Dez
Club RR Member Number: 34
Feb 22, 2011 23:24:03 GMT
that makes things low ;D I'm my never ending quest to be self sufficient at the art of vehicle modification, ive found myself needing to modify leaf springs quite a bit, hence this totem like offering to the gods of low- its a S.B.S.(scrap bin special!) hence the interesting pierced and tubed box section i used- its a recycled redundant gearbox crossmember i made ages ago. how it works. it holds this- to then do this- so how i can decamber and reverse-eye to my hearts content
chevazon
1939 Chevrolet 2 door coupe, `67 `Zon estate, `87 Ragtop Cavalier, 4 x 800 Drifters,(!) 1500 Drifter
Feb 22, 2011 23:27:36 GMT
Dez - that is an excellent piece of kit and would love to do the front springs on my Chevy but the only problem is the "eyes" are different on both ends so even if I reversed the spring it would stay the same !
Seth
Feb 22, 2011 23:32:08 GMT
I've still got Jonny69's one and was intending to put it into use some time in spring ;D
chevazon
Feb 22, 2011 23:34:11 GMT
Not unless you leave it until later in the year.
Feb 22, 2011 23:41:30 GMT
Awesome work Dez, Might have something for you to tweak for me. It's already parked in your yard
Feb 22, 2011 23:48:19 GMT
This might be against the ethos... but that looks like it could also recamber tired springs to restore ride height (and load carrying ability) Might have to knock one up and try and rescue the mk2 tina's rear end.
chevazon
Feb 22, 2011 23:51:15 GMT
Go for it Andy. You may be able to sort the springs out on the rear of the `Zon.
Feb 22, 2011 23:58:13 GMT
I thought volvo 120s were coil spring
Great work as always Dez ;D I thought volvo 120s were coil spring They are indeed - 5 link back end too.
Last Edit: Feb 23, 2011 0:01:35 GMT by Paul H
chevazon
SOC - correct. I am in a silly mood fuelled by the American Dream (and Jura over crushed ice).
Copey
ha, very cool! full of win! Jura is also a win do love a good scotch!
robbo86
Current Ride: 2018 Volvo V90 D4 , 1983 Rover SD1 Vitesse
Very inventive!!!
I applaud you sir, great work!
Like it. Bet it will take ages to do though, lots of pumps letting down, moving pumping etc.
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
Feb 23, 2011 12:26:27 GMT
but compared to either buying a new set, or paying someone else to do it for you, this method is free
Feb 23, 2011 14:18:06 GMT
awsome just awsome!! so this piece of brilliant machinery can actually decamber leaf springs?
will you be doing a before and after pic and of you using it? would be ace to see
Dez
I've still got Jonny69's one and was intending to put it into use some time in spring ;D but on which car?! i suppose if you cant decide, youll just have to do all of em. ;D
Dez
Awesome work Dez, Might have something for you to tweak for me. It's already parked in your yard ive got bigger plans for that
Dez
Feb 24, 2011 10:01:43 GMT
This might be against the ethos... but that looks like it could also recamber tired springs to restore ride height (and load carrying ability) Might have to knock one up and try and rescue the mk2 tina's rear end. I'm not sure i understand the concept- restore........... ride.............. height?! as in make higher? why would anyone want to do that?! ;D
Dez
Feb 24, 2011 10:14:12 GMT
Like it. Bet it will take ages to do though, lots of pumps letting down, moving pumping etc. not as much as youd think. you take up the slack to the spring with the screw thread on the jack, so you don't actually jack it up that much. then the spring pushes the jack back down a lot of the way when realeased. you don't move the pump, just slide the spring through.
