dubwarrior2
"Open up, its the filth"
I got the rachet, impact gun, spot balster and the nailer. I bought the compressor from Netto about 3 months ago. Very similar except this had a 50ltr tank and was about £49. Anyway, just got to get a hose now. From what I have read so far, I take it that the yellow, coiled jobbies in the Machine mart catalogue aren't up to scratch then and I will need one of the 8mm ones? I mainly want to use the rachet and the impact gun on my splitty.
Bought the impact gun, die grinder and a bottle of air tool oil yesterday, for work... I bought the air ratchet last time they had them. A word of warning, the U/J supplied with the ratchet flew apart the first time I used it... Don't forget you can take the stuff back within 30 days if you're not happy...
... the only injury I sustained was a bumped head when I let the seatbelt of without realizing the car was upside down and that's not really the car's fault.
I bought the impact gun and the die grinder on Thursday and it hasn't stopped raining since so I've yet to test them.
Jaguar S-Type 3.0 SE
starchild
suck/squeeze/bang/blow.
i got the comp,wrench,ratchet,saw i wanted the filter regulator and die grinder too but they sold out.
there must be a dozen comps 30 wrenchs & ratchets left at norwich branch.
I planned to stick the new wheels on the Primera this morning and give the impact gun a try but one of the tyres has some bad cracks on the sidwall so I decided to sort that first. I did give it a go on SWMBO's Volvo wheel nuts and it worked a treat.
I gave the grinder a quick go on a seriously manky old caliper carrier and it was excellent. The stones don't seem very hard wearing though.
Stu_B
Investing in rust!
Just got the compressor & saw - Saw's going back as it's leaking air from the inlet & started to come apart as I was using it.....
Ooops....just got back from Aldi armed with the ratchet,air drill,die grinder and 500w bench drill. I only meant to go get the ratchet
Have now got the air drill and die grinder too.I'm very pleased with all the bits i got.Thanks to the person who started this thread as i would'nt of known about this deal.
Just unpacked and assembled the Compressor etc..... Bloody huge pile of extras you know.
rtlkyuubi
Low and Slow
can anyone give me a link to this pipe thats on machine mart please, I'm hopeless on that site
Just unpacked and assembled the Compressor etc..... Bloody huge pile of extras you know. darn!!! did they all come with the compressor me wants
bigrod
^^^^^^ That's a better slection than I got with my compressor last year! (And I got two sets 'cos I had to return my compressor 'cos it was bust!)
If I have to explain, you won't understand. Maximum signature image height = 80 pixels
is there a way to check if they still got these in stock in my local aldi ?? i am prepared to spare my lunch break for this today on their store locater it wont give you a phone number though
curse word i called the head office in the end the chick on the phone checked it on the system and found it in an aldi 5 miles away from me ,got there and claimed my prize and there was still 7-8 compressors and plenty air tools .
Dez
Club RR Member Number: 34
Thursday's Aldi specialsDez
@dez
Club Retro Rides Member 34
a bit of feedback on the tools.
i bought the reversable 3/8" drill (£10) and the saw, (£23)
i was running them at 110-ish psi from a hulk of a 170L compressor thats considerably older than i am!! i was using 10mm int. dia. hose, about 5 metres of it.
the drill is great, i swapped on a proper connector, liberally oiled it, then gave it a go. even the drill bits that came with it are pretty good, which suprised me as they're usually made of an alloy of toffee and steel. they went straight through 1/8" steel no problems. ive not tried the screwdriver bits yet.
the saw is also ok, when it works it cuts well, but it does get through a lot of air, more than it should do. the trigger is a bit sticky even after a lot of lube. id had to pull the trigger down and then push the end of the blade onto something to get it going. the whole thing generally feels a bit tight/stiff. the best thing is that they use half hacksaw blades, so replacements are cheap/free. hopefully the trigger will free up a bit with use.
Forgive me \Father for I have sinned.... AGAIN !! Went back for this one today. Now need to make a stand for it, or pick a skipped table etc up to make a stand for it. One of those tools , not used every day, but handy when you need it. Wanted one for a long time.
Last Edit: Mar 3, 2008 20:41:42 GMT by kieranv
The compressor package is the same one as i got from Aldi last year, except the tank on mine is yellow. Have been really happy with mine sofar, the only issue i've had with it is the paper/plastic gauge in the air inflator line has come adrift which makes it a bit hard to use i picked up the Reversable Air Wrench and the small Die Grinder kit from Aldi in Selly Oak Birmingham on Saturday and they had a fair amount of stuff still in, including the bandsaws and benchgrinders.. at a guess it's because selly oak is a student slum and most of them aren't into serious airtools
darlington aldi has still got 5 compressors
Last Edit: Mar 4, 2008 14:38:11 GMT by fastdub
SPLIT RIMS ARE FOR WINNERS
Has anybody used the bandsaw much? I am getting fed up of trying to jigsaw through 3mm steel plate /5mm ali and wondered if the bandsaw would be better then my crappy jigsaw (to be fair it does to well considering it was super dooper cheap and 3mm steel is quite hard to cut.)
