Aug 28, 2018 20:18:01 GMT
So the Retro look Stanced Mk6 Transit went off to its new owner yesterday and buy the evening I'd brought this.! It's basically running an 1800cc Fiat twin cam engine and 5 speed gearbox. front end is custom independent A arm setup with coilovers, princess 4 pot callipers. Rear axle is a Triumph Dolomite Sprint, with adjustable coil overs and 4 bar setup. In general it's all there. Just needs tidying up and finishing off.. Well happy with it and share it with you as I go. Plan is.. Drop down more in hight, banded steels with chrome caps.. I'll grab some more photos at some point.
Last Edit: Jan 25, 2019 12:50:08 GMT by petetong
1958 Ford 100e Fiat Twin Cam Mercdan68
@forddan68
Club Retro Rides Member 68
Aug 28, 2018 20:30:52 GMT
Thatβs lovely , nice plans too, keep the updates coming chap
Carlosfandango.
Now with added Suffix B Range Rover classic - another bucket list car acquired.
Aug 28, 2018 21:38:45 GMT
Wow, love it. The wheels are smart that are on it (I'm fond of the black / silver rim look) but the steelies will be awesome. Looking forward to updates and loads more pictures!
CFD
1966 Fiat 1500 fast road/race conversion 1967 Porsche 912 1968 Fiat 124 Spider 1973 Range Rover Suffix B 1993 Series one Discovery 200TDI 1997 Jaguar XJ6 3.2 sport 2001 P38 Range Rover 2.5 TD Brace of Triumph bikes
tristanh
Routinely bewildered
Aug 28, 2018 23:03:58 GMT
Best of the 8v Fiat twincams. Some of the later Regata heads had huge valves as standard, pretty much everything swaps between 1.6, 1.8 and 2.0 apart from rods and crank.
Looks pretty near perfect as it is to me.
qwerty
Club RR Member Number: 52
1958 Ford 100e Fiat Twin Cam qwerty
@qwerty
Club Retro Rides Member 52
Love it! When was it built? Early 90s? Seems very period.
Tom
Aug 29, 2018 11:26:49 GMT
yes yes yes yes yes.....approval from porthleven. did you find it locally?
(transit...what transit??)
Aug 29, 2018 18:25:19 GMT
please tell me you will be loosing the under-bonnet pebble dash?!! ;-)
Aug 29, 2018 20:45:49 GMT
please tell me you will be loosing the under-bonnet pebble dash?!! ;-) Local ish.. St Austal way. And yes.. The under bonnet will be on the today list
c'mon tongy...where's more pics??!!
good job i'm not a betting man , i would have lost my shirt on the transit replacement being fwd from the 80's with a blue oval...or a really obscure choice of van for another conversion.
Sept 2, 2018 20:53:21 GMT
c'mon tongy...where's more pics??!! good job i'm not a betting man , i would have lost my shirt on the transit replacement being fwd from the 80's with a blue oval...or a really obscure choice of van for another conversion. Nearly did you with a nice mk3 π But been there, done that.. So thought I'd go proper retro Anyway.. It's in its new home, and I've started checking it over. Really interesting front end setup. Rear 5 link. Princess 4 pot calipers, 9"rear drums.. It's definitely going to stop Coilover mounts need modifying so it can go lower. But I'll add more photos as I go
Sept 2, 2018 20:57:33 GMT
nice one... looks solid and like its had plenty of time put into it. always room for improvement though , definitely a sump guard by the look of it , especially if its going lower!
retrolegends
Winging it.....Since 1971.
Club RR Member Number: 94
1958 Ford 100e Fiat Twin Cam retrolegends
@retrolegends
Club Retro Rides Member 94
Sept 2, 2018 21:06:03 GMT
Veeeeerrry Nice!! Looks good on those Revolutions. More pics please. ππ»
1974 Hillman Avenger 1500DL1992 Volvo 240SE1975 Datsun Cherry 100a flying custard1965 Hillman SuperMinx Rock N Roller1974 Austin Allegrat Mk1 1.3SDL1980 Austin Allegro Mk3 1.3L1982 Austin Allegro Mk3 on banded steels2003 Saab 9-3 Convertible 220bhp TurboNutter1966 Morris Minor 1000 (Doris) 2019 Abarth 595C Turismo (not retro but awesome fun) www.facebook.com/DatsunCherry100a
Nice 107E - My first car was a 998cc 107E and my first car mod was to put an oil gauge on it.....the copper tube transmitted engine noise into the cabin and the very small needle movement confirmed that the engine oil light coming on was correct - the engine was knackered! Still a rebuilt spare engine with a GT camshaft and ported head made it go better. A home made tubular exhaust system made it sound better. The vacuum wipers were a nightmare and somebody ran into the rear wheel arch. I then sold it to buy my first Frogeye Sprite.
Sept 6, 2018 14:49:06 GMT
Bit of a progress report. Lesson number one. Trust your instinct π€ Very small knock on tick over which I put down to just a valve train knock.. But wasn't happy with it. So bit more investigation (with my " acoustic stick" π) and I put it to a bottom end knock around the number 2 cylinder.. But more mid range, middle of the block around the fuel pump area /blank??! Bit of digging on the good old tinterweb revealed that a common issue on the twin cam is an incorrectly timed auxiliary drive shaft, meaning the fuel pump lobe will catch the number 2 con rod as it rotatesπ³ not good.. But look at the timing marks,(painted on marks by original owner ) all seemed good. But gut instinct was to pull out the shaft and check.. Just as well I did. Turns out it had been timed up using the wrong timing hole, meaning indeed there was contact between conrod and auxiliary cam lobe π So well know mod, that I'm able to do because it's running an electric fuel pump, and all should be well again π You can see the mark on the cam lobe!! So cut it off, drill and tap the hole to maintain oil pressure. Loc tight a bolt in (forgot to take photo!) and jobs a good un π I'm going to enjoy this project βοΈ
Sept 6, 2018 21:04:07 GMT
It was such a FIAT engine that I had rebuilt and wedged into my MG Midget that taught me about interference engines.The hard way! Was a brilliant swap once I got past four bent valves and a few other teething issues.
Your car should be a lot of fun.
Last Edit: Sept 6, 2018 21:06:15 GMT by bjornagn
lightyearman
GYJDM - Grimsby based Japanese car club - Find us on Facebook
Sept 6, 2018 21:57:55 GMT
That project looks cracking mate. When you get chance can we have a load of pictures pretty please!?
'89 Honda CRX siR Glassroof Flint black fully restored track beasty '90 Nissan S13 Pignose - pass the mig wire '86 Mini - matt orange, 13" Wellers, Project 2018 '97 LDV Convoy home built camper/tramper van '04 Saab 9-5 Aero HOT. Anyone want it? '91 Honda VFR400 NC30 17,000 km from new '87 Honda XR80 4 stroke baby crosser '03 Mini Cooper S - honestly, they are fun... '15 VW T5.1 LWB daily brick
Sept 6, 2018 22:15:54 GMT
Thats been very nicely done inside and out, I look forward to seeing it on the steels.
Carry on as you were.
