hi, i have just treated myself to a 2 tonne engine crane. to be honest it cost me a small fortune, and it wont be used very often- will just sit in the corner of the workshop and dragged out every once in a blue moon!
if anyone does need to use one then mine is avalible for hire- may do someone a good turn!
i was thinking along the lines of £25 for a day, the crane has a set of 4 tonne chains, a balancer/ load leveller, and slings. i also have axel stands and 3 tonne trolley jacks avalible if needed.
a deposit would be required but refunded once the crane is back, and i can deliver and collect as long as you are fairly local. the crane will fold up to fit in a estate car.
I'm in hertfordshire SG11
hope this may be of use to someone.....
thanks, matt
thanks, matt
