Sept 22, 2005 18:58:11 GMT
I'm currently working out the spec for the Sprite's new engine, and when it comes to buying the required parts, I have no desire to pay a premium in order to have MG or Austin Healey on the receipt.
What good Mini specialists are there who would be able to supply the necessary bits? I know of Mini Spares, but I'm guessing that some potential parts (like 998 conrods for example) don't need to be new.
Any links / info would be much appreciated! Is there a good Mini specialist / parts place in Bristol? If so that would be ideal as that's where my brother lives (he's a mechanical engineer, so is building the engine for me).
Cheers!
Sept 22, 2005 19:53:45 GMT
Sept 22, 2005 19:58:22 GMT
BigWig
Sept 22, 2005 20:18:15 GMT
if you want a build speak to Bill Richards, Pete Vickers or Raven Racing.
Stay away from Mini sp**d for their in house builds but new parts would be ok, but expect them to f*ck you about on postage, Minispares/sport are reliable though....
Let me know if you want contacts, Bill and Pete are friends of the family, so I know what they are like and Patrick Howe of Raven Racing is a friend of a friend.
Davenger
It's only metal
Club RR Member Number: 140
A Series enginesDavenger
@dminifreak
Club Retro Rides Member 140
Sept 22, 2005 22:54:19 GMT
London mini shop are good too, don't think they have a website though. Anyone got thier number? I personally get most of my stuff from mini spares, mainly because I can shop on line
Last Edit: Sept 22, 2005 22:54:53 GMT by Davenger
A Series enginesDarrenW
@darrenw
Club Retro Rides Member 74
Sept 22, 2005 23:32:34 GMT
When I was into Minis, I got all my bits from MiniSport... I used to love the drive up to Padiham to pick up loads of shiney bits
Sept 23, 2005 7:11:01 GMT
Best place for new Mini parts in Bristol is Moss at the bottom of the M32
Sept 23, 2005 7:33:39 GMT
Thanks guys! I'll have a look through all those.
Sept 23, 2005 7:43:46 GMT
If you need any parts that don't need to be new, give me a shout as I've still got 6 Mini engines in the garage........
Sept 25, 2005 22:47:01 GMT
IRooco - that's very kind of you! I'll let you know when I know - I'm not sure yet what the spec will be, as I haven't checked to see how much more (or not) my insurance company will charge me....
slater
Club RR Member Number: 78
A Series enginesslater
@slater
Club Retro Rides Member 78
Sept 26, 2005 5:51:47 GMT
Ive got parts to build a couple of 1430s, one for you one for me??
Sept 26, 2005 8:42:29 GMT
If you bore the block out +.060", that'll give you the same bore as the 998/1098 motor. this means that you can fit the 12G295 head (a goodie) and use either Cooper 998 or Metro 998 pistons. Combine that with a suitable cam and you should have a good little motor.
Sept 26, 2005 10:44:47 GMT
If you get hold of an A + 998cc from either a late Mini or Metro, and combine this with a 276 cam and a heavily skimmed (I've got the exact info at home) early 1300 Maestro head, you can get around 90bhp.......
Davenger
It's only metal
@dminifreak
Sept 26, 2005 14:44:28 GMT
A+ won't fit, mounting are all wrong. My mate Simon tried it out in his 1275 midget
slater
@slater
Sept 26, 2005 16:23:10 GMT
The blocks and cranks are differant for inline engines
Sept 26, 2005 16:50:22 GMT
Rumour has it though that the Maestro block can be used inline (ie rwd)...
slater
@slater
Sept 26, 2005 21:19:11 GMT
You could be right there, they do use a differant gerabox to metros/minis but ive never relly look into it much
Davenger
It's only metal
@dminifreak
Sept 28, 2005 0:10:07 GMT
Hmm, might be worth a look
If you need any parts that don't need to be new, give me a shout as I've still got 6 Mini engines in the garage........ Are any of them 998s? I'm going to have my 948 bored out to take 998 pistons, and I'm looking for a set of 998 rods as the existing 948 rods are apparently incompatible with the gudgeon pins in the 998 pistons. Cheers!
Oct 17, 2005 10:11:00 GMT
If you need any parts that don't need to be new, give me a shout as I've still got 6 Mini engines in the garage........ Are any of them 998s? I'm going to have my 948 bored out to take 998 pistons, and I'm looking for a set of 998 rods as the existing 948 rods are apparently incompatible with the gudgeon pins in the 998 pistons. Cheers! Quite possibly - I'll take a look tonight and let you know tomorrow.
