gess
That door is really coming along nicely. I must say I think I would have been a bit overwhelmed during the reskinning if it was me. It seems to be a lot of work and many things that can go wrong, especially during welding. How have you been/will you be treating the backside of the welded area to protect it from rotting out from the backside? Please continue posting ypur progress, it is an interresting thread, really a shame the so much bad work has been executed earlier on this car. But the silver lining is that thr RR community will have a long thread to follow :-)
gess the insides of the doors have been treated with jotlin and zinc primers during and after repairs then with 2k primer , its a lot of work too skinn but ye know what ye have at the end of it ,good doors are hard to find and expensive ,but with me doing them others can learn just as i did , am self taught watching and learning from other people ,everydays a learning day cheers
Jul 18, 2021 16:21:59 GMT
Jul 18, 2021 21:24:23 GMT
Still loving the work you've done so far, It's great to see it being done to such a high standard, Totally agree about learning, I've always said my learning style is "monkey see, monkey do", I can read a subject numerous times and still struggle whereas I find I only have to watch it a couple of times to pick it up, Nigel
Jul 19, 2021 11:22:03 GMT
SO TRUE EVERY DAYS A LEARNING DAY ,
Last Edit: Jul 19, 2021 18:21:19 GMT by shielsy68
Jul 19, 2021 18:12:42 GMT
Jul 19, 2021 18:16:26 GMT
Jul 19, 2021 18:19:50 GMT
Jul 19, 2021 22:44:24 GMT
seems evertime i reply to resto i kill it ,why lol
Jul 21, 2021 17:29:56 GMT
Last Edit: Jul 21, 2021 19:21:30 GMT by shielsy68
Jul 21, 2021 17:47:29 GMT
Can't believe this was restored by a pro.
Jul 21, 2021 18:02:59 GMT
a so called engineer from kendal
Jul 22, 2021 19:59:43 GMT
i need an acellorator pedal wheel the the pedal runs on mine is missing if anyone has a spare cheers owen
Last Edit: Jul 22, 2021 20:00:17 GMT by shielsy68
Jul 23, 2021 19:20:55 GMT
Just removed the alloys to take of the tyres and put them on the original steel rims that I like better then sell alloys for £200 help fund resto Will replace steel brake lines with new copper ones now when it's handi
Jul 24, 2021 17:27:55 GMT
while taken off the alloys i noticed oil on the back of the alloys ,hub seals where leaking .i just went out to take of the rear hub nuts ,pulled out the split pins , well anyone who has done the brakes on a beetle or camper knows how hard they rear hub nuts are to slacken off,large breaker bar with 36mm nut and a lenght of pipe slide up the bar and swinging on it to brake the seal.well i got the split pins of and the nuts where hand tight ,slight move of the socket and of it came both sides , iam replacing gear box mounts all 3 as well work myself round see what other surprises i find
Last Edit: Jul 25, 2021 10:52:39 GMT by shielsy68
Jul 24, 2021 18:13:22 GMT
It's looking good - even though some of the previous work is pants, at least you've a fairly solid starting point, and no doubt you'll have it fettled in no time as usual!
Jul 24, 2021 18:16:17 GMT
i have the making of a good car but hard to believe he spent 6k on it to cut corners
Norman
Jul 24, 2021 18:26:07 GMT
People will do anything to make money, short cuts and bodges. At least if you do it yourself you can’t blame anyone for the quality of work except yourself. You are doing a grand job Owen, when you are finished it will be something to be proud off. Norman
Jul 24, 2021 19:55:38 GMT
thank you norman for your kind words
Jul 25, 2021 19:11:55 GMT
what an inspiration what a resto
