Like a lot of people, I have to work around limitations like lack of money, lack of space, lack of time, etc... But, if these limitations were lifted, what would you want your car to be like? For my Benz, I'd want... Complete strip-down, acid dip of the chassis Gloss black paint Fast air suspension Custom leather interior Some discreet but high quality ICE Maybach 57S engine and gearbox - 6.0 litre, twin turbo V12 Not sure about wheels... ...ah... if only... ;D What would you do to yours?
Your idea sounds pretty spot on to me, although I might tone down the engine just a little!
I think I'd keep it burning the veg oil to be honest but nicely modded. That said, I love the beige! Can't get rid of that! An interior revamp would be nice though.
rob0r
East of England
Club RR Member Number: 104
My E21 316: Complete strip-down, acid dip of the chassis Gloss black paint (Copying benzboy I know ) Leda specialised coil overs Period E21 Recaros Cage BMW S52 3.2 M3 engine turbo'd 323i rear subframe (for rear discs instead of drums) Polybushed all round Wilwood brakes all round BBS splits, 7" front 8" rear
E30 320i 3.5 - E23 730 - E3 3.0si - E21 316 M42 - E32 750i ETC
Lex
日本車 <3
For my Golf, everything to make it like a brand new Golf again, but dropped with wide wheels and a loud stereo system.
Resto-UKal
ThePollitt
Fix up, look... at that car on eBay!
The Capri....urm, i'd like it go from this.... to this.... with this.... It makes sense.
for the Manta.. strip to component parts / bare metal, repair and rebuild whole car, satin black (as in not matt but not metallic shiney) paintjob full Lotus Carlton running gear conversion, engine, 6speed box, LSD, remake the suspension and drive shafts to fit the 5stud hubs and brakes under the standard manta body no wide arches or unseemly bulges, no 400rally kit, reasonably tame 16/17inch wheels, don't want any outside clues as to the spec breathe on the engine / turbos to get it up to ~450bhp, ideally 500bhp if that's doable without chewing the engine/turbo parts too badly rollcage dash mounted 7inch motorised LCD touchscreen in the radio hole car-pc built into the boot for music and net access on the move go scaring people on the motorways
money no object for a daily driver?
I'd have a new Mercedes AMG CLS 6.3, take the body off it and drop a stack light coupe shell on instead, loverly modern power and relability with some style.
Polo: New wings, front panel. Body blasted/dipped, painted in the same tornado red, redo the chequers on the boot but with satin black. Have the banded steels completely sand blasted and painted satin black with chequered centre caps, notch the chassis rails and change to mk1 golf shorter front shocks to allow me to run superloww. Have the arches rolled front and rear (before paint...), get some better condition arch covers. Plenty of other 'plans' as well
J.P
I like to eat ice cream and I really enjoy a nice pair of slacks.
Before I'd start any retro work i'd built a MASSIVE garage with heating, storage, lifts, lathes, all the tools etc, then..
Mini:
Get rid of the servo and replace with Single master cylinder. Properly cut the front arches before painting. 1380cc, Arden 8 Port head with ITB's and DTA ECU, Steel crank and LSD. Clean up the engine bay more. Fit green tinted glass instead of clear. Not cut a hole in the roof for an ariel. 10x6.5 Banded steels with Yokohamas. 10x9 Splitrims with stretched ATV tyres.
Metro: Sort out all the bodywork. Carbon fibre bumpers, bonnet, boot and doors. Convert front for coilovers. Turret the rear for coilovers. Replaced rear subframe with titanium bean and titanium radius arms. Fully adjustable suspension. Solid mounted everything. Paint it gold. Multipoint cage.1 Bucket seat. 1925cc K Series on ITB's, steel crank, LSD the lot, full race jobbie. On board camera system. 13" splitrims and 4 Pots.
Then i'd buy my other dream retro's and continue going 'All out'
Last Edit: Mar 5, 2008 17:53:32 GMT by J.P
bstardchild
Club RR Member Number: 71
Monza + LS1 + 10 inch rims and low - that'd do it for me
I'm already building mine, though if the budget wasnt already spent, it would probably be a TDI 140 engine, with 6speed and leave everything as it it will be..........
Snoozin
Toyophile
KP with coilovers front and rear, hot 5K on twin sidedrafts, TRD U-code 4.7 LSD, AE86 brakes.
That'd see me right.
I've more or less got everything I need for my car so and Cat 1 Alarm and rolling road set up would see me happy
Other things I would like is a 2 poster ramp, enough fine weather to get things done, a bigger garage and more standing space, and a fully lined back account!
205 GTi Mi16
205 XS - Now in filmidget's signature
Clio dci 80
I've found in life if someone is an idiot, they generally stay and idiot.
For the Primera nothing because anything you did would make it less caable of fulfilling the role of daily driver.
The Mini, the next step would be for someone to give me a handful of twennies and trailer it away.
The Golf GTi (that I don't actually have). 2.0 engine, touch of the stick, 15" steels, arches off. Job done
Jaguar S-Type 3.0 SE
For the Camry
turbo 5SGTE, fully built pristine detailed engine bay, metal flake blue & pinstriped ragtop sunroof rust repairs (but leave the rest looking a bit worn as it does K sport coilovers w/ raised shock towers 13x9.5 wide steelies, metal flake blue
1986 Toyota Camry HB 1992 Toyota Tercel turbo 1972 Datsun 510 1992 Honda Accord EX-R wgn. Same as always, use THE FORMULA....... Your Car + {(Suspension - Height) + (Wheels + [3xWidth])} = THE WIN
For the Imp: Make it look like this- Complete strip down, perfect all the dings and dents brought on from the crash with as little filler as possible. (Still means alot) Repaint in the original Caribbean Blue Lowered on air bags so it can sit on the floor, yet be driveable with the flick of a switch Lots of lovely shiny chrome/black numberplates etc. Cobra Classics inside Chess board dash with moon eye dials Chess board headlining Engine bay cleaned up with everything moved under back seats 1.6L Ford Zetec SE fitted ala original imp engine, maybe even supercharged who knows. Fully mappable though, all that jazz. Rad moved to front Custom wiring loom incorporating alarm, remote locking etc Dixie horns!!! Yeah so erm, not much todo then At least I've got the wheels already I guess
Mmmmm!
Sprite - body sorted (a few icky areas), tweaked rear arches so that the Mambas don't scrub, engine rebuild finished, & a shorrock blower ;D Maybe a Ford 5 speed box, but not essential
Amazon - full but sympathetic restoration, modern turbo diesel (don't know which but whatever fits, goes well & doesn't drink much) & Torque Thrust Ds with matt body colour centres ;D
Last Edit: Mar 5, 2008 22:36:14 GMT by Paul H
for my viva, ideal mods would be.....
-an MOT -a f#*k load of fuel -loads of 185/55 13s
edhall
Jag XJ40 - Borbet A rims (or Jag 8x16 lattice), twin headlamps, a respray and a supercharged XJR engine. Actually, sod it, a twin turbocharged 6.0 V12. Porsche 924 - 968 running gear, a cage, stripped out with buckets and harnesses but looking as it does now with BBS wheels. Though an engine that wasn't in little pieces would be a start. Mk1 Escort 1300E - mint standard purple 2dr 1300E with Mexico steels on the outside, stock and mint on the inside. 2.3 200bhp Duratec under the bonnet, close ratio type 9 and Atlas axle. Anything would be better than a shell and few boxes of bits. Mk2 Escort trials car - actually I'm nearly there LDV Pilot Campervan - decent, plush fully working inside made by somebody who has the first clue as to what they're doing. Plus a turbo diesel engine. Actually, maybe not an LDV Pilot... Mk2 Polo - coilovers, G60 steels, maybe a 1.8T. Haven't thought about this one enough as i only pick it up tomorrow. This daydreaming does me no good
Escort Mk1 1300E – SOLD! Escort Mk2 Trials Car – SOLD! Porsche 924 Jaguar XJ6 4.0 Sovereign – GIVEN TO DAD! LDV Pilot Campervan – SOLD! VW Polo Mk2
Fuzzy
Powered by bees.
Big arches, wide wheels, lower, racier suspension, bright orange paint, buckets, a rev counter (maybe dials from another car) and a 1368 16v Turbo pushing at least 150 brake. And a snappy 6 speed box. With a picture of a whale on the back because I can.
