Mar 13, 2023 17:32:22 GMT
could you convert your leaf springs to slippers by cutting a bit of the front eye off and flattening the rest and just buy the slippers for the front mount? I have thought of this, and there is a farrier down the road with a furnace who could possibly do it for me, but I’m unsure what effect this would have on the springs properties. Will it still be. Spring after heating?
Mar 13, 2023 19:03:43 GMT
gavin rodgers on turbosport has done it without issues mate ive heard of others doing it as well
Mar 14, 2023 15:29:23 GMT
gavin rodgers on turbosport has done it without issues mate ive heard of others doing it as well I’ve had a look Danknight. Instead of using the original spring mounting hole in the chassis, Roger has drilled the holes further back in the spring mount. He’s then just cut the eye off the spring. I’ll look into it👍
Mar 18, 2023 17:18:09 GMT
Mar 22, 2023 11:31:34 GMT
So I borrowed these To see if o could run them instead of the leaf springs No. I can not run these. They touch the body and the tire. And that’s without any articulation. Never mind. Slight change of tack. Gearbox tunnel. Those paying attention will remember that the original tunnel had been modified by my younger brother to make gearbox fitting and removal easier. He used a sledge hammer. I cut those crumpled bits out last summer and replaced with flat steel. The front of the tunnel has also been cut and lifted. I’m not completely happy with this so “while it’s in bits” I’m going to fit this. It’s a tunnel from an automatic Escort, bigger than standard to accept the bigger auto box. I’ll have to weld a bit back into the bulkhead as it’s a little lower at the front than the existing tunnel. And I’ll have to redo the gearbox mount, but other than that it’s “just” cut the old out and weld the new in. Job for Saturday
Mar 22, 2023 15:56:07 GMT
Much neater.
Younger siblings are a nightmare. My younger sister and my wife’s younger brother are the reasons why our son is an only child. 🤣
Mar 22, 2023 21:35:36 GMT
Much neater. Younger siblings are a nightmare. My younger sister and my wife’s younger brother are the reasons why our son is an only child. 🤣 I’m sure my older brother thinks the same of me
Mar 25, 2023 18:45:21 GMT
Got up late this morning as I was dragged to a “ghost hunt” by Mrs Jonsey. Unsurprisingly no ghosts were found. Anyway, after breakfast I started on the tunnel. The last post showed the new tunnel levitating about an inch above the floor as the old tunnel extension is in the way. So out with the grinder Also drilled out a couple of spot welds around the gear stick hole A lot of grot in there. Probably a good job I’m doing this. Still not enough clearance so it all came out It was at this point I started stressing and sweating. This tunnel didn’t want to fit good at all. I’d seen a video on YouTube few months ago of a young lad (mk2 Mitch) fitting one of these tunnels so I had a quick flick through his vid. At one point he’s stressing asking himself “why am I cutting up my car” as he realizes the size of the job. I feel your pain young man. My problems were compounded by the fact that I’ve also replaced the floors, I’ve cut out part of the bulkhead, the cars far from straight and I really can’t be arsed with this after 2 busy weeks in work. So I thought to unstress myself I’d repair the bulkhead first. Tacked in Welded And ground With that sorted I put the tunnel back in and played with it in different positions. Went for the best compromise and ended up with gaps like this So I massaged them into place with a hammer and blunt chisel and screwed the tunnel down I then drew around and removed it Then drew another line 15mm further in I then cut it out to the inner line and ground the epoxy off (no photo evidence of this- you’ll have to trust me). I used my joddler/punch to put some holes in the flange. I’ve had this since I was a teenager. The hole is too small (5mm?) so I always dril the holes out bigger. But this puts the hole quite close to the edge of the metal so you can get burn through to the edge. So I got the grinder out and cut the slot from this To this It’s only a couple of mm but will hopefully make the difference. The edge got primed and the tunnel screwed back in I can now plug weld the tunnel in and I’ll stitch weld it also from underneath tomorrow
teaboy
Make tea, not war.
Mar 25, 2023 20:22:12 GMT
Good idea with the joggler/punchy thing.
That's a massive tunnel.
Mar 25, 2023 20:31:37 GMT
Good idea with the joggler/punchy thing. That's a massive tunnel. my first mk2 Escort back in ‘96 was originally an auto so had the same tunnel. I Knew it had a bigger tunnel but I’d forgotten how big it was. It is Massive. Far bigger than it needs to be. But it is a lot neater than what I had. Rallying rules have also changed where bigger tunnels can mean the MSUK classification can change. But this is a Ford fit tunnel so should be ok
Mar 26, 2023 16:29:27 GMT
Today I started plug welding the tunnel I then started seam welding from in the engine bay I then put the car back on the rotisserie (for the millionth time) and seam welded the tunnel to the floor section I then took it back off the rotisserie (for the millionth time) and ground back all the welds inside the car And that was as much as I could be bothered to do today. I now need to fit the engine and gearbox to make the gearbox mount
Mar 26, 2023 22:03:09 GMT
Great work as always 👍🏻. I often modify my hand tools to make them more efficient.....or to make them do something they were never designed for....which then renders then useless for what they were designed for! ....if you know what I mean 😀😀 Ghost hunting....sounds interesting, although, as confirmed by yourself......uneventful. My late Nan used to be interested in all that. She also liked a drink. My dad always joked that she was known as the Exorcist because she wouldn't leave the house till all the spirts were gone! 😁
Opel Commodore A Coupe Opel Rekord C Coupe Opel Rekord C Saloon Vauxhall Magnum Coupe V8 (Magnumania) Mk1 Scirocco GLS Mk1 Scirocco GLS (early chrome bumper) Corrado G60 Mk1 Cortina 2 door Pre Airflow Mk2 Escort 1300 2 Door VW LT35 Tipper Truck BMW 320D E91 Tourer
Mar 27, 2023 16:49:01 GMT
Great work as always 👍🏻. I often modify my hand tools to make them more efficient.....or to make them do something they were never designed for....which then renders then useless for what they were designed for! ....if you know what I mean 😀😀 Ghost hunting....sounds interesting, although, as confirmed by yourself......uneventful. My late Nan used to be interested in all that. She also liked a drink. My dad always joked that she was known as the Exorcist because she wouldn't leave the house till all the spirts were gone! 😁 😁 My younger brother will cut up a tool to do one job as he says it the job won’t get done otherwise. My older brother reckons that he (my younger brother) would also cut up a lifeboat to build a raft.
I was on call on Tuesday. I had planned to refit the engine in the morning but when I woke up it was peeing down, so watched TV instead. So this morning I was up at 9, fry up and then out the garage. First I had to tidy up as the place was a sh1t tip. That done, it was time to fit the engine and ‘box. It’s on a trolley which makes it easy to move around on my own. When I took the engine out it was tight with the manifolds still on so I removed the exhaust side to make things easier So with the trolley positioned under the ‘bay, I lowered the car onto the engine and ‘box. It’s still on the cross member so after a couple of attempts I got it all lined up and 3 of the cross member bolts in. One has gone missing somehow. The only casualty was the dip stick pull snapped off 😩. I think I have a spare. The bit of wood is to hold the gearbox where I want it. When I fitted the tunnel I didn’t cut the gear stick hole Using the aluminum gear stick hole thingy as a template, I marked up the cut lines Quick zip with the grinder And we have a hole. The gearbox can now lift higher up into the tunnel and I can start making the ‘box mounts. When I first fitted the 5 speed I just drilled some holes and bolted the mount to the floor. With the new tunnel the mount isn’t long enough to bridge the gap. I could weld extensions on and bolt it back through the floor again. In fact this is what I did when I had put a manual gearbox into my old mk2 Escort auto shell. But I decided to make some box mounts in the tunnel instead. It was at this point I forgot to take any photos. But in a nut shell, I bent some 1.6mm steel, welded some m8 nuts inside and tacked them to the shell. It was at this point I remembered to take some photos so here you go. I really should have taken the engine and ‘box back out and put the shell back on the rotisserie so I could weld it all together. It would have been tidier and I wouldn’t have had molten steel dripping on me, but I couldn’t be arsed with all that so buzzed them up from underneath whilst molten steel dripped on me. A bt of primer got added and the mount bolted up so I could see the results of all my hard work. I might grind all the welds off. I might not. I’m navigating for my nephew in his Astra GTE at a rally in Caerwent army base tomorrow so there’ll be no progress until next weekend.
teaboy
Make tea, not war.
Excellent stuff, dude.
Remind me what engine it has, please.
Excellent stuff, dude. Remind me what engine it has, please. Thanks Mr T. It’s a Ford I4 engine out of a mk5 Escort Rs2000 16v. When I first fitted one it was 150bhp for £100. They’ve gone up a bit now. I’ve got a 2.3 bottom end from a Ford Galaxy that I may use to give a bit more go.
teaboy
Make tea, not war.
Excellent stuff, dude. Remind me what engine it has, please. Thanks Mr T. It’s a Ford I4 engine out of a mk5 Escort Rs2000 16v. When I first fitted one it was 150bhp for £100. They’ve gone up a bit now. I’ve got a 2.3 bottom end from a Ford Galaxy that I may use to give a bit more go. 2.3 sounds like a good idea.
Thanks Mr T. It’s a Ford I4 engine out of a mk5 Escort Rs2000 16v. When I first fitted one it was 150bhp for £100. They’ve gone up a bit now. I’ve got a 2.3 bottom end from a Ford Galaxy that I may use to give a bit more go. 2.3 sounds like a good idea. There was a 2.3 with 260bhp on fb this morning for £2800. Bargain. Mrs Jonsey would go nuts if I spent that money though
teaboy
Make tea, not war.
There was a 2.3 with 260bhp on fb this morning for £2800. Bargain. Mrs Jonsey would go nuts if I spent that money though I won't tell her if you don't.
Good Friday. No rain for what seems like an eternity. Gave the grass its first cut this year. Nearly 4 hours later, with that sorted, I fixed the exhaust, boot switch, indicator bulb and oiled up the eldest’s car. Then I opened the old garage and found this I put the battery on charge as I knew it would take a bit of cranking to get the fuel to the carbs While that was charging I turned my attention to the Escort’s gearbox tunnel. I’d primed the mounts I welded on from below but not in the car I have them a quick going over with the power file and added a bit of paint This was done both sides. I then tried to start the Cortina. After a bit of cranking it fired into life for the first time in 6 months. The youngest wanted to go for a drive so we jumped in, but it wouldn’t go in gear. I thought it must have lost clutch fluid but it was full. Got the boy to press the clutch and the arm moved fine. The clutch plate must have been stuck to the flywheel. Started the engine with it in gear and foot on the clutch and it broke free after a few feet. A quick press on the brakes to make sure they were working and off we went for a 20 mile “spin”. Quite enjoyable.
