Frankenhealey
Club RR Member Number: 15
Jul 30, 2010 22:06:08 GMT
You've got to be careful. Some have gone on Ebay for less than £1500 quid but they can hide a multitude of sins. I bought one with a crappy body but only 2600 miles since 1956. They were maintained up to about 2002 but then many have been left to rot. Mine was warranted mechanically sound by someone I trust but even then I currently don't know whether it can cruise on Unleaded or LPG because the exhaust valves are so soft. It's going to be a big learning curve. I've broken three open ended spanners this week that I've been using for 20 years. Half the b@st@rd nuts and bolts are AF and the rest are  It's fun though ;D
Tales of the Volcano Lair hereFrankenSnail - Vulcan Power hereThe Frankenhealey hereThe Goddess Transporter here
Jul 30, 2010 22:29:07 GMT
I`am loveing this, reminds me to get back on mine
Frankenhealey
That's AWESOME. Love the look but showing my total ignorance; what is it?
Jul 31, 2010 12:31:22 GMT
It's an old Ford COE truck. Has it had a roof chop? Looks mean as.
Sven
Jul 31, 2010 20:21:04 GMT
It's definitely had a pretty major chop ...
1969 Chevrolet 4x4 C10 Pickup 1969 VW extended cab pickup (doka) 1980 Volvo 240DL 1995 Mazda Miata MX-5 2007 Toyota FJ Cruiser 2007 Dodge Ram 2500 Cummins Diesel 2011 MK Indy R (building)
Frankenhealey
Jul 31, 2010 20:49:23 GMT
Goddess is looking a bit boring now
Jul 31, 2010 20:57:49 GMT
Theres an old 1980's dennis fire engine near me thats had the rear body removed and a beavertail added, it looks the bizz. Ill have to get some pics if when I can.
1987 Maestro 1.6 HL perkins diesel conversion 1986 Audi 100 Avant 1800cc on LPG 1979 Allegro Series 2 special 4 door 1500cc with vynil roof. IN BITS. HERITAGE ISSUES.
Goddess is looking a bit boring now  Does it help if I tell you I'm still imagining how awesome it's going to look when you finish pulling bits off and start putting bits on?
Boring? I don't think so! . Ive bookmarked this thread to keep up on the progress, Keep at it,
Frankenhealey
She's now a demi-goddess ;D I've had the these spanners 20 years and it took the lousy rusted to hell nuts and bolts on the Goddess to break them   A few shots underneath...... Gearbox and front axle  Transfer box - shaft from gearbox in, shafts to front axle and rear axle and power take-off to pump  Front axle and typical weep on tyre from front axle  Transfer box to back axle and PTO to pump  Another transfer box pic - why?
Frankenhealey
The start of the day and just clearing up the remains of the top-notch lino roof covering. Side view  Rear view  About two hours later with grazed knuckles, a bloody nose (don't ask), bruised kneecap and some extra special cursing  You can start to get the sense of what it might look like now
Frankenhealey
Having a quick look around the cab while on a break I discovered that you can check the oil from the driver's seat  I also thought I'd better expain the heating and ventilation system  Too hot? Open driver's windscreen ;D  Too cold? Adjust opening of engine cover   Then I wondered how the points could be adjusted as the dizzy is very high up on the engine and I noticed this removable metal plate  and there it is the distributor ;D
Frankenhealey
End of the day From behind  Side left to do  I had hoped that the closer I got to the cab that the wood would be getting better- no such luck  Near side is perfect though - Goodwood ;D  ....and finally for this week how can you start a 5 litre engine effortlessly off this army surplus lamp battery?  ....easy with only 6: 1 compression
Love this.Your doing a great job.
Peace,Max signature height = 80px
megzy
great progress
second transfer box is for tunning the water pump
Progress, yay! Someone should take Photoshop off me.
Frankenhealey
They bl00dy well shouldn't ;D That's fantastic!  It will be a bit longer for the beaver-tail and I'm playing around with a possible fibreglass roof with actual corner curves but your picture has really helped with the visualisation. Cheers, Ian
Progress, yay! Someone should take Photoshop off me.  That does look good! They bl00dy well shouldn't ;D That's fantastic!  It will be a bit longer for the beaver-tail and I'm playing around with a possible fibreglass roof with actual corner curves but your picture has really helped with the visualisation. Cheers, Ian Is the AH narrow enough & to be enclosed by the bodysides? If so, imho it would be good to keep more of the Green Goddess silhouette, as this would echo the style of the Ecurie Ecosse Commer.
