Lopez
East Midlands
Thanks all! Next job - dashboard lights. The car is fitted with white dials. Not for boy racer styling reasons, but because it's the cheapest and easiest way of converting MPH clocks to KMH. Obviously doesn't fix the odometer.... so I will look out for a set of MPH clocks in the future but for now this is what I am stuck with. Previous owner fitted blue LED bulbs (the standard bulbs are extremely dull) but I thought they looked horrible. 80's Fords should have green illumination, so 4 2000 MEGAWATT 900SMD LED bulbs later, I was in business. They are also bright enough to be seen in daylight which is nice. I might also repaint the speedo needles. They are supposed to be a sort of dayglo orange and have faded in the sun. They are brittle though, so I might not risk taking them off until I've acquired a RHD clock set. Little bits but I enjoy stuff like this
Lopez
East Midlands
Jan 12, 2019 13:04:05 GMT
Next job. I want to tidy up the engine bay a bit at a time, everything is dull/corroded/rusty as is normal with these things. First I tackled the coil: Typically scabby but fun to tidy up. The inner wing holes are from the air horns it had in France. Some aluminium and black later, along with some new screws and some loom conduit, much better Then the scabby air filter brackets: And after a quick refurb: It's hardly going to trouble the concours boys, but it keeps me occupied. More thrilling tales to follow.
Lopez
East Midlands
Jan 13, 2019 20:41:15 GMT
Today's delights: Dirty milky fuse box cover Clean(er) shiny(ish) fuse box cover Manky distributor Clean distributor (the marks are physical damage to the casing, not surprising after nearly 40 years) Tired wiper motor cover Slightly fresher wiper motor cover Getting there slowly. Cam cover will make a big difference, as will painting the manifold.
Lopez
East Midlands
Jan 19, 2019 16:19:43 GMT
Following a truck on the A46 this week and it had a blowout - the tyre carcass hit me and smashed the grille, cracked the number plate, and the broken grille stabbed through the radiator, so I had to limp to work and get the car recovered. Amazingly there seems to be no other damage. After sourcing a new radiator I decided to do some other stuff while I was changing it over. Fan shroud & motor Intermittent sticky starter which has annoyed me since I got it Replaced with a Transit Connect one, what a difference! Awesome starter compared to the lethargic CVH unit Exhaust manifold I used Stove paint, wanted something a bit more textured really, but it will do New distributor cap Replacement expansion tank decal and painted the cap Refreshed the air inlet Also a new oil cap and a few other bits cleaned up, and of course the new rad. So this is the engine bay a few weeks ago And this is now Not perfect but an improvement!
AB car pix
Car mag' snapper
Jan 19, 2019 16:43:06 GMT
Lovely! Mk3 XRs have always been a favourite of mine. Actually better in LHD as well, no daft crossbar for the brakes!
1979 Chrysler Horizon 1.3 GL 1980 Ford Granada 2.8 Ghia 1985 Ford Sierra 3dr 1985 Ford Escort Mk3 1988 Ford Sierra Sapphire Cosworth 1989 Ford Escort 1.3 Popular 1995 Volvo 960 1996 BMW 525i 1998 BMW 323i 1999 BMW 530d 2003 BMW 530i . www.facebook.com/ABCARPIX
Lopez
East Midlands
Jan 19, 2019 17:31:28 GMT
The brakes are honestly on another level compared to a RHD Mk3, the pedal feel is superb.
Lopez
East Midlands
Feb 24, 2019 15:14:05 GMT
Overdue update! The Escort has been doing well, here are the latest changes: Off with the RS1600i splitter which was looking very sorry for itself Off with the rear wheel spats which were in a similar state Car looks very basic and naked without them Repainted with K2 Bumper Structure paint, which restores the spark eroded finish of the original parts Plastics back on, replacement grille, pressed number plate to replace the broken plastic one, and some Hella Comet 500 lamps to replace the dinky Ring ones. Still sitting low as the brackets are on the bumper rather than in the proper location. Just can't justify the cost of Carellos! I've also replaced the front springs (rears ready to go on too), fitted poly ARB bushes and poly top mounts. Next - cam cover.
Feb 24, 2019 16:37:44 GMT
I like what's going on here. I admit that I did't used to like XR3s (in the days when every mammary gland on the road used to have one!) but I'm changing my mind now. Bad luck with the lorry tyre but it could have been a lot worse.
Lopez
East Midlands
Just a little update but one I think that makes a big difference. Last two big bits of the engine bay were the cambelt cover and the cam cover. Cambelt cover - all scratched and scuffed. No pics but this was sanded smooth, painted with plastic painted and new graphics applied: Cam cover old vs new - the new one is actually different, it's missing the bracket to hold the airbox but the airbox is well held on without it. All fitted - along with a new later type rubber gasket, stainless bolts and load spreaders. Makes the engine bay look much much smarter I think.
Lopez
East Midlands
Mar 23, 2019 22:39:26 GMT
The rear bumper on the Escort was starting to get on my nerves. 1) The overriders are in really poor condition and crumbling apart 2) The plastic sections are worn smooth and marked 3) The bumper metal is distorted and flared at the ends, making the plastic end caps not fit properly 4) The bumper was not painted at the same time as the rest of the car, and the colour is way off and the finish dull in comparison to the rest of the car. Here is the bumper "before" - a picture hides a thousand sins, but hopefully you can see the poor fit of the end caps and the dull finish So I popped the bumper off Removed the rotten overriders and plastic end caps and crash pads. Spent what felt like forever bending and hammering the bumper into some sort of shape. Sanded and primed with some high build celly Painted the end caps, crash pad and number plate lamps with K2 black plastic structure paint Painted the bumper metal with some Halfords Sunburst red (an alright match, not perfect) Lacquered with Tetrosyl Trade Gloss (BRILLIANT aerosol lacquer, best aerosols I've ever used - comes out like a spray gun finish) Reassembled and refitted with warm white LED number plate bulbs Really really happy with the finish considering this is a DIY job. Annoyingly the pictures don't make it look much different, but in the flesh it's a big transformation. The overriders will probably make a reappearance once I've restored them to a satisfactory finish.
JasonB
Mar 29, 2019 12:45:25 GMT
Top job! I also have a soft spot for these from back in the day. Had a sunburst red supersport fiesta instead as these were just too pricey. Recently bought a good mark 1 fiesta shell for a copy of my old supersport so appreciate the info on the k2 bumper paint. Hopefully it can turn around the scruffy arch & spoiler set I've bought. Always prefer to use something after a recommendation. Agree with the tetrosyl lacquer comment and would add that their primers are pretty good from a rattle can too. What's next on the job list.
1977 Kawasaki Z650 1983 Ford Fiesta (Project) 1985 Kawasaki GPz900R 1993 Toyota MR2 Turbo
Lopez
East Midlands
Mar 30, 2019 19:01:17 GMT
The K2 stuff is really good. The nozzles are a bit ropey, I find they gum up after a very short time so I swap them with Tetrosyl ones, makes a massive difference!
Next on the job list is front bumper to match the back. It's in much worse shape unfortunately.
keyring
Club RR Member Number: 47
1982 Ford Escort XR3keyring
@keyring
Club Retro Rides Member 47
Mar 30, 2019 21:41:37 GMT
Loving the work you’re doing to this! It always looked an amazing example, but the tidying up you’re doing to it and the little touches are making it an extremely nice and awesome car! There won’t be many left in this condition...
you are doing a great job with this car, keep it up all the small details make a car
Lopez
East Midlands
Apr 14, 2019 18:34:05 GMT
With the rear bumper done, it was time to look at the front. Took it off, prised off the end caps, removed the crumbling overriders, and popped out the crash pads. This gives you an idea of the general condition of the plastics: Everything was cleaned, scuffed up, and coated with K2 Structure Paint (I might as well buy shares in this company) The bumper, which initially looked alright, was trashed. Rust everywhere, bent out of shape, fit for the bin to be honest but I haven't got £80 knocking about for a new one. I started attacking it with a variety of tools - hammers, grinders, DA sander, rust converter, Hydrate80, all sorts: More grinding, filling, sanding, filling, sanding: Finally it was ready for primer. First some grey high build - then some Tetrosyl Red Oxide (you are supposed to use red primer for Sunburst Red paint) While I was at it, I soaked the rusty brackets in a citric acid solution and did them in black. I know they aren't the proper Ford brackets but they were already fitted when I got the car: Followed by a good few coats of Sunburst Red (not the best match to be honest) and then a few coats of Tetrosyl Clear. It isn't perfect, but it will do me: And back on the car with the recoated end caps: Although the colour match looks good here, it isn't really. It's no worse than it was though, and the finish is now a lot better than the original bumpers. Overall, happy with the result, even if in the pics it looks basically just like it did before!
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
1982 Ford Escort XR3retrolegends
@retrolegends
Club Retro Rides Member 94
Apr 14, 2019 22:25:30 GMT
I’ll keep an eye out for this cruising around the Shire, good work.👍
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Apr 15, 2019 10:39:21 GMT
cant tell the colour differences from the photos tbh. i think you can get away with it anyway, due to being separate panel with shadow gaps
1982 Ford Escort XR3Mercdan68
@forddan68
Club Retro Rides Member 68
Apr 15, 2019 17:17:07 GMT
Nice job on the bumpers , lovely clean motor
Fraud owners club member 2003 W211 Mercedes E class 1989 Sierra sapphire 1998 ex bt fiesta van
Lopez
East Midlands
Apr 19, 2019 19:42:54 GMT
cant tell the colour differences from the photos tbh. i think you can get away with it anyway, due to being separate panel with shadow gaps Yeah, big black spoiler below it helps too! RS1600i splitter went back on today. I also have a brand new headlamp coming for the driver's side (mine is a bit tarnished inside) and new indicators which will be fitted at the same time.
Last Edit: Oct 10, 2019 20:48:56 GMT by Lopez
1982 Ford Escort XR3fr€$h&m1nt¥
@freshandminty
Club Retro Rides Member 99
Great car to start with but the little tidying jobs have been spot on, especially with before and after photos to highlight them.
