Today my goal was to do hub seals and 2 new gaiters. Took ofhub nut to find that it was damaged and couldn't be tightened full so I ground it out and polished the face
Then pulled hub casing of to find it had no large o ring just siilocone. Stripped out seal the new metal ring that came in kit was too small so reused ole one. Greased new seal and tapped in using 46mm socket. Replaced new gasket and new small and large o rings a pig of a job when your on your own, then a friend Aaron came helped me out 4 hands better than 2. Cleaned up drums shoes, washed inside drums with thinners then scored them with 60 grit and paper and reassembled them, hub nuts on handbrake on and hub nuts tightened up both sides.
Before cleaning
After cleaning
Covered in silcone
new hub kits
Before cleaning
After cleaning
Covered in silcone
new hub kits
