Nov 10, 2005 18:19:41 GMT
For some reason, my reversing lights aren't working properly . It's been an intermittent problem (for the last few days), which will no doubt make it fun to trace. However, all the other lights are fine. Anyone know how easy is it to get at the switch on the gearbox? Also, where would I find the relay for that circuit? I've checked the Haynes manual, and that's no help, beyond a schematic wiring diagram which has no reference to the actual location of many electrial components..... This morning they were working again, and also when I left work, but when I got home, just as I was reversing into a parking space, they cut out :-( There have been no problems using overdrive, so I'm guessing that the gearbox earthing is fine. Any ideas what could be causing this? Cheers!
Nov 10, 2005 18:27:39 GMT
sorry to state the obvious.....take it youve checked the bulb fuse......a fuse went on my car but it only killed one brakelight and the reversing light.....that was after i spent a whole 67p on a new bulb my '79 fez doesnt even have a reversing light
Reversing Lightsrustingdeathtrap
@GUEST
Nov 10, 2005 18:27:41 GMT
Most probably a loose or broken wire, although what can sometimes happen, especially on an older car is the plunger on the reversing light switch wears away on the end so it doesnt get pushed in far enough. You can repair them but it might just be easier to fit a new switch. Theres no relays on a reversing light circuit so thats one less thing to look for.
Nov 10, 2005 18:33:03 GMT
are you having any probs with the other rear lights?have you checked the earths for the lights themselves? if you have then I'm stumped to think of any other possibilities other than the relay or dodgy wires. the rear lights on my old manta 400 rep were like disco lights, cleaned the earths and bulb housings and robert was my mothers brother. may help, may not, hope you get it sorted soon.
Nov 10, 2005 19:05:02 GMT
Cheers guys!
It's not the bulbs, as the problem is intermittent. The rest of the lights are all working fine, as is the overdrive, so I don't think it's an earthing issue either with the light units or with the gearbox itself.
I'm hoping it's just a loose contact somewhere or the relay (there is one according to the wiring diagram) is playing up, as if it's the switch, that will be a pain. It's above the overdrive on the back of the gearbox so basically inaccessible from underneath unless the car is on a lift, and I don't think it can be reached from inside the car either...
Last Edit: Nov 10, 2005 19:05:29 GMT by Paul H
Nathan
Club RR Member Number: 1
Reversing LightsNathan
@bgtmidget7476
Club Retro Rides Member 1
Nov 10, 2005 19:08:27 GMT
I had the same issue with the GT it got so bad that they stopped working for a while, Now they kinda do but After realising they are not Req for your MOT I thought to hell with it, I was spending weekend after weekend Tracing the issue.
Still the same now however I think its the Switch as they are prone to going
Nov 10, 2005 19:13:41 GMT
they are not Req for your MOT Interesting! Do you know if this is not required as in not tested, or not legally required to work? Plan B is probably going to be a buzzer switch on the dash, until such a time as it's convenient to deal with properly.
Nov 10, 2005 19:24:50 GMT
bgt is right don't need one and yours is pre 70 any way
don't worry
it does sound like the switch tho had same prob on goof gti and it was the switch - that was a pain to change too lol
2001 HONDA CT110 (NOT RCV)
Nathan
@bgtmidget7476
Nov 10, 2005 20:52:16 GMT
Well Mine are still Present mate and they never check them. So no need to worry if you cant resolve the issue. I know its always good to have reversing lamps but in my case its just not worth the hassle until I remove the Transmission for a type 9 or something
@GUEST
Nov 10, 2005 21:20:43 GMT
Reversing lights are not an mot requirment on any year of car I just had a thought, it might be worth checking the bulb anyway as sometimes the filament can break and just make ocasional contact causing that intermitantness. (is that a word? ;D)
Last Edit: Nov 10, 2005 21:22:53 GMT by rustingdeathtrap
Nov 10, 2005 21:45:14 GMT
I know what you mean, but both the reversing lights are playing up, not just one :-(
Davenger
It's only metal
Club RR Member Number: 140
Reversing LightsDavenger
@dminifreak
Club Retro Rides Member 140
Nov 10, 2005 22:34:01 GMT
Reversing lights are not an mot requirment on any year of car I beg to differ old chap. They're compulsory after a certain year, can't remember when. They checked them on t'other halfs 85 Mini
RetroMat
Column Shifting!
Nov 10, 2005 22:59:11 GMT
As far as i knew no cars get tested for reverse lights. My Toledos got them wired into a swich on the dash i think reverse lights were a dealer fitted option ;D
Davenger
It's only metal
@dminifreak
Nov 10, 2005 23:01:34 GMT
We used to check them when I worked at an MOT test centre, but that was 8 years ago
The problem is that the Amazon has them built-in to the rear light units (factory fitment), so I can't just disconnect them :-( This morning they were working again
Nathan
@bgtmidget7476
no need to disconnect them just leave as is mate, all will be fine either that or just remove the bulbs Job done for you then
GavinJ
MGB 3.9 v8 Sebring
Club RR Member Number: 209
Reversing LightsGavinJ
@gavinj
Club Retro Rides Member 209
Nov 11, 2005 10:55:00 GMT
My 1989 e30 BMW passed the mot in july with the reversing lights not working, they have not worked since i've had the car!
Davenger
It's only metal
@dminifreak
Nov 11, 2005 14:20:18 GMT
How peculiar. Looked on the VOSN website and it just says the lights are checked, makes no specific mention of reversing lights, but then it doesn't specifically mention brake lights either. I suppose it's up to the discression of the tester now
GavinJ
MGB 3.9 v8 Sebring
@gavinj
Nov 11, 2005 17:30:16 GMT
Yeah that wasn't a back street garage either, it was done by ATS.
