept 17, 2007 15:43:23 GMT
You have PM.
bazzateer
Sept 24, 2007 23:26:20 GMT
Madge took me to Wales and back this weekend including a trip to see Brian and collect some wheels/tyres (cheers Brian ). 700 miles in all and she went really well until about 8 miles from home in London when the clutch gave up. Looks like the slave has gone but I'll probably change the master too, just to be safe! Baz
