Aug 17, 2005 18:02:04 GMT
After seeing a few inspirational rides at RCS, here's my thread of the week - design, using manufacturer parts only, the car your manufacturer of choice should have built - copy and paste my compiled list below and fill it in as you would have the car built... Bodyshell : Engine : Gearbox : Rear axle : Front brakes : Rear brakes : Interior : Seats : Extra gauges : Exterior detailing : Wheels : Anything else : So.... Here's my example Bodyshell : Dolomite Sprint Engine : TR7 2.0 litre slant 4 w/ Triumph P.I. or HS8's Gearbox : 2500 Saloon 4spd w/ J type overdrive Rear axle : Dolomite Sprint w/LSD Front brakes : Stag discs w/twin calipers Rear brakes : Stag drums Interior : Standard Dolomite w/smaller steering wheel Seats : Triumph 2500 leather seats w/headrests Extra gauges : Oil pressure/Oil temp/Water pressure Exterior detailing : Rear spoiler Wheels : Stag alloys Anything else : Sportier looking exhaust. Lower a bit. Bigger chin spoiler Summat like this
Last Edit: Aug 17, 2005 18:03:47 GMT by Lewis
Aug 17, 2005 18:12:43 GMT
For the imp its got to be the twin cam model that was going to compete against the twink cortinas. This would be coupled to the jack knight 5 speed box and LSD. Coupe body shell, or a van with group 4 arches, decked on split cross spokes.
If the twin cam imp ever was it would be an amazing car, seriously quick.
J
Aug 17, 2005 18:13:33 GMT
Bodyshell : mk2 escort 2 door Engine : 2 litre cosworth yb Gearbox : t5 Rear axle : atlas with quaife atb Front brakes : sierra cosworth discs Rear brakes : sierra cosworth discs Interior : ghia spec trim retrimmed in leather with carbon fibre dash insert, replacing the mock wooden one Seats : seirra cosworth leather recaro's Extra gauges : 6 clock capri Exterior detailing : ghia spec, early grille, all red rear clusters, optional bootrack, vinyl roof Wheels : 7.5" 4 spoke rs alloys, with 175/50/13's, polished chrome and black centres Anything else : 3" drop all round, crystal headlights,
a little bit boring, buit id sell my family for one of that spec
edit: changed it to 2 door, imho, id prefer a 2 door (of course)
Aug 17, 2005 18:21:03 GMT
No, that sounds a doozy
Aug 17, 2005 20:26:52 GMT
Bodyshell : Shove-it Saloon Engine : HS 2.3 litre, big carbs, Blydenstein-tuned Gearbox : 4 speed straight-cut with synchro overdrive Rear axle : LSD, 2" track increase Front brakes : 300mm vented discs, 4-pot calipers Rear brakes : 240mm vented discs, 4-pot calipers Interior : Black leather, smaller wheel, Seats : buckets, bench. Extra gauges : Oil temp/pressure, water pressure Exterior detailing : HS striping, Wheels : 7x14" front, 8x14" rear. Alleycats Anything else : HS Front and rear bumper, bonnet and arches. *n
Aug 17, 2005 20:36:37 GMT
This ones easy as i'm building my one already Bodyshell : 1970's Mazda 323 Engine : 10a or 12a from a Mazda RX3 (I'm using a later engine tho') Gearbox : 10a or 12a 4 speed Rear axle : probably rx3 but with the 323 links Front brakes : RX3 Rear brakes : stock or rx3 drums Interior : RX3 Seats : RX3 Extra gauges : 323 SP Exterior detailing : Some nice rotor touches ala the rx4 Wheels : 13" steelies or the standard rx3 alloys Anything else : nope
Aug 17, 2005 21:33:44 GMT
Aug 17, 2005 21:40:38 GMT
"He's not the messiah, he's a very naughty boy!"
Hirst
This avatar is inaccurate, I've never shaved that closely
Aug 17, 2005 21:52:31 GMT
Bodyshell: Pre-facelift Daihatsu Charade Turbo cabriolet Engine: Storia X4 713cc Turbo 120hp Gearbox: Storia 5-speed Rear Axle: 2-way adjustable LSD to go with the 4WD Front brakes: Storia X4 standard Rear brakes: Storia X4 standard Interior: Black Daihatsu Momo wheel (as on newer Move etc.), plain black interior and door cards, cheesy 80's LCD interior Seats: Copen leather buckets with retrimmed standard rears Extra gauges: Cheesy LCD boost gauge in the dash Exterior detailing: Stretched horizontally 80's font outline-only CHARADE across the higher area of bootlid, pinstripe down sides, TURBO 4WD in cheesy italic 80's font on the rear screen Wheels: 13" 80's BBS style spokey wheels Anything Else: Fulltime 4WD, more intensely yellow headlamp bulbs (instead of offwhite), little front lip
Aug 17, 2005 22:27:21 GMT
mk 1 zephyr with ford galaxie under pinnings
2001 HONDA CT110 (NOT RCV)
Aug 17, 2005 22:33:28 GMT
Bodyshell : mk2 escort 2 door Engine : 2 litre cosworth yb Gearbox : t5 Rear axle : atlas with quaife atb Front brakes : sierra cosworth discs Rear brakes : sierra cosworth discs Interior : ghia spec trim retrimmed in leather with carbon fibre dash insert, replacing the mock wooden one Seats : seirra cosworth leather recaro's Extra gauges : 6 clock capri Exterior detailing : ghia spec, early grille, all red rear clusters, optional bootrack, vinyl roof Wheels : 7.5" 4 spoke rs alloys, with 175/50/13's, polished chrome and black centres Anything else : 3" drop all round, crystal headlights, a little bit boring, buit id sell my family for one of that spec edit: changed it to 2 door, imho, id prefer a 2 door (of course) Sorry to be a spoil sport but 13" wheels won't fit over cossie brakes. I found this out the hard way Concept sounds good though!
Reynolds501
Volvos, they're boxy, but good.
Aug 17, 2005 23:15:01 GMT
Bodyshell : Mk1 Marina saloon Engine : NASP T16 on throttle bodies + mappable ECU Gearbox : R380 5spd Rear axle :Jag IRS Front brakes :246mm vents + alloy four pots Rear brakes : 230mm solids + single pot sliding callipers Interior : standard interior retained Seats :front buckets x2, retrimmed to match original interior Extra gauges : oil temp and pressure, capilliary water temp gauge, Elliot tacho Exterior detailing : standard Wheels : standard, fitted with Yoko A539s, original trims retained! Anything else : front suspension converted to adjustable platform coilovers, adjustable platform coilovers replacing rear cart springs, fully polybushed
Ok ok, maybe I missed the point there, as some of the kit I listed wasn't from the BL parts bin, but I got carried away!
The Princess and the Cresta! OMG, they should have built them like that. How cool?!
^Clearly the work of a tortured genius! ;D
Aug 18, 2005 10:07:39 GMT
Bodyshell : Volvo Amazon estate
Engine : A nice big turbo diesel (I like torque) - no idea what Volvo's latest one is
Gearbox : 5 or 6 speed (pref 6) matching to above
Rear axle : Narrowed Volvo 240
Front brakes : Volvo 240
Rear brakes : Volvo 240
Interior : Standard apart from 123GT dashtop and tacho
Seats : later Amazon front seats with front headrests
Extra gauges : Oil pressure, tacho (see interior)
Exterior detailing : early Amazon front panel & grilles, with matching all white indicator / side light clusters.
Wheels : '70s style slot wolfraces, or 240 GLT alloys
Anything else : decent stereo (but all concealed), and of course dark blue paint with red interior!!
Last Edit: Aug 18, 2005 10:09:22 GMT by Paul H
SteB
Aug 18, 2005 10:52:18 GMT
Bodyshell : Golf Rallye Engine : 3.2l 24v V6 - optional HGP Stage2 twin turbo setup available ;D Gearbox : 02J motorsport 6spd sequential Rear axle : Haldex setup Front brakes : 4motion/S3 discs Rear brakes : Golf G60 (standard) Interior : half leather and alcantra Seats : standard leather recaros Exterior detailing : subtle removal of plastic guff and badges, graphite grey paint, chromolux glass Wheels : BBS RS001 Anything else : very very low suspension
Stu
Aug 18, 2005 11:20:29 GMT
Bodyshell : Golf Rallye Engine : 3.2l 24v V6 - optional HGP Stage2 twin turbo setup available ;D Gearbox : 02J motorsport 6spd sequential Rear axle : Haldex setup Front brakes : 4motion/S3 discs Rear brakes : Golf G60 (standard) Interior : half leather and alcantra Seats : standard leather recaros Exterior detailing : subtle removal of plastic guff and badges, graphite grey paint, chromolux glass Wheels : BBS RS001 Anything else : very very low suspension Oh yes, like the sound of this one! I will have a think about mine, probably something similar
Aug 18, 2005 12:27:14 GMT
Mercedes 450 SLC 6.9
sciroccorrado
Scirocco Storm/Corrado Campaign
Aug 18, 2005 13:04:35 GMT
Bodyshell : Scirocco Mk2 Engine : R32 Gearbox : Gemini 6spd Rear axle : Haldex setup Front brakes : Porsche Rear brakes : Porsche Interior : Standard Storm trimmings Seats : R32 Leather items Exterior detailing : Standard Scirocco Storm bodykit Wheels : Zender Monzas Anything else : Standard scirocco, lowered by about 30mm, coilover suspension
www.autoposter.co.ukVW MotorSport Corrado Campaign (Dusty Mauve, Red Leather) | Scirocco Storm (Cosmos Blue, Blue Leather) Passat 20v (Oak Green, black cloth ) | Seat Toledo Mk2 (Green, no longer with Teddy Ronals, but Blue Recaros)
Aug 18, 2005 13:16:57 GMT
Bodyshell : - Lancia Montecarlo Engine : - Alfa 3.0 V6 Gearbox : - mini Rear axle : - Jag IRS Front brakes : - Austin Princess Rear brakes : - Alfa Spider Interior : - ? Seats : - Mk1 RS Turbo Extra gauges : - boost Exterior detailing : - 037 front & rear bumpers Wheels : Alfa SZ Anything else : 6 foot swedish Blonde in pasenger seat
71 Alfa GT 1300 Junior 89 Alfa 75 3.0 V6 Veloce 89 Alfa 75 3.0 V6 America 2015 C220 estate Daily shunter
Aug 18, 2005 13:19:28 GMT
Bodyshell : - Lancia Montecarlo Engine : - Alfa 3.0 V6 Gearbox : - mini Rear axle : - Jag IRS Front brakes : - Austin Princess Rear brakes : - Alfa Spider Interior : - ? Seats : - Mk1 RS Turbo Extra gauges : - boost Exterior detailing : - 037 front & rear bumpers Wheels : Alfa SZ Anything else : 6 foot swedish Blonde in pasenger seat Nice work,.. but wern't they suppose to be from the same manufacturer??
