Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
Sept 1, 2010 21:30:37 GMT
Once I got the engine going again there was a leak from the top hose which no amount of clip tightening would solve, on closer inspection I found this......... I had to take the bloody A/C pump off to get at it The stat housing is made of steel so I cut the bad bit off and welded a bit of stainless tube. I forgot to take a pic of it finished (duhh) but you get the idea.
Last Edit: Sept 1, 2010 21:31:31 GMT by Chops
Chops
Sept 1, 2010 22:00:16 GMT
Last Edit: Sept 1, 2010 22:02:15 GMT by Chops
will
Sept 1, 2010 22:26:57 GMT
Lunch break hero build FTW ;D Top pick tickled and writings tickled me, bet that was not a nice find. Hope to see this at RRG '11 then. Bookmarked *Edit - already bookmarked
Last Edit: Sept 1, 2010 22:28:04 GMT by will
Chops
Sept 15, 2010 22:49:31 GMT
Last Edit: Sept 15, 2010 22:53:05 GMT by Chops
Chops
Sept 15, 2010 22:57:07 GMT
The O/S wing isn't quite as bad as the other side but it's gone in much the same areas.................... That's as far as I got lunch time today.
Chops
Sept 19, 2010 23:17:23 GMT
Last Edit: Oct 1, 2010 22:23:53 GMT by Chops
Chops
Oct 14, 2010 23:09:44 GMT
Once the repairs were welded in, I added a bit of retro filler. Brush, tinning flux, grade D lead, bit of hardwood and a blow lamp. First the clean steel is painted with the flux which contains hydrochloric acid to etch the surface. When heated the lead in the flux becomes liquid and has to be quickly wiped away leaving a tinned area for the lead filler to stick to. tinned......... Leaded (not sanded yet) O/S door
Last Edit: Nov 11, 2010 0:49:06 GMT by Chops
Chops
Oct 17, 2010 21:56:41 GMT
Seth
Oct 17, 2010 22:39:21 GMT
What an absolute pain in the butt
10mpg
Club RR Member Number: 204
AR$E! how the hell did that happen? never mind though I know from experience that galss can be a pain to ship but if it's packed right it's not 'to' much bother, and at least it's just a case of find the cheapest supplier and get it shipped not hunting for some elusive mechanical trim part for year after year.. chin up old bean... the cars coming along lovely otherwise!
Oct 18, 2010 19:44:00 GMT
Ah man...... That sucks!!!! But you're hardcore enough to pick yourself up again, don't let it beat you!!!
Don't know if it's any help, but the backwindow partnumber is DB03342 (ad CLN for clear or GTN for a green tint)...
Shiva
Social hand grenade. Does not play well with others.
Oct 18, 2010 20:14:12 GMT
if all else fails with your skills panel it in and cut an oval glass rear window hole , that sucks man!!
yes ,it started badly ,petered off in the middle and the least said about the end the better!!!
Chops
Oct 18, 2010 21:31:06 GMT
AR$E! how the hell did that happen? There was so much rust in the lip that it had pushed the window out about 1/4" so the whole thing was under uneven stress, I disturbed it whilst removing some of the wibblepoo and it spat it's dummy out once my back was turned Don't know if it's any help, but the backwindow partnumber is DB03342 (ad CLN for clear or GTN for a green tint)... Shiva That's a great help thanks BTW how the hell did you know that?
Last Edit: Oct 18, 2010 23:22:10 GMT by Chops
Oct 18, 2010 21:34:11 GMT
Ahh man, that blows goats a hidden problem / weakness in the glass d'ya reckon? If so it's probably better it showed itself now, rather than after it's in shiny paint & hopping! Also - lead, wow! Mad skills dude, don't see that done much! Proper job ;D
Chops
Oct 18, 2010 21:49:15 GMT
Oct 18, 2010 22:46:51 GMT
That's a great help thanks BTW how the hell did you know that? It's my job.... People need parts found for any US car, they ring me... Don't spread the word to much though Hahahahaha!
Chops
Oct 29, 2010 23:48:57 GMT
Oct 30, 2010 16:14:54 GMT
gotta be honest chops you're a demon with a welder !!
300ce lowrider c220 track car c280 youngtimer S320 ...vip no 4 S430 .. 2 x slk 230 500se , E36 amg E 430 E55 amg Ml 320 C43 amg
Chops
Oct 30, 2010 20:39:35 GMT
welder
Epic fabrication skills there mate. Bad news on the screen but at least theres a good chance you can get a replacement.
I'm not completely useless, I can be used as a bad example.
