Sept 5, 2020 13:47:24 GMT
Inspired by hudson66 minivan I thought I’d post my little project on here. I knew of this one about 6 months back but the guy said it owed him too much to leave it go for my price even though I told him where these things go ripe and this one would be no different. We were about £600 adrift and neither would budge. Eventually I won out and he agreed to sell. The car was a runner, but wouldn’t drive due to a non existent clutch and a huge oil leak from the timing cover area. It looked pretty good and was complete so a deal was done. Once it was home I had a prod about and found plenty of filler around the front end which was supported by cardboard(!!!) and some fibreglass filler in the A pillar and a perforated roof corner. I found some 13” Revos and Miglia arches locally and love the look. I know it’s a Cooper but don’t think originality matters on these SPi cars as it’s just badge engineering exercise. A Sprite or Equinox would be no different. This corner is ripe but it’ll come good in time.
Last Edit: Sept 5, 2020 16:42:16 GMT by exuptoy
Sept 5, 2020 13:56:12 GMT
First thing to be sorted was the roof! I found a cut on the bay of flees for £28, while I was waiting for the roof corner repair to arrive it was time to remove the front end after finding a little bit too much cardboard inside the wings! I spent around £850 with Minispares on new Heritage panels and some bits to cure the oil leak which was being worked on around the same time. At this point I was about a week into it. I work offshore so I get 2 weeks to work on things then away for 2 weeks. Ample time for Minispares to organise my delivery of panels. Once the corner piece arrived I unpicked the A pillar piece as I had ordered a new heritage door frame anyway. Not 100% happy with my repair as it has rippled. This will get redone later but for now it’s ok.
Last Edit: Sept 5, 2020 14:13:49 GMT by exuptoy
Sept 5, 2020 14:28:02 GMT
Amidst all this cutting I removed the rad and timing cover and was greeted by this! Copious amounts of RTV after previous attempts to seal the leak had failed. I found the timing cover fixing bolts were all dimpled from overtightening and I also found the front plate bent where an incorrect length bolt was used and jacked the plate off the block thereby bending it so it wasn’t flat. That’d be it then! I used a hammer and dressed back the holes as the cover was no longer available and threw everything into a bucket of citric acid to derust after running a wire wheel over the paint so I could re-paint everything.
Sept 5, 2020 14:57:45 GMT
Last Edit: Sept 5, 2020 15:04:23 GMT by exuptoy
Sept 5, 2020 15:15:33 GMT
Odd to see a cut for that section off a Mini. As most rot there..... Nice project that.
Sept 5, 2020 15:15:40 GMT
When I arrived home all my stuff was waiting but I had a caravan break planned with the wife for a couple of long weekends so I wasn’t expecting huge strides forward. First job was to refit my timing chain setup with all my new bits, I ordered the improved timing cover gasket which is supposed to make a big difference but hedged my bets with a thin smear of blue Hermetite. I struggled to time the engine for some reason as everytime I wound the engine around it always lined up with number 4 not 1 even though I’d made sure to mark the number of links between the teeth when the timing marks were aligned until I found out that Turns out it was right and the Haynes manual had printed it incorrectly. With the 2 dots on the timing wheels facing each other The rotor arm should be pointing to no4! With that sorted it started on the button and it seems like my oil leak is cured. With that sorted I stripped down the rad cowl, more Kurust and etch primer before more satin black and reassembled the rad after polishing the alternator and radiator header tank. I have some silicone hoses to go on yet but that can wait.
Sept 5, 2020 15:17:38 GMT
Odd to see a cut for that section off a Mini. As most rot there..... Nice project that. Cheers pal. I hope I can do it justice. I’m only 4 weeks into it just now but any progress is good progress.
Sept 5, 2020 16:14:22 GMT
Last Edit: Sept 5, 2020 16:21:19 GMT by exuptoy
Sept 5, 2020 16:28:29 GMT
Next I removed the door and welded in a few braces to stop the shell moving when repairing the door frame/step area as that seems to be this shells worse area for rust and loss of strength. Thats pretty much where we are just now, I'm back offshore for a fortnight and planning my work when I get home! I’m not sure what the score is with the door post and if it should be attached in the pic above or even where it should attach! I’ll probably purchase a quarter sill from M-Machine with the 6 flutes as this has cover sills fitted and the sill repair will encompass the floor into the first grove and I can attach it to the new door frame/step once that repair is effected and just be done with it. If anyone here has done these repairs and has pics or even advice then please feel free to comment as any helpful advice would be welcome.
Last Edit: Sept 5, 2020 16:29:32 GMT by exuptoy
Sept 5, 2020 16:40:14 GMT
Sept 18, 2020 8:30:27 GMT
Last Edit: Sept 18, 2020 8:32:28 GMT by exuptoy
elfman
Sept 18, 2020 8:47:33 GMT
I've had Minis for over 45 years and love the little cars to bits, but really annoyed that Austin Rover never did a better job of protecting them from rust,,,they had enough time over the years. I have a friend who has a Mini the same age as yours and has had similar rust problems.. he said there was no paint at all inside the sills or panels !!! madness. Keep up the great work you doing and so glad another one has been saved...
vanpeebles
I am eastbound in pursuit of a white Lamborghini, this is not a recording.
Sept 18, 2020 8:53:45 GMT
Inspired by hudson66 minivan I thought I’d post my little project on here. I knew of this one about 6 months back but the guy said it owed him too much to leave it go for my price even though I told him where these things go ripe and this one would be no different. We were about £600 adrift and neither would budge. Eventually I won out and he agreed to sell. The car was a runner, but wouldn’t drive due to a non existent clutch and a huge oil leak from the timing cover area. It looked pretty good and was complete so a deal was done. Once it was home I had a prod about and found plenty of filler around the front end which was supported by cardboard(!!!) and some fibreglass filler in the A pillar and a perforated roof corner. I found some 13” Revos and Miglia arches locally and love the look. I know it’s a Cooper but don’t think originality matters on these SPi cars as it’s just badge engineering exercise. A Sprite or Equinox would be no different. SPi coopers had more powerful engines with tinkered bits in, different final drive etc and high compression pistons etc. What is the first part of the engine code?
Last Edit: Sept 18, 2020 8:57:59 GMT by vanpeebles
Sept 18, 2020 9:14:34 GMT
I've had Minis for over 45 years and love the little cars to bits, but really annoyed that Austin Rover never did a better job of protecting them from rust,,,they had enough time over the years. I have a friend who has a Mini the same age as yours and has had similar rust problems.. he said there was no paint at all inside the sills or panels !!! madness. Keep up the great work you doing and so glad another one has been saved... You get it with cheap cars no matter what. Because the margins are so slim, you can't afford to shill out that extra £5 for some more body sealant. And the margins on minis were slimmer than most! Still a curse word for us lot down the line though, mind.
Sept 18, 2020 11:48:37 GMT
You are doing a great job here, enjoying the updates thanks. I had a rover mini neon as my first car, then a tuned Rose as my second. Great fun.
elfman
Sept 18, 2020 14:15:21 GMT
Yes they went for wide wheels, wood dashes and fancy trim but not a splash of paint and sealer, Madness. I found the early minis were better...but not a lot. Will watch the build with great interest, keep it up.
Sept 18, 2020 18:37:49 GMT
Cheers guys, was thinking I might have bitten off a bit much by chopping out so much rot but once you see new metal going in and it just feels like I’m doing the right thing. Nice to know there’s some interest on here. Today I got my door on which confirms the frame will fit just fine. Next I removed the hinges and separated them, cleaned them up, cut off the snapped studs, drilled and tapped for 6mm and thread locked in 3 x stainless (one has been drilled too big the the PO), a couple of stainless nylocs mean I’ll be able to remove the door easier next time! Next up I couldn’t put up with the heat distortion in the roof repair so cut it out and following the video on the tube of Fitzee Fabrications showing a trix on butt welding in body cuts I dug out my 30mm Dremel discs, then cutting at 45 degrees to the patch got it on nice and flush. Much happier this time round. Currently extending the roof lip so I can weld it to the gutter once the door frame is in. It’s not pretty! Here’s Fitee’s work. Awesome stuff and never thought of doing it this way before!
Sept 18, 2020 18:41:29 GMT
SPi coopers had more powerful engines with tinkered bits in, different final drive etc and high compression pistons etc. What is the first part of the engine code? Not sure mate. I’ll have a look tomorrow and report back. I just assumed it was 12H as in high Compresson 1275?
vanpeebles
Sept 18, 2020 19:14:34 GMT
SPi coopers had more powerful engines with tinkered bits in, different final drive etc and high compression pistons etc. What is the first part of the engine code? Not sure mate. I’ll have a look tomorrow and report back. I just assumed it was 12H as in high Compresson 1275? I think 12H is just the start code for a 1275. Should be some more numbers and letters after
spacekadett
F*cking take that Hans Brrix!!
Sept 18, 2020 20:20:29 GMT
I’ve just ( well, tail end of lockdown) dug out my spi and made a start as its been kicking around in bits for too long. I don’t envy you with the rust repairs! The extent of the rot seems to be wings, A panels and doorsteps, it was a nice car but it’s had a knock when the previous owner swerved to avoid a pheasant 😢. Yours gives me flashbacks to my old carbed Cooper, that really was triggers broom underneath 😂. Looks like it’s coming along well 🙂
Mechanic's rule #1... If the car works, anything left on the floor after you finished wasn't needed in the first place
