Aug 30, 2022 13:16:27 GMT
definitely interested in this, i have a love of them born out of being dragged around steam fairs as a kid. as an adult i like the sound, look and smell and will be following with interest
mungo
Aug 31, 2022 10:52:05 GMT
so , at this point I had no idea on the internals of this engine . It had no compression and made a bit of a rust dry scrapping noise when you turned it . I tried hitting and pulling the the stuck valve but it just opened more and wouldn't close up at all. I decide to pull the head off to have a look . Mucho mankyness rocker shaft out Here's a look into the water hopper. I vacumed about 6 inches on rat poop and seed grain out of there carb and exhaust off...no pics. giant head off Forgot the talk about fastener sizes......everything is Witworth on this engine. I had to borrow a set of spanners and some cool old socket set . Here's the combustion chamber ... lovely . and the block , I squirted a bit of oil in there to see what he rings would do . The bore and the piston top looked great ,which was a bonus . I was half expecting something to be completely knackered ...I had no idea why the thing was put in the shed ...could have been worn out or bust ...or maybe they got electricity!!!
56' bug 2332 +ida's 56' lowlight ghia 72' bus 1600 devon 67' type 3 square - gone 83' gti - gone 90' gti 16v - gone 82' chevette - gone 70' GP1 Beach buggy -gone 78' lightweight landrover 3L v6 -gone 89' gti - gone 83' gti - gone
PHUQ
Aug 31, 2022 11:29:29 GMT
Beyond the mankyness that doesn't look half bad at all
Aug 31, 2022 14:54:58 GMT
engine blocks really were exactly that once upon a time.
Sept 3, 2022 18:06:23 GMT
Looks like great fun, and I am very much enjoying reading all the updates. I am very tempted by something like this but already have too many projects...
mungo
Sept 5, 2022 14:58:26 GMT
A bit of time on the wire wheel had it all cleaned up lovely : The valve springs are not like car springs... they could be compressed with a hammer handle whilst pulling out the little retainer bars that go through slots in the valve (no collets). Once the valve stems were cleaned on a wire wheel they were feeling good and it went back together nicely I got the rocker chamber as clean as I could .....it's not a F1 you know.
mungo
Sept 12, 2022 12:49:29 GMT
The top of the block came up nice (enough) as well Head gaskets are readily available ,there's a choice of copper like the original or a cheap (£8) composite one. It not going to be turbo'd so cheap one it is : The rockers shafts were cleaned up. After I took that pic I cracked loose the adjusters and pulled them out and clean the threads up . Under all the gunge everything is looking in quite good nick really . Head back on and torqued down and rocker shaft back in . Quite a transformation !!! Lubed up and ready to go The rocker assembly is lubed by the brass grease cap on the side of the case that you turn in to force the grease through the shaft and out of holes under the rockers . Compression achieved !!! quite a lot as well !! Carb next , it was in a right state .
mungo
Sept 13, 2022 10:36:09 GMT
no. It looks more like inlet gasket than a head gasket . I can only assume the compression/heat/timing is so low that is doesn't need a "normal" head gasket. I've not heard of any one having running problems with this type, I've seen folks having problems getting the head off when they've had a composite one fitted for a bit ...but hopefully I won't have to do that for a while .
Last Edit: Sept 13, 2022 10:37:04 GMT by mungo
mungo
Nov 11, 2022 13:25:26 GMT
Annoyingly , I didn't take any pics of the carb in bits!! It was all seized solid with crud mostly but all came apart eventually I stripped it right down cleaned it as much as I could and let it soak in evaporust for a night and it came out perfect. Here it is back on the engine ,compare it to the before shots !! It's about as simple as a carb can get, you screw the needle out to start it and in a bit when it runs and right in to stop it . Throttling is taken care of by the governor. Which cleaned up nicely as well: Mine has an extra brass filter/water separator ? which looks nice The only thing left to do was the magneto.
Last Edit: Nov 11, 2022 13:25:53 GMT by mungo
mungo
Nov 17, 2022 13:02:34 GMT
After I had compression and fuel sorted next was spark..it had none . The plug was rusty and super old school so I bought a new one . I could hold the HT lead whilst spinning it over and there was a tiny tickle but curse word all really. Everyone says the mag coils go when they've been sitting for years ...and the condenser. Here's the old coils and condensor : Looks a bit swollen maybe ?? here's the points : I gave them a file and they're good to go . I found a chap on ebay that was doing rewound magneto coils for Lucas RS 1.2 ( which is what I have ) and had to bite the bullet and fork out £70 for a new one ...which was a bit harsh but I got the engine for nothing so I could justify it ...sort of . he had condensers as well and a new HT lead so I got everything I needed. Here's the new gubbins: The little output nipple was in the the wrong place on the new one which got me for a bit , I had to modify the cap to get it to contact. With all that done ...fuel,valves ,plug,spark there was nothing to stop it firing !!!
Frankenhealey
Club RR Member Number: 15
Lister D Stationary Engine Frankenhealey
@frankenhealey
Club Retro Rides Member 15
Nov 17, 2022 15:23:20 GMT
You are inspiring me to do something with mine.
mungo
Nov 25, 2022 12:55:47 GMT
All that was left was to just give it a spin ...and hey presto... it fired on the first try . This vid was legit the second try where it ran for more than a second : That was a proper result . Where a little one showing the mag chain : That how she sits right now , I start it up every could of weeks and watch it for a bit . I've had water in it a couple of times and run it for half an hour to see what happens when it get properly up to temp but it'll run for 5 mins without water and still be barely warm . I need to get something for it to do to give it a bit of load.
jimi
Nov 25, 2022 13:05:30 GMT
Well done, great result 😎
mungo
Feb 13, 2023 15:04:23 GMT
Got a new toy ! Frankenhealey yours is a bit nicer than mine !!! It's a Lister domestic water pump . She's rough but not seized . I think I'll do this one shiny and green and mount it to the trolley. I got it for free from my cool old horder collector uncle ...got a couple of other bits off him too : Who doesn't love a MAMOD traction engine ,an old grease gun and some dinky VW's !!!!
Frankenhealey
@frankenhealey
Feb 13, 2023 15:28:50 GMT
^^^^^^ That is a result
mungo
Mar 22, 2023 13:05:51 GMT
I've done a bunch of work to my lister pump . It wasn't looking too good initially: But it got a bit better once everything started getting cleaned up. I thought the valve plate was going to be destroyed but it's all made of brass, all the rust was from the inside of the top bell bit ( which is about 10mm thick cast iron) I pulled the whole thing completely apart Some of the bolts needed a few day soaking and heat but it all came apart in the end. It all got either blasted or wire bush stripped then rust converted and painted with enamel "mid Brunswick" green(lister green) I did the top hat bit first to test the process Looked good .
mungo
Mar 22, 2023 13:12:10 GMT
I had to cobble a home made puller to get the pulley off the bearings are not in great nick but I'm not going to be relying on it to keep my house dry so it'll do . It might have to pump to and from a bucket for a couple of days if I ever get it to a show ........we'll see . Strangely, absolutely everything is available for these pumps. I needed 2 valve bolts ( brass) and a gasket set . One of valve bolts broke coming out and one was worn nearly all the way through
Last Edit: Mar 22, 2023 18:31:57 GMT by mungo
mungo
Mar 31, 2023 11:27:19 GMT
Long story short...everything got cleaned stripped, rust treatment where needed and painted green. Here's the main body treated,masked and ready for paint : All the bits painted: You can see the rebuilt valve plate and new gasket set . Here's the body in paint : Everything had 3 coats with a day in-between . When it was all dry ( enough) . I finished cleaning up all the internals and started re assembly . The water piston got a new pair of leather cups that were soaked in veg oil prior to fitting . and all together: and finished: On to the old wooden trolley next so I can mount the engine and pump together to run . Annoyingly, I think the pump needs to spin the wrong way to just sit next to the engine...will have to check that and come up with a solution .
Frankenhealey
@frankenhealey
Mar 31, 2023 12:40:06 GMT
On to the old wooden trolley next so I can mount the engine and pump together to run . Annoyingly, I think the pump needs to spin the wrong way to just sit next to the engine...will have to check that and come up with a solution . If you use a round belt you can run the belt in a figure of eight to reverse the drive. You may need to twist the pump slightly out of line with engine so the belt does not rub.
