May 16, 2019 17:15:29 GMT
So had it running on the bike carbs,eventually! After lots of messing about that is !! But it went well,ish! but sounded great..till they carbs popped of the silicon hoses😔 So I'm going to re design the inlet again and bolt them back on at a later date. So for now the twin webber is back on it.. Most recent photos I have of it. Enjoy
May 16, 2019 18:42:20 GMT
great shot pete.. bet it sounded sweet on the carbs! any plans for a front bumper (or 1/4's)? just looks a little odd with one on the tail but not the nose.
1958 Ford 100e Fiat Twin Cam peteh1969
@peteh1969
Club Retro Rides Member 107
May 16, 2019 19:09:52 GMT
Have you been to any car meets at shopping centres as I'm sure I have seen it in a youtube vid run buy a kid in a BMW maxi mini thing.
May 16, 2019 22:05:11 GMT
great shot pete.. bet it sounded sweet on the carbs! any plans for a front bumper (or 1/4's)? just looks a little odd with one on the tail but not the nose. Not sure yet. I've got a couple of front bumpers with a plan to make a pair of 1/4 bumpers for it. But not sure if I will yet 🤔
May 16, 2019 22:06:23 GMT
Have you been to any car meets at shopping centres as I'm sure I have seen it in a youtube vid run buy a kid in a BMW maxi mini thing. Nope. Been out and about in it. But not any meets.. Tesco's shopping is about as fare as it's been so fare !!
think 1/4's would work really well , balance it up.
Jun 11, 2019 16:20:46 GMT
So I went with full front bumper in the end. And the lower spec pop front grill.. And I think it works Also made a start on some banded steels for it. To pop on at a later date And vinyl painted the rear seat black. Still little bits to do. But now able to get out and use it ..
Jun 11, 2019 16:36:06 GMT
Looks good; a full width bumper always makes the car look wider, lower and finished.
Jun 11, 2019 16:55:06 GMT
Banded steels alway look good on a 100e
Jun 11, 2019 19:22:36 GMT
bumper.......check
grill......check
twinc badge......check
rear seat......check
steels......check check check check check check check check check!
what colour was the rear bench to start off with pete?
Jun 11, 2019 21:08:43 GMT
bumper.......check grill......check twinc badge......check rear seat......check steels......check check check check check check check check check! what colour was the rear bench to start off with pete? Gray with red piping .. But didn't match the rest of the interior
Just a little update. Plan to make a new inlet for the bike carbs after they popped off the silicon hoses,after some people told me they might ! And other than that just been out driving it and getting some shows in.
Local show I attended
Last Edit: Aug 4, 2019 16:29:15 GMT by petetong
Parts to make new inlet.
Aug 31, 2019 22:12:01 GMT
when's the test run?
@peteh1969
It may be a bit late now but shouldn't the carb float bowls (at the bottom) be horizontal / parallel to the floor rather than angled as it's in a basic form the same as fitting 4 Stromberg carbs and I know those don't perform if the float chambers are not level?
Nice work on getting the manifold built.
Last Edit: Sept 1, 2019 9:38:41 GMT by peteh1969
Sept 2, 2019 22:00:23 GMT
Was tonight. And still not happy with them.!! Still seems thats it's only running on 3 at ideal and has a flat spot mid range! Might just stick the twin choke back on.
Sept 2, 2019 22:02:25 GMT
I did original fit them with the bowls level but looking at how they sit on the bike they came off and speaking with others seems there about right and it doesn't really make much difference!
they are generally canted on bikes , i believe , plus think of the angles they run at in cornering. stick at it pete , you will crack it!
