Feb 16, 2019 10:20:00 GMT
Sittin' here in a hired tuxedo. Wanna see my bacon torpedo?
Feb 16, 2019 22:33:11 GMT
Oops.......!
Unless you’re under say 40, too late was the cry
I misread that a wedding fumes are carcinogenic...
keyring
Club RR Member Number: 47
I think this will be a big shock to a lot of people, I myself had no idea... Will highlight it at work too, we do have LEV, but it’s definitely worth highlighting
As a panel beater of 21 years I can confirm welding fumes are very nasty. It was never really talked about when I did my training and so I never felt the need to wear a respirator when welding. Now I knew at the time welding fumes can’t be good for you but I never knew exactly how dangerous they were. From causing cancer to destroying your nervous system welding fumes are not fun.
In the spring 2011 I was working in a mainstream crash repair bodyshop and was given the job of replacing a boot floor and rear panel in a new fiesta van. About 90% of the floor had to be mig welded in place and so I spent a fare amount of time in the boot welding the floor and breathing in the fumes which were made worse by the galvanised panel and weld through zinc primer.
That evening I was feeling quite rough, a bit like I was coming down with a cold. The following morning I felt very rough and it felt more like flu than a cold and stayed away from work as a result. Two weeks and a trip to the doctors later I returned to work. The diagnosis by the doctor was metal fume fever! Basically I had poisoned myself by breathing in the welding fumes.
Looking back at my apprenticeship I’m amazed this was never mentioned. I now always wear the correct welding respirator when welding or grinding and improved my own knowledge on health and safety in my job. It’s there for a reason. Stay safe people.
Yes galvanised metal fumes actually give you similar symptoms to flu, it's nasty stuff.
As a welder I always took it for a given.I would at least be wearing some sort of filter mask appropriate to the task. If your a pro or you regularly do hours and hours I would bite the bullet and by a decent mask and sir feed system by speedglas or similar. They really make a difference and you are much more comfortable. The masks even flick up to show a clear lens for grinding do you do not have to take it off. Worth every penny.
