jikovron
mechanical chaos
Aug 20, 2009 22:25:55 GMT
ive had this issue on 2 triumph engines,,,one with knacked valve guides,,,,,and one that had totally knackered valve guides and rings
valve stem seals tend to cause more smoke on overrun when the manifold vacuum is high so will let out a brief blue cloud at gearchanges and a continuous oil cloud if going down hill off the throttle piston rings tend to let oil through under load so will continuously smoke while running if those are buggered
Colonelk
Club RR Member Number: 83
Aug 20, 2009 22:28:32 GMT
balls. Rings then! Best start building up that spare engine ![:D](//storage.proboards.com/forum/images/smiley/grin.png)
bstardchild
Club RR Member Number: 71
Aug 21, 2009 10:50:17 GMT
balls. Rings then! Best start building up that spare engine ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Shopping list Goetz rings - much better than OE and quarter the price Over size throttle body, bored out injector rail holder, decked head and bit of easy home porting on the head - you know who to call for advices ![;)](//storage.proboards.com/forum/images/smiley/wink.png) After all if you are gonna build an engine you might as well get some extra free performance, should help the third gear drifting
Aug 21, 2009 17:07:33 GMT
just a quickie Q regarding your light tints - is it just normal red spray paint you use and how many coats do they need? they look spot on and i wouldnt mind doing the ones on my audi cab
Aug 21, 2009 18:37:52 GMT
I would have thought that the valve stem seals should be ok on that head. The head was a total refurb by a very well respected member of ABS. (the same person also owned an LC with nearly 200k on the clocks!!) The engine block in your car is the original, so i would say it is probably getting a bit tired now with all the abuse that's been thrown at it!!
Colonelk
Colonelk
Craig..... thanks Id completely forgotten about the head!! Do you think he tweaked it at all? as she does go well! BC, don't worry when the time comes Ill be asking you, but funds are too short to even think about it at the moment.
Aug 24, 2009 15:29:42 GMT
Lovin the rear light ![8-)](//storage.proboards.com/forum/images/smiley/cool.png) Was great to see the beast out on track in person! Can't wait to see further progress bozo exhaust? and the paint is it going to stay matt?
Colonelk
Aug 24, 2009 20:04:54 GMT
paint various ideas. Next theme is satin / matt combo. exhaust.... bozo is the correct level of stupidity however this will be legal.
Aug 24, 2009 20:16:15 GMT
thanks colonelk.. i'm going to buy some and give it a go ![:)](//storage.proboards.com/forum/images/smiley/smiley.png)
Aug 26, 2009 18:56:14 GMT
Ok, I will have another guess at the exhaust, you got me interested ;D Will it be twin exit but in the rear quarters or something like that? at higher level? I don't want to guess and ruin the suprise, but I can't help it ![:P](//storage.proboards.com/forum/images/smiley/tongue.png) Lewis
Colonelk
Nov 11, 2009 18:13:48 GMT
hello all, havent updated for a while, and this is a bit of a none update.
Basically been a silly depressed muppet and havent touched my cars or tidied up the yard like Id wanted to in my months of leisure. Oh well!
Anyways, whilst driving along the other day someone suddenly turned the volume up on the senators exhaust. I thought that maybe a weld had cracked or Id warn through the under axle hump. Had it up in the air this afternoon and...... well theres nothing wrong with it! no leaks, no cracks, backbox still has its internals... I'm confused! The only thing thats happened is the tailpipe has fallen off, but surely 4 inchs of pipe cant account for this much volume increase (and general raspyness / poppy-bangy-ness) ?!
Any ideas?
apologies for non-update
Nov 11, 2009 22:55:23 GMT
As long as it sounds better - is it a problem?
Maybe it just decided to get more into character with the car??
Funny enough - losing a short run of tailpipe can have quite an effect on the acoustics, so this may well be the reason. Just enjoy the new soundtrack ;D
megzy
Nov 12, 2009 10:44:28 GMT
yes four inches will make a lot of differance as you ahve the venturi effect or lack of now ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) if u wanna quieten it downa bit weld a ss exhaust trim on it say 4 inch that ll keep the noise just dull it down a bit
Nov 12, 2009 13:17:33 GMT
When I put the bozo style pipe on the Rover it changed the note, even thou it was just a 2 foot lenth of aluminium bodged on the backbox ;D So I guess even loosing a really small amount could change the note. ![:(](//storage.proboards.com/forum/images/smiley/sad.png) can't find any photos of my Rover!
Colonelk
Nov 12, 2009 18:53:19 GMT
Hmmmmm, guess it falling off would tie with the sudden increase..... just seems wierd! Pops and bangs a good'un now though! MM The reason its a problem is due to the fact I was already too loud for a lot of tracks! LOL ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) But yes it does sound nice ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Will dig out my spare tailpipe.
rodit
Nov 14, 2009 18:08:01 GMT
I have a spare inlet manifld here if you want it with injectors the lot in like new, if you can get it to you it's yours to mod as you like.
Also for turbo set up speak to wack at wackyraces.org, owner of the satin black big hp firrenza and a turbo ha van.
Pm me if you want his number. ;D
Low and slow
Why can't i tune it?
Colonelk
Feb 10, 2010 17:43:35 GMT
No worries rodit..... already have a spare inlet manifold. Got loads of spares actually thanks to sootyrides again! Small bump, mainly so I can actually find this thread! jeepers it was well hidden. Sooooo driving a long t'other day, and bwarp became BWARP!! BANG BANG GRRRRR GRGRGRG BWAAAAARP"Ah nuts, so something IS toast on the exhaust then." Drove home, parked it up.... Today.... started it up for a video (see below) of comedy loudness, only for the obvious running problems to show their heads.... looked where I could hear the blow and discovered the problem ![:D](//storage.proboards.com/forum/images/smiley/grin.png) Pretty simple fix! Anyone want to guess whats gone wrong? haha!
Steve
Making progress in small, easy to handle chunks of awesome
Feb 10, 2010 18:53:17 GMT
That aint noisy at all ;D I reckon it was one of the bolts joining one of the front-pipes to centre sections had rattled loose then just fell out.........am i close?
Steve
Colonelk
Feb 10, 2010 19:58:34 GMT
it really is, the video isnt a good exaxple really! re joining bolts...... that wouldnt make it run like a big ball of curse word now though eh? ![:)](//storage.proboards.com/forum/images/smiley/smiley.png) Its related to a bodge I did to get to the gathering
