Apr 12, 2022 20:52:02 GMT
Apr 13, 2022 10:04:15 GMT
I've missed this car
Apr 16, 2022 20:33:05 GMT
Time to take the Herald out! Shake down drive. Broke down of course. Luckily it was on a busy intersection for the m25, blocking Easter traffic. No fuel to fuel filter, no fuel to fuel pump, but fuel in the tank (took the sender out to have a look inside). But... I didn't have the reserve tank open. So I was seeing fuel on my gauge but its all in reserve. Moron. A friend came to thd rescue and brought more fuel just in case. Fired up and made it home, although was close to getting too hot. When it died though it was also getting hot, so I thought that was related. There is a ticking noise on idle and on acceleration from engine bay. I've had this before, exhaust manifold leak ffs. I did this job already about 6 months ago, obviously not very effectively. Luckily I have a set of spares. Found a class air fuel analyser I bought off a guy on a triumph forum for about £30 in the garage. Bought it a few years ago then forgot about it. Never tried using it. It works! Seems to have been calibrated. Means I can have some fun doing live afr tuning! [/img] Hard to see the numbers in the pics but it's idling with an afr of about 10.5. I believe 12 is a sweet spot so it's rich. I've the fuel adjustment nuts nearly all the way out. There is a ticking noise. It splutters at 4k rpm like its lean despite being rich at idle. When stationary I can smell exhaust a bit. It's trying to overheat (not quite but I've a massive rad and big fans). All points towards leaky manifold gasket and running lean. An exciting and stressful afternoon, basically sums up this car.
Apr 16, 2022 20:42:37 GMT
12.5 is stinking rich at anything but full chat. 10.5 is drowning.
You want something between 13.5 and 14 at idle. Is that a wideband O2 sensor or a narrowband? Latter is only ant use for detecting stoichiometric(14.7:1)
Nick
Apr 16, 2022 20:52:55 GMT
When I have had similar issues with SU's it has been worn jets, the holes wear, so you raise the jets in an attempt to get a decent idle mixture but then it is weaker at higher loads.
Apr 16, 2022 22:20:08 GMT
12.5 is stinking rich at anything but full chat. 10.5 is drowning. You want something between 13.5 and 14 at idle. Is that a wideband O2 sensor or a narrowband? Latter is only ant use for detecting stoichiometric(14.7:1) Nick Cheers Nick, will aim for 13-14. Its a wideband sensor so should be OK as a guide.
Apr 16, 2022 22:21:52 GMT
When I have had similar issues with SU's it has been worn jets, the holes wear, so you raise the jets in an attempt to get a decent idle mixture but then it is weaker at higher loads. Thanks kevin, yep it's a good point. I replaced the jets recently as I thought it could be a culprit so should be OK.
Apr 16, 2022 22:26:25 GMT
Gasket off. Leaks on the exhaust ports visible, maybe explains ticking. Intake ports don't show anything but I guess they wouldn't really. Don't really want to use sealant next time, awful stuff to clean up. I only have card gaskets, might double up and see if that helps.
The seat belt strapped exhaust was fine for a run down the road but it was obviously a stupid idea as fabric stretches. So made a bracket from a bit of metal I found, painted it orange and off we go! In the poor running, decided to start from the beginning, reset everything and check the timing. It was totally off, no wonder it wasn't happy. It was at about 18degs advanced at idle eeek. Pulled it back to a safe level (6degs for now), adjusted mix and idle and its running better. Will do a colourtune tune up this week. Also changed the carb manifold gaskets, lovely and leak free.
May 23, 2022 13:38:17 GMT
Seems like I'm not allowed to have 2 functioning projects at the same time. The Scirocco gearbox goes boink, but the herald is now running beautifully! Got timing into the right place, did a Colortune on both carbs and they're now looking good with a lovely blue flame. Balanced them and went for a spin. No flat spots, revs freely and has its power back. No overheating even when static for long periods too. So pleased. Still not fully on board with the ride height being higher, but it isn't clonking on tarmac at the slightest bump so it's now usable. Going to take it to a few meets or shows over the next month, maybe ace cafe and one in Bedfordshire in June. A few gratuitous photos for no reason!
First big trip in the Herald, about 130 mile round drip to Bedfordshire classic car meet up. About 3 hours across back roads. Seemed ok at first but the weather was roasting and water temp got a bit high but never into the read. Did result in it getting spluttery and eventually starting to misfire. We made it to the show though, give it a chance to cool down. Great show, every 2 weeks too apparently! www.facebook.com/groups/1741756416104832/ Alfa 6 with dogleg manual. Lovely thing Fiesta with MX5 turbo engine and rear wheel drive (one of a few at the show) Car barely made it back to a friend's house (half way on the journey home). We pulled the plugs and they looked a touch hot, pulled more timing out of it and added a touch more fuel. Temps came down and it behaved much better on the way home. More tuning needed but its progress that it survived. One issue is a wild vibration across the whole car at about 55mph+. Suspect it's the propshaft, which I have had off and been told it's hard to get them back on and still balanced. Not sure what to do about it... Pull it off and fit again maybe. It was fine when I took it off, balls.
check to see if a previous owner has marked the propflange and diff flange ... you might get lucky
Jun 15, 2022 18:46:50 GMT
Still loving this
Jun 29, 2022 15:04:48 GMT
The gearbox started to feel a little stiffer than normal on the recent trip, realised I've never changed or topped up the gearbox oil. Topped it up so hopefully that helps. Lots of leaked oil though, I'm told they all do this but... Checked all the bolts, all the back ones were not tight at all, tightened up. The oily bits. Prop shaft/Uj checking next, see if I can reduce that vibration and drive the car to silverstone on Friday...
Spun the prop round 180degs at the straps and did a test drive, much improved vibration. Still not gone, will try the 2 jubilee clip technique when I get time. But it was ready for silverstone! Drove perfectly there and back (4 hours round trip), fun roads too. Brilliant to be able to enjoy it again.
Ratty Triumph Herald 13 60 peteh1969
@peteh1969
Club Retro Rides Member 107
Have you trebled the value of the car by filling her up with petrol?
Good to see you out using her.
Pete
😂 Can be said of most of my cars I reckon. Expensive fuel cans with wheels
Dec 16, 2022 15:11:48 GMT
Had a few adventures with the herald over the summer, took it to silverstone for motogp which was excellent (and no breakdowns) Made it to a couple of shows including ace cafe Classics Monthly Also took it to a family thing 50 miles away which resulted in awful traffic and a brief breakdown due to hours slow moving traffic. Almost certainly it was an issue with fuel vaporising because of heat so... Installed some plastic nylon spacers between carbs and block. Need another tune, plus I have a, similar spacer for the fuel pump. Then I can do 3 hours in slow traffic! It's starting to feel pretty reliable which is great. Next job is tracking down the vibration in the driveline over 60mph.
Dec 16, 2022 19:41:50 GMT
Good to see it getting used and development happening.
You can’t just fit a spacer to the fuel pump btw…. As the operating arm will then be the wrong shape and it won’t pump! Late Spit 1500s and Dolomites did have spacers and a pump to match but good luck finding the right pump now. I favour and electric pump (Huco) so you can keep the pump and pipes well away from heat sources. Do hit an inertial cut-off switch in the supply Line though.
Nick
Good to see it getting used and development happening. You can’t just fit a spacer to the fuel pump btw…. As the operating arm will then be the wrong shape and it won’t pump! Late Spit 1500s and Dolomites did have spacers and a pump to match but good luck finding the right pump now. I favour and electric pump (Huco) so you can keep the pump and pipes well away from heat sources. Do hit an inertial cut-off switch in the supply Line though. Nick Thanks Nick, I was hoping it would be OK as the spacer is about 2mm-2.5mm but good point I should check. Maybe it won't! Would wrapping all the fuel lines with heat proof tape help you think? Or a waste of time? Electric pump could be a fun project for the winter, will investigate. Cheers!
