71 puch maxi - soldretrowagen1234
@GUEST
you wouldnt regret it dude, The way i look at it is. I'm saving like 100quid a month in fuel bills, near a grand insurance a year, couple of hundred in tax. and getting to ride a bike thats fun And lasts forever... Theres not alot of bikes that can do that for £500
dungbug
'Ooligan!
Sept 1, 2011 13:38:43 GMT
True, the GN is a few glitches at the moment which I'm gradually getting fixed. Agreed on the fuel saving though, I'm spending a 1/4 per month compared to running my last car (which was a 1.1 Cinq) ;D
Fungus
Sept 1, 2011 17:07:29 GMT
Cub looks great, and atleast as a 90 itll have some pull too. Not all chinese bikes are curse word, my mate has a 2008 RMR125 (Suzuki GS125 rep engine), and its been pretty reliable. All that we've had to replace is the voltage regulator. Standard it did 65, and with a re-jet, and £30 Yoshi rep 'silencer' and a few other tweaks, we've had it at 76mph on GPS. Next step is a 26mm carb and a few teeth off the rear sprocket- 80mph easy
@GUEST
Rode it to work for the first time yesterday 30miles round trip, Was fun hopefully doing the same this week but the weather seems to be taking a bit of a turn and i cant find my damn waterproofs Ive done alot of riding around , And about 60miles friday and saturday all on £3.17 worth of fuel And its genuinly putting a smile on my face riding it ;D
@GUEST
QUICK COPY AND PASTE OF MOPARTS CHECKOUT I havnt!!! ordered this lot yet... Just wanted a rough guide on price Dellorto PHBG 19.5mm - Replica DEL124 ∞ €39.50 €39.50 Stage6 Airbox Oval - Black STAI24 ∞ €25.00 €25.00 Top Racing - All Round TOPU29 ∞ €79.00 €79.00 Puch Maxi Bearing Kit - New Type PUCC27 ∞ €32.50 €32.50 Oil Seals - New Type OIL027 ∞ €6.50 €6.50 Puch Maxi Motor Oil - 250ml PUCQ27 ∞ €3.50 €3.50 Kickstarter Spring KICF27 ∞ €4.50 €4.50 Exhaust Nut - M6 - Brass EXHH27 ∞ €0.75 €0.75 Bosch Breaker Points - Extra Heavy BOST28 ∞ €16.95 €16.95 Champion PRO5M Sparkplug Cap CHA582 ∞ €5.00 €5.00 Puch Maxi Engine Bolt and Nut Rebuild Kit PUC127 ∞ €8.50 €8.50 Ceramic Exhaust Baffle - Universal - 22x40cm CERP31 ∞ €4.50 €4.50 Exhaust Gasket - Large + Ring EXHR30 ∞ €1.00 €1.00 Head Gasket - 70cc HEAJ30 ∞ €1.00 €2.00 Kickstarter Gasket KIC330 ∞ €1.75 €1.75 Manifold Inlet Gasket MAN330 ∞ €0.50 €0.50 Topset Gasket Kit - 60cc/70cc TOPM30 ∞ €2.50 €2.50 Side Stand - Chrome - Long SID8Y7N544 ∞ €10.95 €10.95 Swing Arm - Chrome SWIL49 ∞ €38.95 €38.95 EBR Fork - Black - Short EBRW34 ∞ €63.95 €63.95 Heavy Duty Shocks - Black - 300mm HEAL42 ∞ €22.50 €22.50 Handle Bar Mounts - Puch Maxi HANVUG3Y44 ∞ €6.00 €6.00 Original Puch Maxi Seat - Black PUCC41 ∞ €28.50 €28.50 Duo Foldable Footpegs DUOK44 ∞ €9.00 €9.00 - Remove Item Discount: €0.00 Subtotal: €413.80 Total Weight: 14.4Kg Shipping: n/a Tax: €0.00 Basket Total: €413.80 Got a gift certificate or promotional code? Enter Code:
Thats the problem with moparts, you think "oh thats reasonably priced, i'll have that too"
And it all racks up!
dungbug
'Ooligan!
Blimey, might be worth talking to them directly with that list and ask f there's any discount available for bulk buying. ;D They've picked up some business via RR so they might offer some money off if you ask. Did I read somewhere that you fitted a 'performance' air filter to he Puch?
@GUEST
Right the times come to sell this bike. The spacy took its maiden voyage today, and ive been told i need to thin out my projects as somthings gotta give. So its gonna be the puch annoyingly... GOOD BITS*MOT'D TILL APRIL *70CC DMP KIT *GENUINE 17MM BING CARB *The amazing sound of the FUEGO exhaust *NEW BOTTOM END BEARINGS AND SEALS *NEW THREE SHOE CLUTCH WITH LIGHTENED SHOES AND BRACE PLATE *TWIN EXTERNAL CONDENSORS *KEY IGNITION SWITCH AND KILL SWITCH *50CC HEAD FOR HIGHCOMPRESSION (COMES WITH NEW 70CC HEAD) *NEW BRAKE SHOES *NEW CABLES *NEW TYRES *FRESHLY GREASED EVERYTHING *SMALLER REAR SPROCKET *LARGER FRONT SPROCKET *GENUINE SPEEDWAY DISCS ON THE REAR WHEEL (CUT DOWN) *DROPPED BARS SPARES INCLUDED*original removed parts *spare spoked wheels *one front mag with speedodrive *two pedal start engines and one kickstart engine + the one in the bike = 4 engines!! *BRAND NEW GENUINE E50 CASE!!! i was going to use to build kickstart screamer! *spare 70cc highcomp head * 50cc barrel and piston *15mm bing and foam filter *original 14mm bing *original sprockets *tools for removing clutch and mag *loads of other little bits inc new fuel tap, new main jet for repro 17mm bing.... clutches and more... BAD BITS*Doesnt come with brooks saddle (ill try find the one it came with) *Declared sorn *Big end bearing has gone i think.. ^Not a big deal in that you could use a crank from one of the spare engines and have it going again in an hour.. Reason i havnt done this is, If i do... Ill innevatably want to keep it.. ;D So there ya go... Its all there. LOADS OF MONEY spent since ive had it. Comes with all the spares FREE!! Just needs someone to spend an hour swapping a good crank into it. Which i promise you is a a realy realy easy job. For all that id like the TINY SUM OF £250 But feel free to make me an offer... I might accept.
Russ
You have a PM
dungbug
'Ooligan!
Decision made then gent, it's a pity but there come's a time when you have too much & not enough time/space etc. Out of interest, what airfilter have you got on there?
dungbug
'Ooligan!
Ah right, toying with the idea of getting a 'performance' (ue that word loosely) for the GN. Hearing mixed reviews about 'em, some say there make a difference others say they're an 'instant rebore kit' & fug the engine.
@GUEST
For the gn id be supprised if you notice any difference. The valves are quite small on commuter bikes and alot of effort goes into making everything work well together. For example changing the air filter on a c90 actually makes it slower lol.
It wouldnt fug the engine though. Unless your blasting the airfilter with sand all day.
A foam filter would filter very well (appart from when wet) and a mesh filter will filter alot of the curse word but the smaller items may get through... But then they will be so small it wouldnt cause any problems... What ones you looking at for it? Got a link?
@GUEST
Mr puch going to his new home tommorow Gonna miss him....
dungbug
'Ooligan!
A foam filter would filter very well (appart from when wet) and a mesh filter will filter alot of the curse word but the smaller items may get through... But then they will be so small it wouldnt cause any problems... What ones you looking at for it? Got a link? Here's the type I'm looking at; www.patternparts.net/p-Suzuki_GN_125_Power_Air_Filter_%2839mm%29_94_01-4699.aspxI was chatting to a local bike shop & the guy who runs it said that most modern learner legal stuff is restriccted via the air system, i.e the air flow is 'restricted' & added a filter like this allows the engine to get air much faster. I didn't really see how it would make any odds to be honest,
@GUEST
To be fair your GN is old enough that they wouldnt have done that.
It probably isnt restricted at all. Its just a commuter bike so isnt very fast. Small valves, Small carb for efficiency and economy, Same as my 90 realy...
The little 50cc scoots and things are restricted though. But thats more cdi controlled.
That said thats a nice little filter. Cant do it any harm... But cant see it helping either.. Imho.. Appart from making it a little louder when you open it up. ;D
Last Edit: Oct 6, 2011 7:50:53 GMT by retrowagen1234
dungbug
'Ooligan!
To be fair your GN is old enough that they wouldnt have done that. It probably isnt restricted at all. Its just a commuter bike so isnt very fast. Small valves, Small carb for efficiency and economy, Same as my 90 realy... The little 50cc scoots and things are restricted though. But thats more cdi controlled. That said thats a nice little filter. Cant do it any harm... But cant see it helping either.. Imho.. Appart from making it a little louder when you open it up. ;D Yeah, pretty much what I'd summarised. ;D I'll leave it as is, save the money towards getting the full license seems the more preferred option. ;D ;D
@GUEST
haha, I'm trying to do the same dude... Its hard not buying stuff i like... Trying to organise this excelsior atm and get on with that. Might take my mind off other projects for a while Oh and the puch has gone to a new home now... A fellow RR'R so i expect an update will be made at some point.
dungbug
'Ooligan!
Haha, cool. I'm not planning anything on the test front until the better weather kicks in next year, which should give me time to get the theory test out of the way.
