Hi, I'm in the midst of replacing the 'screen rubber on a split-screen Moggy - has anyone got any tips? I'm sure someone is going to tell me exactly what I'm doing wrong...it's turning out to be a blinkin' nightmare!
Ah - the split screen is reputed to be a swine. I recall an article in a MMOC mag a while ago (I used to be a member as my first car was a Moggy van) - I'll see if I can find it this evening. I'd also recommend looking on the MMOC website and / or asing on their forum
Last Edit: May 2, 2006 11:30:38 GMT by Paul H
What apears to be the problem? I take it your using the string technique.
I think the main problem is the fact that the screen is in two parts, so the rubber isn't really stretched during the fitting. I'm assuming that in the case of a normal screen you put the rubber on and then fit it using the string technique - but with a split screen the rubber is prone to falling off at any point in the process.
