Hi folks just thought id join as this seems a lively site and as i don't have facebook and most other forums are dead these days this seems the place to be Ive a mk3 escort cab nearly ready for the road but like most projects are they ever finished Had several cars and old Fords over the years but always seemed to go back to the cabs Not sure how to get pics on here if anyone can help Cheers Del
Hello welcome aboard. I canโt imagine thereโs many mk3 escort cabโs on the roads now.
1955 Austin A30 1981 Jawa Mustang 1990 Trabant 601 (Tommy) 1989 Trabant 601 2009 Jaguar XF 2012 Toyota AYGO 2018 Scomadi TL
Hello welcome aboard. I canโt imagine thereโs many mk3 escort cabโs on the roads now. Cheers mate, no there is not but this a bit different here is a link for pics photos.app.goo.gl/WURCn18QLNbzDkfS7
11 MAY 1984
Ford Escort Cabriolet Mk3 1.6 EFI Turbo
Bought this as a mk3 someone had put a mk4 on then someone had attempted to return it to a mk3 again which i had to then fix
Near enough every nut ,bolt,bush washer and moving component has been renewed or refurbed cleaned Built to the way i want it
BODYSHELLใ Car has had welding and has been done to a decent standard then welds have been ground back cleaned sealed then painted with submarine paint NEW crossmember NEW inner wings NEW landing panel NEW outer wings NEW scuttle panel NEW front panel NEW bonnet NEW rear lower panel NEW NSR outer wheel arch Mk4 doors with full electrics Mk4 tailgate Drivers floor pan has had 2 small plates not your usual scabby job Chassis legs and sills all good Floors all cleaned and painted with NEW sound deadning and NEW floor bungs fitted Bodywork fully prepped then painted with Ford Frozen white NEW roof tension cable NEW reg plate bumper inserts NEW bumper fitting inserts NEW wiper nuts sleeves and plastic covers NEW custom DMB RS Grey decals Genuine S1 kit with NEW aftermarket caps and NEW aftermarket hard plastic tow cover great fit(NOT FIBREGLASS) NEW white Ford badges NEW OLD STOCK headlights then wrapped in yellow tint NEW Hella Comet 500 yellow spotlights NEW headlight clips NEW indicators and all NEW LED bulbs etc
BRAKES AND SUSPENSIONใ
NEW Apex 30mm lowering springs NEW KYB shocks Front hubs vapour blasted and powder coated fitted with NEW bearings then carrier mounts drilled out to 12mm to fit Re-Con MK3 Mondeo calipers with 15mm spacers NEW sliders paint etc NEW 300mm Focus ST170 discs NEW Mintex Focus ST170 pads NEW flexi hoses and a couple NEW copper brake pipes made to suit NEW track rod ends NEW bottom arms with NEW yellow poly bushes All engine and gearbox mounts clamps etc have been blasted and powder coated along with strut top plates NEW engine mount bushes NEW gearbox mount bushes Front roll bar buffed and painted NEW purple polybushed "U"clamps NEW roll bar 16mm conical washers SPARCO alloy front strut brace
NEW rear arms NEW rear tie bars NEW yellow tie bar poly bushes NEW orange rear top mount poly bushes NEW red rear upper spring poly bushes Rear brakes have been uprated to Sierra Cosworth 2wd disc conversion NEW rear disc conversion plates Rear hubs and spindles stripped and chemically cleaned blasted then painted with expensive high temp paint then cooked in oven for 4 hours NEW rear hub bearings and all re greased etc with NEW hub nuts NEW Solid 2wd cosworth rear drilled and grooved discs NEW MK5 Xr3i/RS2000 Handbrake cable NEW EBC rear pads NEW rear flexis and clips REFURBED 2wd Cosworth Calipers NEW 2wd carriers NEW cosworth slider kit
ENGINE AND RUNNING GEARใ
Rebuilt Fiesta EFI RS TURBO CVH internals unknown but came from a friends newly rebuilt track car and had done around 200 miles then removed from car as they went Zetec i have since added
RM MOTORSPORT ECU OFAB With in MAP SENSOR NEW larger turbo with NEW gaskets spacer plate bolts etc NEW turbo oil feed and NEW custom oil return pipes Ford Puma Linkage conversion Full 3 inch rolled out stainless system
NEW battery and terminals NEW S1 style black intercooler NEW oversized alloy radiator NEW twin fans NEW header tank NEW water temp sensor NEW inline water temp sensor to gauge Thermostat housing blasted and cleaned Blasted and painted EFI charge carrier NEW 8mm Burton Power leads NEW coil pack NEW alternator to starter wiring kit NEW NGK plugs NEW dump valve NEW magnetic sump plug NEW custom cooling and water hoses NEW fan belt NEW oil pressure switch NEW fast road clutch NEW CV joints and gaitors NEW gearbox /shaft seals NEW 340LPH fuel pump NEW EFI fuel tank and new hoses pipes clips etc NEW fuel filter NEW Bosch oil filter Castrol 10/40 oil Granville Red anti freeze Shafts cleaned buffed and painted Millers TRX 75/90 Synth Gearbox oil NEW bonnet stay clips Full MINT EFI loom from H plate hard top extra heavy duty body earths fitted NEW uprated speaker loom NEW heater matrix heater
INTERIORใ
MINT RS 4 Spoke MINT 90 Spec Recaros Seat runners vapour blasted and resprayed and greased Seat bolts blasted and sprayed Flocked dash ,handles and trims and centre console NEW gauges NEW triple gauge holder NEW cig lighter Heated front screen NEW mirror EFI clocks fitted with NEW genuine Ford bulbs and blue LEDS
I used to run my S1RST without the towing eye cover for fear of it being pinched! S1RST probably the best looking Ford ever!!!
A friend of mine used to run s1 rs turbos. His dad was in the drag racing world (friend in question is now a top fuel mechanic). He had about 320bhp in his. This was in the mid 90s. I remember he put his running gear in a cabriolet but took it out after about a week due to chassis flex. Said it was too scary ๐
I used to run my S1RST without the towing eye cover for fear of it being pinched! S1RST probably the best looking Ford ever!!! I will probs take mine off when going anywhere mate keep it by my side like back in the day when folk used to carry about the pull out stereos
A friend of mine used to run s1 rs turbos. His dad was in the drag racing world (friend in question is now a top fuel mechanic). He had about 320bhp in his. This was in the mid 90s. I remember he put his running gear in a cabriolet but took it out after about a week due to chassis flex. Said it was too scary ๐ Thats good power if it was still the cvh my brothers have mk4 estates 1 is a zetec turbo pickup but I'm keeping to my wee 1.6 cvh as i want it to atleast survive a summer haha
Did the mkiii have sill reinforcement like the mkiv?
Sure have the sills are solid on them but still wouldnt like to crash one tho or roll it
A friend of mine used to run s1 rs turbos. His dad was in the drag racing world (friend in question is now a top fuel mechanic). He had about 320bhp in his. This was in the mid 90s. I remember he put his running gear in a cabriolet but took it out after about a week due to chassis flex. Said it was too scary ๐ Thats good power if it was still the cvh my brothers have mk4 estates 1 is a zetec turbo pickup but I'm keeping to my wee 1.6 cvh as i want it to atleast survive a summer haha It was based on the stock block, that's all I know. I remember it went through gearboxes every few hundred miles and a built box didn't last Much more than 2000 miles so he just kept swapping in stock boxes. I also remember it putting a rod through the front of the block once and punched a hole right through the rad and grill ๐ Went through spark plugs very regularly and tyres like no tomorrow. Was used in anger alot ๐ Pretty sure it was in max power at the time. His dad drag raced a 4 pot cortina if I remember right. Family name is Webb, if anyone knows them. Not spoke to him in 25 years!
Hi and welcome to RR Plenty of escort people here, great build I like that Look forward to more updates cheers Danny
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
Thats good power if it was still the cvh my brothers have mk4 estates 1 is a zetec turbo pickup but I'm keeping to my wee 1.6 cvh as i want it to atleast survive a summer haha It was based on the stock block, that's all I know. I remember it went through gearboxes every few hundred miles and a built box didn't last Much more than 2000 miles so he just kept swapping in stock boxes. I also remember it putting a rod through the front of the block once and punched a hole right through the rad and grill ๐ Went through spark plugs very regularly and tyres like no tomorrow. Was used in anger alot ๐ Pretty sure it was in max power at the time. His dad drag raced a 4 pot cortina if I remember right. Family name is Webb, if anyone knows them. Not spoke to him in 25 years! Hahaha aww that gives me the fear like my old ones ive owned non stop troubles and they never had anywhere near that power Ive stuck a rather large turbo on this hopefully doesnt lag much and can still have some fun in it without it popping
Hi and welcome to RR Plenty of escort people here, great build I like that Look forward to more updates cheers Danny Thanks Danny ive been about Ford forums years ago but most have sheeped to FB which i cant stand as its killed most of the forums off but as i mentioned this place seems ideal Del
Nice
