Sept 16, 2005 17:41:17 GMT
THe MR2 is about 96k old on a G plate.
What oil would you think would be best? The MOT garage put 10W40 in - is that a little thin do you think?
Sept 16, 2005 19:04:47 GMT
I used to use castrol RS fully synthetic with my 4age engine. Expensive but worth it the way I used to run it. I think that was 10w-40. You are better using a synthetic or semi synthetic with a 4age as mineral oils tend to loose their lubrication in engines running over 6000rpm.
Sept 16, 2005 19:35:44 GMT
i just use 10/40, castrol semi synthetic. change it and the filter about every 3-4k
Davenger
It's only metal
Club RR Member Number: 140
Suggested oil?Davenger
@dminifreak
Club Retro Rides Member 140
Sept 17, 2005 0:30:42 GMT
I use 15w50, but that's in a mini so it's used as engine and gearbox oil
Sept 17, 2005 16:45:27 GMT
I use 15w50, but that's in a mini so it's used as engine and gearbox oil Which 15/50? There aren't many decent ones still available :-(
Sept 19, 2005 9:49:54 GMT
THe MR2 is about 96k old on a G plate. What oil would you think would be best? The MOT garage put 10W40 in - is that a little thin do you think? If its an NA MR2 then you can go 10w-40 semi synthetic or 5w-40 full synthetic as a quality option. If its a turbo, then 5w-40 full synthetic or 10w-50 if it is modified or used on the track. Cheers Guy.
Sept 19, 2005 13:38:27 GMT
Guy the oilman know his stuff!
