About 3 years ago I paid what was considered strong money for a 190 Cosworth. I didn't do it for the brand or any other reason (i'd love an E30 M3, but can't afford one!). Why I did was that a friend of mine has a black 190 2.3-16 that he was kind enough to let me drive. After I tickeled it about for 20 minutes, he said "just drive it as your own".... Another 20 minutes and with a mild rear end drift I was hooked. I had (at the time) a Lotus Excel v8 and knew that i'd never be able to forget the 190. Fast forward 9 months, a house purchase and a girlfriend that was sick of me looking at them online every evening....... I bought the below. Sadly I don't have a photo from when I bought it as the (now ex had them on her Facebook)
Last Edit: Apr 30, 2020 14:55:53 GMT by jonnyboyraver: Title Update
Photo now added! UPload wasn't working for me!
Sadly you're unable to remove the timing chain without dropping the sump and removing the head due to various guides being in the way. What I should have done was pulled the engine (you'll see where this is going later!) I'd spent over £400 in parts from Mercedes and probably the same again replacing alot of very tired sensors, radiator, various bolts, engine damper, etc. The previous owner said it "only" needed a chain. I'd been kidding myself.
This was the first time that it had gone back together. What I wasn't told was that the machanic hadn't set the timing chain correctly and everything hit on first start. He hastely removed the head and had it re-skimmed and the valves recessed further as somebody had been there before me. I got the car back and completed approximately 300 miles before a breather hose on the back of the engine exploded and it dumped it's water everywhere. That was going to the first Bournemouth Pistonheads meeting of the year, I wasn't impressed. For a year, the car sat in the communal car park looking sorry for itself. Even some of the neighbours washed it for me on occasion.
alx
Club RR Member Number: 21
Bookmarked!
Who doesn't love a Merc cossy?
AL.
Thanks Al! Lots more to come!
So the long and the short of trusting a moron with my car is this; - He'd bent the timing chain and bodged another connector onto it (as he'd cut a link out with a disc cutter!) - The fueling had been adjusted for a terrible idle. - The head had cracked inbetween the crankcase breather and water feed. Luckily (at the time) Mercedes had 4 new-old stock heads left in the world. I snapped one up! The engine was pulled from the car (thanks for the help, various!) and the block was sent to a local machine shop. It needed a regrind on everything and was the model of a "tired engine". So I had to find new pistons... The choices where; - Mercedes, Mahle oversize at £200 each (£800 for 4) - Weisco Forged Pistons from a chap in Germany for £650, including P&P. Guess what I did? The engineering shop did a great job and got hold of a complete bottom end gasket set for me too. I had them build the basic bottom end.
It was at this stage that I had a huge sort out in my garage and cleared an area to work on the engine. I was living in a terraced house with a garage in the block, luckily, I had great neighbours and there was never a time that I couldn't ask somebody more senior then I for an opinion or a hand. What a great many don't appreciate is that preperation is the key with these engines and that the timing chain is a total *curse word* to get on. Another friend had found me a cheap engine stand on ebay and (fuelled by Stella) I set about fitting the ancillaries and torqueing the head. One of my neighbours is an old school full time mechanic and would float over to mine on a Saturday to help (but mostly just steal my beer). Photos above say far more then words!
Space was cramped, but it worked.
ToolsnTrack
Homebrew Raconteur
Club RR Member Number: 134
keeeep.... going.....
Following various threaded bars, rechecking of torques and the head fitting (which uses Daewoo Matiz bolts!) It was time for the oil pump and sump. I say this as one because of the unique way inwhich one HAS to go in prior to the other Sadly, I didn't take any photos of the dissasembly and rebuild of the pump, but to summerise, we had the following issues - Seals had gone brittle (all of them) - Oil Pump Relief valve Spring was 150,000 miles old. I changed it.... - The stop plunge to the relief valve had seized due to carbon build up. I think that the last issue could have been a contributing factor to the slow death of the car. Then I played a game of sliding in on gently (under a fitted head gasket) until seated correctly. End oil seal replaced too. Below is a view from the underside. Finally, it was time for the sump to go back on. Everything was thoroughly cleaned in petrol!
Next up, I had an almost completed engine and a really manky looking valve cover. Whilst I wanted to go full OEM on it, I couldn't justify the cost. So for the interim, I had it fine bead blasted and powder coated black. I won't recommend either, as neith did a great job.
Then came another change in life. I'd taken a few promotions/changed jobs, etc and I could afford a better place. Problem was, I had the contents of the house, a blown up Honda, a Motorbike and the contents of my garage! A few phone calls/Whattsapp messages later and a mate and his son agreed to help me get the lump in one weekend. I wasn't moving far, but the new place was a wreck and on the list was extending the garage! Whilst I was at it, I replaced the clutch (not that there was much wrong with the old one!) After a mornings swearing and messing around, it was in. Luckily, you've got a sensible amount of room without the ancillaries installed. The rest was boxed and moved to the new place in a friends van/Dads box trailer. That brings us to June 2017
tristanh
Routinely bewildered
Looking forward to more.
I really like these. A real shame about the problems though.
My dad had one the sae as this when I was a lad, Ive wanted one ever since. Good work. Isnt it terrible when you go to a garage and they churn out curse word work/no work at all? One of my pet hates. You pay someone to do a job, just do it to a high standard.
It's a real shame, but since then the mechanic has become a mobile injector remover (probably for the best) as he's not a well man. Sadly I've forgotten my laptop today, otherwise there would be more to read. I may get a chance over the weekend to update it. Needless to say, there has been a lot more done (and continues to be!)
Looking forward to more updates. A future car to add to the collection is either one of these or a bmw as I've not owned either in the past mostly Audi's so fancy a change.
Porsche 944
