Mar 11, 2012 14:51:52 GMT
Now ready for it's MOT, which will hopefully be sometime this week.
I serviced it yesterday, re-attached all the trim and gave it a wipe down to try to clear some of the crud that's sitting on it.
I used my £2 each Aldi oil filter remover and spark plug wrench which coped admirably given I had to put a breaker bar on the spark plug wrench to get the mout. When the first one went I just about headbutted the radiator as I was practically sitting on it. Glad I changed them though as they looked a bit grotty and slightly worryingly a few had a fair bit of oil on them. Ach, that's to worry about another day. When I fired it back up it sounded pretty healthy (kiss of death).
Still not decided on a colour yet but that'll be the next thing to look at if it passes the mot okay.
Mar 12, 2012 12:52:22 GMT
Good luck with the MOT!
You can't buy happiness but you can buy cars and that's kind of the same thing.
1989 Austin Metro 1994 Harley Davidson hardtail bobber
Mar 13, 2012 22:06:56 GMT
Thanks! It's going in tomorrow. Before it goes in for it's MOT I need to get it out of the lockup. IMG_1888 by cort16, on Flickr IMG_1889 by cort16, on Flickr I had to jack it up on the diff and push it over on the jack to stand any chance of getting it . A 28 point turn and a couple of light impacts with the wall it's out in the fresh air for the first time in a year. Not easy with inches to spare in an auto thats running lump as some time you get no power other times you get too much. IMG_1891 by cort16, on Flickr IMG_1892 by cort16, on Flickr As I said seems to be running a bit lumpy but it maybe just needs an italian tune up given how long it's been sitting. I'll deal with that after tomorrows outcome.
Mar 15, 2012 16:50:44 GMT
So..... How did it go?
Mar 15, 2012 17:12:33 GMT
Failed But just on front brake pads and a rear wheel bearing. Solid as a rock Phew.
Mar 15, 2012 18:30:21 GMT
Awesome news! Not much to do then and you'll be back on the road!
Mar 15, 2012 20:03:26 GMT
After studying the Haynes manual the wheel bearing looks like a right ball ache. I've ordered one off the web so I guess I'll find out how much of a ball ache it actually is when I try to fit it next week. Hows your one coming along Phil?
Apr 13, 2012 21:12:39 GMT
Right after a bit of peeing around it's got an MOT. Yay! Pretty much a year to the day since I took it off the road. The bearing wasn't too bad in the end once I popped the half shaft out. I cut the old bearing off with the grinder then got the garage next door to press the new one on. Because it came out easy I presumed it'd go in alright with a couple of gentle taps. Aye right! I tried to wind it in using the mounting bolts but just ended up bending the mounting plate on the end of the half shaft! I took it out and while giving it a good battering trying to flatten out the bent plate I was looking at the bearing thinking, hmm that outer bit of the bearing wasn't on the half shaft when I took it out. Sure enough the outer bit of the bearing was still in the axle tube. What a flange. I've got to say this greasy stuff isn't as entertaining as the welding and battering bit of metal around. I eventually got the old bit of bearing out and it went in no bother. Next up take it to bits againm, paint it, put it together again thne maybe drive it somewhere. It seems to be running pretty badly. It fires up fine but runs as if there's no choke. It's always done this as the autochoke part of the carbs is disconnected but cleared after a couple of minutes. It doesn't seem to clear now and I don't know why. I've no doubt a good blast up the road will do it no end of good after sittting for so long. Here it is lurking in the carpark. SD1 by cort16, on Flickr In other news I've been using the 740 a fair bit as it's fast and extremely nice to drive (given it's done 271,000 miles). Part of the deal with the car was I had to give the wheels back. I'd obviously not done anything about this so last week set about finding some by going on gumtree and typing in "bmw wheels". Some 17" ones popped up near my work with decent tyres so I went off to look at them. They seemed fine so I handed over 140 quid and headed down the road. I turns out they're quite rare racing dymanics (so I'm told) and I think they look better than the old 18's and come with 2x goodyear and 2x continentals with 5mm tread. 740_1 by cort16, on Flickr The front brake discs on it are totally shagged so I bought new discs and pads for it. I managed to change one side but it took me 3 hours as all the wheel buts and calipers bolts where on unbelievably tight. I had a breaker bar on one of the calliper bolts and was on the bar with my feet off the ground and it still wouldn't go until I wobbled up and down on it. Even then it just squeaked then I had to spend 10 minutes working the bolt off. I went to do the other side and everything came off easily other than one bolt on the caliper. It wouldn't come off and the breaker bar slipped rounding it. Great. I got a loan of those jaggy sockets for rounded bolts so a few of days after changing the wheels I decided to have another go at the bolt but when I went to get the locking wheel nut I couldn't find it, nor could I remember putting it back in the car after changing the wheels. Like a total dimwit I'd left the locking nut in the wheel and had subsequently driven 50-60 miles in the car and it was obviously no longer in one of the wheels. I took a massive huff and went off to do something car related. A few hours later I was walking down the lane to my lockup staring and the ground and cursing the universe for my stupidity when I spotted the locking nut just lieing on the ground all innocent like! How lucky was that! I still couldn't get that caliper bolt of though so I've bought a new bolt from BMW and it's getting its head cut off. That'll teach it.
Jun 22, 2012 12:51:12 GMT
BUMP. Well I've been quietly plodding away with this repainting bumpers and spoilers, fitting a new rear door, re-shaping fibre glass arches and generally fannying around filling, rubbing and priming. So eventually over the last couple of nights it got itself painted. It needs a polish obviously and they're a few annoying dents I've missed but all in all it's good to see it all one colour again. I owe the guy who painted it a massive favour as it was 2 really late nights to get it done. IMG_2040 by cort16, on Flickr IMG_2042 by cort16, on Flickr IMG_2043 by cort16, on Flickr
Jun 22, 2012 12:55:15 GMT
Thats cool. Its going to be years till i get to that stage!
Jun 22, 2012 13:02:21 GMT
Cheers. Yours is going to be like a new car when it's finished though.
I've also got a new bit of BL model range heading my way in a couple of weeks. I really need to get this finished as it needs to go in that garage.
Jun 22, 2012 17:58:25 GMT
Wow he looks really good. So chuffed to see him looking shiny again!
MK2VR6
Mk2 Golf GTi 90 Spec
Jun 22, 2012 18:26:10 GMT
Looks lovely in the blue with those wheels. Love the way the SD1's are showing themselves on here recently!
Jun 30, 2012 20:05:40 GMT
More progress today as I got most of the bits bolted back on. I just need to bolt on the front spoiler and finish and fit the JDM type arches to it. The arches I've got are for an MR2 and the rear ones are pretty much a pefect fit (ish) but I had to cut and re-shape the front ones to fit the wider profile of the arches. My biggest problem is the interior (mainly the door cards), which seem to be uncleanable. I might end up re-painting them with vinyl paint or something if I can't make any progress. In the mean time I've got my eyes on ebay for a couple of replacements. together by cort16, on Flickr
Jun 30, 2012 20:14:52 GMT
What colour door cards do you need?
The Doctor
Club RR Member Number: 48
1984 Rover SD1 2600S The Doctor
@thedoctor
Club Retro Rides Member 48
Jun 30, 2012 20:29:44 GMT
what a nice looking car, I love the wheels on it.
Great job!
Jun 30, 2012 20:32:35 GMT
What colour door cards do you need? It's blue ones. It's the front ones that are the worst if you happen to have any? I want to drive this on the road next weekend as I've got another project on it's way so I might have a couple of late night this week.
Jun 30, 2012 20:40:13 GMT
Looking good! Brilliant work so far.
"You're about as likely to come across a fully functioning old Jag, as you are a taxicab that smells agreeable." - James May
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
1984 Rover SD1 2600S ToolsnTrack
@overdrive
Club Retro Rides Member 134
Jul 15, 2012 10:45:39 GMT
Thats coming on a treat. Please tell me a replacement back box is on the cards? That pea-shooter is not in keeping with the V8 manifesto!
