I have a problem with the petrol cap on the Amazon - the rubber sealing ring is knackered, so it's losing fuel both by evaporation, and also when going around right hand corners (the cap is low down on lh rear 1/4 panel, behind the rear wheel).
I would take it off to sort out a new rubber seal (it appears to be just a flat seal, that could potentially be glued on) but as it's parked in the street in sarf London, I don't fancy leaving it either without a cap, or with an emergency one fitted (current one is a locking cap) for too long!!
Anyone got a decent locking cap with key for an Amazon estate that they can sell, or any ideas as to whether I can repair the old seal?
Cheers
Cheers
