Chops
Don't touch me I've been somewhere
Club RR Member Number: 36
Nov 15, 2009 23:27:52 GMT
Last Edit: Mar 24, 2011 23:28:07 GMT by Chops
Chops
Nov 15, 2009 23:49:01 GMT
Chops
Nov 15, 2009 23:57:02 GMT
Last Edit: Nov 16, 2009 0:08:25 GMT by Chops
Chops
Blimey. Theres a 4dr one of those in Crawley.
I assume this has same setup as my '69 C body, IE a separate front chassis. Any strengthening to that?
75 Range Rover 2 door 82 Range Rover 4 door 84 Range Rover 4 door 78 Datsun 120Y 2 door 78 Datsun 620 Pickup 81 Datsun Urvan E23 86 Datsun Vanette van 98 Electric Citroen Berlingo 00 Electric Peugeot Partner 02 Electric Citroen Berlingo 04 Berlingo Multispace petrol 07 Land Rover 130 15 Nissan E-NV200 15 Fiat Ducato
Nov 16, 2009 11:25:34 GMT
What a stunner! Also, kudos for working outside in the elements.
Chops
Nov 16, 2009 13:07:28 GMT
Blimey. Theres a 4dr one of those in Crawley. I assume this has same setup as my '69 C body, IE a separate front chassis. Any strengthening to that? Yes exactly the same, leaf rear, tortion front and uni-body constuction. The front is having the same treatment then a mid section of chassis has to fabricated to join the two What a stunner! Also, kudos for working outside in the elements. Cheers, it's working outside that's caused the project to drag on for so long
Last Edit: Nov 16, 2009 13:11:51 GMT by Chops
Nov 16, 2009 16:26:18 GMT
I really like this! Good work.
Nov 16, 2009 16:30:23 GMT
What a stunner! Also, kudos for working outside in the elements. Cheers, it's working outside that's caused the project to drag on for so long I fully sympathise. I'm at the mercy of the weather / daylight with my Benz project too.
will
Nov 16, 2009 17:51:11 GMT
Ooooooooh nice, looks pretty tight on the trailer there, good to see work commencing, shall be keeping an eye on this one.
Nov 16, 2009 19:18:16 GMT
c'mon chops i know you got some more sneaky pics!! ;D
300ce lowrider c220 track car c280 youngtimer S320 ...vip no 4 S430 .. 2 x slk 230 500se , E36 amg E 430 E55 amg Ml 320 C43 amg
rodit
Nov 16, 2009 21:55:32 GMT
Oh come on, get perm to shift all that cheap german tat out his garage and get it up there son. Really nice to see this coming about
Low and slow
Why can't i tune it?
Chops
Nov 16, 2009 23:25:22 GMT
Thanks for the positive comments The leaf springs are getting binned and there's also likely to be a fair bit of twisting force from the hydraulics so the axle needs a few subtle tweeks.......... Axle stripped then trailing-arm mounting plates welded to the old leaf spring mounts. 1/2" thick plate cut to shape and welded on the underside to add a bit of ridgidity and 4"x4"x3/8" angle on top to give more strength and a flat surface to mount the rams. (sorry about the curse word pics)
Chops
The bit with the bolt in the middle is for the Watts linkage 1" square bronze block for a bearing, mounted in the centre arm with rose joints both ends welded in place with stainless tube for link rods and more rose joints The other ends are mounted as high as possible on the near-side and as low as poss on the off-side so the axle has the maximum travel before the linkages lock-out (I'm using 12" rams on the rear) N/S O/S
that's a lotta work!
Chops
Nov 17, 2009 13:54:39 GMT
rodit
Nov 18, 2009 22:25:36 GMT
Blimey Chops, you are seriously going to town on this lad.
You putting a chain bridge on as well? I do remember Filthy bending his Girder axle with one though saying that.
Keep up the good work.
TIDY ;D
Low and slow
Chops
Nov 18, 2009 22:43:18 GMT
You putting a chain bridge on as well? TIDY ;D Yeah thats what all the axle re-enforcement is for ;D You can see the chain anchor point in the middle of the bridge in this pic
Last Edit: Nov 18, 2009 23:12:55 GMT by Chops
Chops
Nov 26, 2009 13:57:30 GMT
rodit
Nov 27, 2009 22:57:45 GMT
Looking good chops, glad to see a chain going on;) Now you look after the bmw so you can give it to me as my house warming present when this is finished, should have about 5 months
Low and slow
