totti
Aug 25, 2019 10:37:28 GMT
Hi! Another "Patina" thread from germany.... It's my mates car,he's not so keen with the world wide web....so i will report instead.He's a kind of a "welding god" in german classic car circles....you will see... And there is a lot of welding ahead! We collected the car last year in December ....a 1000km trip to the blackwood forest. It's a very rare Peugeot 203 Camionette from 1952.... There is no way out.....so we make the deal! There was a lot of thumbs up on the way home..... The car went in storage.....till now! In the workshop Removed the seats.... Time to warm up the welder..... There is serious metal work to do.....the car has had a hard life,and bodge repairs are common for this kind of cars....it was the workhorse for the french farmer for it's whole life. Removed the fuel tank....and the sender.You can imagine how the tank looks inside now Even the steering wheel and the indicator/light switch falls apart.... Plan is to get it back on the road next spring.No new paint! Only renew whats broken....tight budget And than drive the car as a daily! What do think? Greet
Last Edit: May 14, 2021 18:21:35 GMT by totti
65 'Ford Taunus 17m 66' Ford Taunus 17m Turnier 73' Ford Taunus 63' Ford Taunus Transit 1250 72'Ford Escort 2000cc 71'Ford Escort 1700 4 door 89'Ford Escort Express 87'Ford Fiesta Diesel 64'Ford Cortina 1500 deluxe 57'Volvo PV 444 Califonia 54'Peugeot 203 Commerciale 2004 Harley Davidson Fat Boy 78'Zündapp ZR 20 88'MZ ETZ 250
Aug 25, 2019 11:54:00 GMT
yes...most definitely. looks great , i remember when it was picked up. I'm in.
Aug 25, 2019 14:31:02 GMT
sehr hübsch in einer altmodischen Weise
Aug 25, 2019 16:05:34 GMT
You are correct 'Rust is not a crime' but it's a pain in the behind - especially when you have to unpick everyone else's bodges from years gone by - that said if no attempt had been made to keep it on the road then it would not be around today to repair in the first place
totti
Hi! More rust!! The chasis-frame is so weak that you have to brace it befor you cut any old metal out. Removed the wood from the load bed.....and the bodge repair on the back from the cabin.... ....pandorra's box is open now...
totti
Aug 31, 2019 10:53:14 GMT
Hi! Opened the chassis-rails from the load bed..... The right one needs a repair ,the left is solid.Both full of rust and mud.... And found housings from insects everywhere....don't know which typ it is Thanks for looking....
Last Edit: Aug 31, 2019 13:05:32 GMT by totti
totti
Sept 8, 2019 15:44:57 GMT
Hi! Removed the sill covers....to find a very rotten inner sill.... Opened a small part where the B-post is.... Cut deeper..... There is no stability left....welded in the first piece of metal! Cheers
Sept 8, 2019 19:50:35 GMT
Wow, and I thought my car was rusty... What are the plans? Original or something different(engine swap)?
totti
Sept 9, 2019 20:00:14 GMT
Wow, and I thought my car was rusty... What are the plans? Original or something different(engine swap)? Plan is to keep the car as it is....no engine swap. Preserve as much as possible..... Greet
totti
Sept 26, 2019 15:55:49 GMT
Guten Abend! On the right side a new piece of metal find it's way into the sill... Outside.... Solid again! Nice paper cover for the rear windows.... Cheers
Sept 26, 2019 17:08:49 GMT
thought airbags were supposed to be in the front?!
Sept 26, 2019 20:24:08 GMT
How cool would this look as a stepside.
Sept 27, 2019 2:48:00 GMT
very brave man!....getting those sills back in shape is no small feat... nice work
JP
totti
Sept 29, 2019 8:29:42 GMT
How cool would this look as a stepside. Look! Isn't it awesome? A 203 UTE.....Australian version...
totti
Sept 29, 2019 8:38:58 GMT
very brave man!....getting those sills back in shape is no small feat... nice work JP Bend the chassis with a jack till the door gaps are ok,than weld in the sill....
Sept 29, 2019 13:51:18 GMT
That pick up is good looker, never seen one of those before!
totti
Hi! Next was the sill on the left side. Cut out the first piece.... Deeper..... Rusted badly...but the right side was far worse... B-post....solid! Closed!Should be solid enough for the next decades! This was a 5 hours job... And it has to be solid again... Thanks for looking!
Last Edit: Oct 11, 2019 8:46:43 GMT by totti
totti
Oct 27, 2019 20:52:29 GMT
Guten abend! The left inner sill is a nightmare.....B-post area... There is nothing good left....so cut out the whole area... Fresh metal! Some primer befor welding into place... The outside of the inner left sill towards the load bed... The pictures are a little bit confusing....you don't know which areas shown....but they are ALL rusty! Not easy to stay with the mojo.....
What a beauty. Interesting, the flange around the rear of the roof and cab sides, ready i assume from new to be mated to a station-wagon rear, or van body? Fascinating to think this was made just seven years after the end of the war. John
totti
What a beauty. Interesting, the flange around the rear of the roof and cab sides, ready i assume from new to be mated to a station-wagon rear, or van body? Fascinating to think this was made just seven years after the end of the war. John Yes,the first ones came on the market 1948.....and they are highly modern at this time! The flange is for the load bed blanket.Station wagons and vans have a different chassis but the same cabin It's a commercial vehicle... and so they have a targetet way to build. For example.Here the front area of the roof:No attemped to hide the seam..... And a look into my garage at home this morning.... Meanwhile at the pick up....fat progress! Welded in the left inner sill.... Primer... And the finished B-post.... Thanks for looking! Cheers
