Yesterday I fitted the last but one full size board at the front and finishing off the cuts to the far sided from the doors where the wall meets up with the roof sheets
A new addition to my hand winch, I was finding at times I needed more than one, ordered it from Amazon
The more I look the more I’m finding these empty knots that will need looking at later
The gap to the roof sheets is getting g smaller
I bought some long wood screws and long wood drill bits last week, to hold down the last end wedges
I bought 3 different lengths of screws, 120mm, 180mm and 200mm, the drill bits for the pilot holes are all 300mm long with a diameters of 4mm/5mm/6mm/7mm/8mm/10mm/12mm
The gap between the wall and the roof sheets will be overlapped with the end flashing and from inside the space between the wall and roof sheets will be filled in with builders expanding foam, followed by a breathing membrane and then insulation
This is the 4mm diameter drill bit I was using for the pilot holes, with a depth gauge
The 180 screw
One more full board and one half one and the front tall side will be complete
Working a bit late Sunday night, that or the nights are getting shorter
The 180 screw
