The Doctor
Club RR Member Number: 48
1987 Toyota Starlet 1.3 SXLThe Doctor
@thedoctor
Club Retro Rides Member 48
Jun 15, 2014 20:48:41 GMT
New job further away from home and a broken daily do not match, so i needed a new daily. I found this for sale and i went to take a look, it's not perfect, but i love it! With it being an SXL it's pretty good equiped for a shopping trolly Decent seats, 5 speed gearbox, loads of extra plastic in the interior etc. etc. It's allready lowered on loweringsprings with koni red shocks and is wearing some nice Borbet 15" wheels. Powerhouse is nothing spectacular, but it'll get me to and from work for now, might be doing something under the bonnet in the future. Plans are to fix the rust first, and fix the minor issues it has at the moment then look into modding. I want to build a semi decent sound installation for it, so i can listen to some music in better quality then the 27 year old original speakers
Last Edit: Jul 27, 2019 10:16:47 GMT by The Doctor
1987 Toyota Starlet 1.3 SXLRobinxr4i
@robinxr4i
Club Retro Rides Member 143
Jun 15, 2014 21:14:52 GMT
Now that's a cool little daily, even like the softline 5 spokes.
Jun 15, 2014 21:45:55 GMT
something a bit different nice daily
The Doctor
@thedoctor
Jun 16, 2014 14:58:10 GMT
Now that's a cool little daily, even like the softline 5 spokes. They do suit better then they haven any right to, don't they? Thanks!
Siert
Jun 16, 2014 15:51:21 GMT
I like it. If starlet badging is anything like the E8 corolla's then SXL is purely an invention of the Dutch importer.
Last Edit: Jun 19, 2014 17:03:28 GMT by Siert
The Doctor
@thedoctor
Jun 16, 2014 15:53:04 GMT
It is, some more options put in the car and another badge at the bootlid
The Doctor
@thedoctor
Jul 12, 2014 19:05:52 GMT
Managed to find some 1.3S parts on Marktplaats, i went to pick them up today, and fitted them when i got back home Out with the old In with the new I have to clean them a bit, will do that later, but i just had to fit them. Pretty rare stuff, not a lot of 1.3S cars got sold overhere.
The Doctor
@thedoctor
Feb 14, 2015 23:38:16 GMT
In the mean time, i've upgraded the brakes (227mm solid disks to 255 vented and bigger callipers): Added a rear spoiler, because it looks nicer: Took it out on track twice, had loads of fun: But it was lacking power, i was on semislicks, but my mate, with the same Starlet was just as fast as i was, but he was on normal street tires. Our cars just aren't fast enough! So to solve that, i made a plan, which consists of a frankenstein build of 2 engines. 'big' bore 1.3 16V and a short stroke 1.0 12V engine combined, giving me a 1107cc short stroke 16V engine. Capable of high revs, and delivering some power, i hope to be near 100hp in the end. It's probably easier and quicker to swap in a 1.3 Turbo from a later Starlet or Glanza, but where's the fun in that? So far no pictorial updates about the engine stuff, but i found out the 1.0 block differs in height from the 1.3 block, dus making the 1.3 pistons come 2mm out of the (bored out) 1.0 block, or 8mm shy off the deck on the 1.3 block. I'll go for a 2mm headgasket and use the 1.0 block as a base. Then lightening the crank and flywheel, get the cams reground and uprate the valvetrain, do some port work on the head and add 40mm Weber DCOE carbs together with a nice exhaust manifold. I hope all this makes me an engine which will go up to 10k rpm, i know the stock 1.0 engine goes upto 7,5 - 8 allready, before the valves start to bounce It won't be the smartest choice, the engine will probably be frugal, but i just want to see if it's possible to build a stupid engine for my daily commuter
Last Edit: Feb 14, 2015 23:46:23 GMT by The Doctor
Really cool little car this.
Feb 15, 2015 10:58:50 GMT
1.1 screamer oh hellz yeah bike carbs give way more bang for buck
Feb 15, 2015 11:29:34 GMT
You should put a 2zz-ge in it, free 6 speed box upgrade into the bargain and 190bhp bone stock. I built one 5 years ago... Project "Buzz" was a flying machine.... lightweight engine, revs to 8500rpm, extra cam lift at 6000rpm, full of win.
The Doctor
@thedoctor
Feb 15, 2015 22:14:56 GMT
i'm sure it's a hoot to drive, but that is way, WAY above my skillset
The Doctor
@thedoctor
Feb 22, 2015 18:38:30 GMT
Well... a week later and i managed some more investigation time on the new engine on top the 1.3 crank, bottom is the 1.0 crank. 1.3 crank is better balanced with 8 weights, but way heavier then the 1.0 crank. Then i tried the 1.0 crank in the 1.3 block for comparison. 1.3 crank, block and pistons: 1.0 crank, 1.3 block and pistons: Exactly as i suspected, the 1.3 pistons are 2mm higher then the 1.0 pistons, but due to the shorter stroke of the 1.0 crank, they sit 8mm shy of the deck now. I thought about 2 options: - shaving 8mm of the 1.3 block - boring the 1.0 block from 70.5 to 74mm and us a 3mm MLS headgasket I then got a tip from somebody to use longer rods, which sounds like a good solution i hadn't thought off! Now trying to find information about conrods. Stock is 118mm, so i need 126mm rods with 43mm big end bearings and 18mm small end bearings, but information is really scarce (or i don't know where to look!). Toyota hasn't got anything that fits that size. One from a Honda engine (which i forgot which one) came really close, but was just too long.
Last Edit: Feb 22, 2015 18:42:52 GMT by The Doctor
Feb 22, 2015 23:33:58 GMT
Longer rods have their advantages, but just getting the 1.0 block bored out can be done by any machine shop vs finding rods that may or may not fit.
That is a lovely daily driver. Was trying to find a starlet originally. Bookmarking this thread as would like to do some of the things you're doing.
The Doctor
@thedoctor
Dec 12, 2015 18:06:12 GMT
A stupid, new idea found it's way in to my head lately. Even though my brakes where a great addition to the car, as the stock brakes are poor, i wanted a bit more silly, so i went and bought this: Celica GT-FOUR 4 pot front brakes with 315mm discs. Probably more then i ever need, but i just wanted to see if i can make them fit my car. I wanted to keep the 15" wheels, as i'm not a fan of big wheels on small cars, 15 is the limit, for me, on my car. So today i went into the barn and see if it's even remotely possible old 255mm vs. new 315mm discs: And the calliper goes on as well, i couldn't test the wheel on, as it hits the caliper before it's on the studs, so some spacers have to be bought to get them to fit. So now i'm going to take a hub of my donor car to make them fit my car, i have a rough idea what i have to do to get them on.
Dec 20, 2015 10:20:20 GMT
would some rs19 pads perform alot better then adding all that unsprung weight? you're not trying to stop a 1500kilo car..
The Doctor
@thedoctor
Dec 20, 2015 13:19:51 GMT
probably, but i just want to see if i can make them fit
The Doctor
@thedoctor
Jan 31, 2016 10:03:57 GMT
APK is looming, and I knew the car had some issues which needed to be dealt with before I could go and get it tested. First i changed the tires, as the old ones where way past their best. I love our tiremachine, makes life so much easier! With BIG help from my mate, the hole in the sill got fixed as well, caught it in time, luckily! So now some minor issues left to tackle (leaking exhaust, bulb here and there) and then I can put it in for a test.
Jan 31, 2016 10:29:27 GMT
A quick look on the carillo rods site and Toyota / lexus 1nzFE ONES ARE 43MM 17.9MM . Unsure of the length though . You might have some luck with the dubious? MaxSpeeding ones from ebay .
