I've been speaking to the owner of this site www.funksoulkitty.org/ and am trying to persuade her to come along and join here - though she's a little shy. So some encourgament from you lot would probably help......
How can you butt in, if you are invited to join? Nonsense. What a great scirocco, anyway! Lets have some more pics and specs!!!
Hello everyone!
First to clarify, the Arrogant curse word Ale Scirocco in the first pic is not my car....it was one of the Sciroccos at DubWars 2005.
My hot little hunk is still a little rough around the edges in terms of looks....but then again....it is what is in the engine bay that counts ;D
A picture of him when I first got him in '97:
I have no plans for exterior modifications...I think the Mk1 Scirocco is perfect as is....Giugiaro was perfect in his design.....although he will be painted bright blue once I have money again (stupid power lust...).
The engine bay is where all the money was spent:
And a much smaller version of the picture that is TOOO big for this forum....
letsee...specs:
Engine: 1.8T from an '03 Jetta (AWP)...stock internals..(for now ), DTA P8PRO Engine Management (using a wasted spark setup with single coil pack instead of stock coil on plug), Tech Edge WB02, 580cc Injectors
Custom GT30R Turbo (Compressor: GT30R -10, mitsubishi compressor cover Wheel Diameter: inducer size - 2.08, exducer size - 3.00, Trim: 48 Turbine: GT30R turbine wheel, .48 T3 turbine housing Wheel Diameter: inducer size - 2.03, exducer size - 2.22, Trim: 84) with TiAL Wastegate, Bell Intercooler FMIC ATP Exhaust Manifold, Custom Downpipe, Techtonics Tuning 2.5'' exhaust with Borla Muffler
Gearbox Bits: 02J from '03 Jetta (hydraulic clutch and cable shift), Quaife LSD, VR6 228mm Clutch, 16V 100mm drive axles
Suspension: Bilstein shocks, H&R springs, Autotech 25 mm front and 28 mm rear swaybars, Autotech subframe
(more to come.....oh yes...more to come! )
Brakes: Audi 25.4mm Master Cylinder, Audi Dual Piston Calipers, Corrado G60 11'' rotors, Rear Disk Conversion with A3 Calipers, Autotech SS brake lines
...and lots more ;D
I documented every bit of the swap and have uploaded most..okay...um....half of the swap pages onto my website. I am a bit behind on the remaining pages, but I am working on them:
...and um yes...so that is Shocky Jr....my hot little hunk of a '79 Scirocco. Many more things are in the plans for the future...most notably AWD (Haldex, baby...), and secret stuff above and beyond current power and handling levels....
Here is the last video that was made (in March):
My name is Kirsten BTW....a pic of Shocky and I...
(Tim.....you should delete the big image of the engine bay... )
Whoah! Cool! Your 'rocco is SWEET! You're right - the looks are great as they are. I've always had a soft spot for them, shame they're all totally rotten over here
Stick around, your contributions will be most welcome I'm sure
I would have posted pics of that...but I was sternly warned against posting such non-car related items....
(so there, Tim!.... )
;D Thanks! Shocky will one day be a perfect example of a Mk1 Scirocco on the exterior....for now at least...he goes very fast....and handles nicely
Last Edit: Jun 22, 2005 13:42:46 GMT by funksoulkitty
