The time has come.
1x 1984 Mercedes Benz 230CE
In running and driving condition but MOT Failure. If I was prepared to drive illegally I would dive this car any distance. It failed on rust on the NS sill, in the regon of the rear subframe mount and the seat belt mount, a NS rear solid brake pipe and handbrake efficiency.
The top photo shows the car at the begining of this summer, the BRM replicas are now gone. The other photos show the car a couple of weekends back.
The wheel arches a getting a bit grotty, but more about that later. It has four electric windows, all working though one rear needs the switch rocking sometimes to bring it down fully. The interior is pretty tidy, but the drivers seat bolster is worn through.
Its been lowered around 80mm on aftermarket springs with a coil removed - could go lower - just depends how often you want to change driveshafts.
The car had very simmilar welding work carried out for last years MOT (cost in the region of £350) so with the current work doing it should be ok for a bit.
I have a full set of stainless trims, and a set of mexican hat alloys.
Full set of Pictures.
And to perfectly compliment the above:
Non runner, mostly complete, with good body work, bolt off front wings would replace the grotty ones on the other car, good rears would make repair panels when needed. Could be taken whole or stripped and fraged whatever you decide.
I also have a few other bits and bobs + new front shock, handbrake linings, gearbox filter and gasket and fuel filter.
Full set of Spares Car pics.
So all the above for £500
Be cruising this summer in pillarless style
Contact me through here or 07723600441.
Mark.
Mark.
