valman
Jun 24, 2010 21:37:57 GMT
thank you for the replies people it shouldnt be a problem crushing wise... its got 4mm walls but i will cap it off with 2mm steel aswell for extra safety. i did some measuring today as what will be doable lowering wise: all these numbers are in millimetres and are the distance between the lowest part of listed component to the floor. (my car is likely to be different from yours though but it would work as a ball park figure I'm sure) Diff: 195mm Exhaust: 140mm Catalytic converter: 135mm (lowest point) chhop chop, weld weld :wink: Tank: 227mm sump: 140mm (with guard so add 10mm for standard) Rear damper bolts: 140mm Chassis rails(?): 175mm (bits going towards the leaf springs) this was the distance between the top of tire and the point directly above standing: 83mm Lifted:183mm and pics cz pics r kl that was with the tire still touching the ground - crazy travel! big day tomorrow too so excited thanks all
can u get lowering springs for them mebe u can adapt mk2 golf ones or raise the turrets
1965 Datsun spl 310 1967 MGB roadster 1979 Dodge Spacevan 1983 Citroen LNA 1989 Volvo 760 GLE 1990 Volkswagen Jetta 1990 Nissan Bluebird 1990 Volkswagen LT35 1984 MZ TS125
mat91
can u get lowering springs for them mebe u can adapt mk2 golf ones or raise the turrets on theses its alot easier to drop the strut throe the hub as there just tubes welded in so all you have to do it cut the welds slide it throu and re weld but you have to get both side same lol
The stupid is everywhere
valman
Jun 27, 2010 18:59:42 GMT
hey guys, small update: i passed my test with 3 minors anf have put just under 400 miles on my car since - and only spent 50 odd quid on fuel.. quite impressed! The car rolls way too much while steering but lights up the tires no problem in the dry and also the exhaust snapped just now at the catalytic converter joining... i have never felt such a knob driving through town at 20 in 4th with the sound of just a manifold...
wallopadonkey
stunning grinder! curse word welder!
Jun 27, 2010 19:17:12 GMT
well done on the test fella
now the learning begins lol
1983 mini city e 1985 miny Mayfair 1997 Audi a4 tdi 2003 gsxf 750
mat91
Jun 27, 2010 21:36:36 GMT
400miles on 50quid i wiah i got half that to 50 quid
valman
well not alot happened here - used this for bugjam loads of people saw and pointed "OMG it says LOLVO!!!!! ZOMG!!1!" which is always funny to see :lol: ive put 2300 miles on this since passing (40 days) - i havent used it for the past week as I'm on holiday. clutch is slipping - hoping thats just the cable that needs adjusting as there is alot of play in the clutch pedal - 2 inches almost. and I'm going to get the grinder out when I'm back from russia, going to take 2 coils off then just match the back to whatever drop that gives me - Fcuk comfort!
valman
Aug 11, 2010 19:38:08 GMT
down she goes good sirs! front is done! back should be down tomorrow
valman
Aug 13, 2010 16:08:31 GMT
back still not done, been busy plus lots of rain got some pictures of her as she is now! Lolvo shot : wide rubber - 205/60 Rack! and my favourite shot (you may notice the taped up headlight again - my good friends been at it again to give it a "drift spec YO!" look enjoy
conrad
Here to fix your cabin.......
Aug 13, 2010 21:23:04 GMT
sweet
Aug 14, 2010 14:06:01 GMT
That's some nice rake you've got there. Sliding forward off your seat much when you brake hard?
valman
Aug 14, 2010 16:48:59 GMT
haha yeah that needs adressing just the weathers not been good whenever its sunny I'm always busy hopefully next week will be better, clutch should be done by then too
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
Aug 14, 2010 18:56:40 GMT
Is that a prancing moose sticker I spy?
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
valman
Aug 16, 2010 17:04:02 GMT
indeed, i have a shield type to go on the front too just need to modify it a bit to make it fit properly currently looking at landy shocks to fit to the back to stiffen it up and make the handling even better
valman
ok, few updates - i got landrover dampers for the back: quite a size difference haha fitted them: that didnt go great though, because the standard bushings were somehow made as a one piece the only way i could get them out was via the knife method, that went well. NOT. :lol: so make sure if you are using a knife for soemthing fiddly it has to be one that can lock the blade in place as mine didnt and closed on my finger had the clutch replaced too, bloody brilliant - nothing like a car that accelerates when you want it to didnt get any pictures of that was very dark but heres one of the !ghetto engine support" and then the lolvo was used to get to reading festival (that was bloody epic) the car was full = 5 people + enough camping gear for 4 days each that meant this: the low exhaust didnt help really. the thing scraped on road markings when i changed lane. also this happened: yup deffo need to re-route the exhaust once i take 3 or more inches of the rear height :twisted: nice arch gaps
valman
Sept 8, 2010 23:12:26 GMT
this is what will be tomorrow/friday - curse word clearance issues ill get round it.
Last Edit: Sept 8, 2010 23:13:25 GMT by valman
valman
Sept 11, 2010 6:03:22 GMT
here we are: 3 coils off the front and weld up top and bottom to stop dislocation Stance! just needs a polish repping the sticker crew :lol: the lowness of it all opinions? suggestions? hate? :lol: enjoy
Speedle
Sept 11, 2010 11:00:01 GMT
awesome, love it! Wheels, stance, color! All Epic!
valman
Sept 11, 2010 12:18:31 GMT
thanks glad you like it - really helps keep morale up
conrad
Sept 11, 2010 13:00:32 GMT
that car is win all over, but to use another internet term, exhaust fail! that pea shooter looking backbox must go! love the lowness and volvoness though
