I've read about it being done before...but I've never seen any. Until now: 11" 911 rims! I wonder if the 'band' is cut from billet, or if it's taken from another wheel? I want my Lotus rims taken out to 10" now! Anyone think they can handle it?
Sounds like trouble to me! I don't think alloys would take as well as steels would.......
<Bang> "what was that", "oh, me alloy just split in two"
Or am I mad...
When is slater going to start making us all wide rims? *n
Banded wheels are illeeeeeeegal aren't they?
Reynolds501
Volvos, they're boxy, but good.
Banded wheels are illeeeeeeegal aren't they? Only if you get caught! mind you, when the police find you buried backwards in a ditch, half a wheel on display, I'm sure they'll twig! 'They were on the car when I bought it'...
steels yeah alloys no
2001 HONDA CT110 (NOT RCV)
But it's only welding isn't it? A professional alloy welder must be able to do it surely?
Failing that, I've got some super glue and duct(sp) tape handy!
Peugeot 307sw - Suzuki SV650S - MX5.
I've seen aluminium BMX frames ([reminisce]ah, the PK Ripper[/reminisce]) break on non-weld areas and the same on Chromoly frames too. A good weld is easily as strong as a non-welded piece isn't it? Those Fuchs don't look weak to me? Any engineers care to shed some light?
There's no reason why the welds won't be as strong as the 'base' material. Having said that if the original wheels were heat treated, that will have gone out the window during welding, and there's no way of knowing if the heat-treatment has been re-done after welding.
I think banded steels are safer than banded alloys...
There's no reason why the welds won't be as strong as the 'base' material. Having said that if the original wheels were heat treated, that will have gone out the window during welding, and there's no way of knowing if the heat-treatment has been re-done after welding. I think banded steels are safer than banded alloys... On a similar note any idea if the companies that repair cracked or broken alloys heat treat after repairs.
slater
Club RR Member Number: 78
Banded alloys?slater
@slater
Club Retro Rides Member 78
Cant see a problem if its done properly. Some custom alloys are welded to start with (Ever watched American Hotrod? Their wheels are all welded) Could just convert them to use a split rim outer. Could even have to bolts on the outside so you couldent see them
Could just convert them to use a split rim outer. Like Dimma split-rims (made with original Peugeot centres):
slater
@slater
Yeh that kind of thing. Force racing were doing it to mini wheels at one point.
I was going to do it that way to a set of Exacton mini special rims that i have untill Image stopped making the rims for them (silly-billies, now everyone with 10 or 12" image wheels cant get spare rims ffs!)
oooo nice idea
imagine how dead centre they have to be lined up and i hate to loose half a wheel at 30mph never mind anything more.......ill give it a miss
but i doo like the 911 rims
Oct 10, 2005 13:58:16 GMT
When listing modifications to the insurrance company (when a 'decent/understandable' one is found), the one mod they wont allow is if you state you've got 'banded' wheels.
Oct 10, 2005 14:32:27 GMT
When listing modifications to the insurrance company (when a 'decent/understandable' one is found), the one mod they wont allow is if you state you've got 'banded' wheels. I've recently had to fill in a 'Modified Vehicle Report' (for Adrian Flux), and the section on wheels asks: Presumably this means that they will allow them if they are pukka / professionally made, but won't allow DIY ones??
Last Edit: Oct 10, 2005 14:33:17 GMT by Paul H
Oct 10, 2005 14:47:54 GMT
Just put 'Mi Dad's mate from work' see what they say!
