Feb 20, 2019 16:41:28 GMT
Chris, can you elaborate on why circles have less distortion please? Part of the answer is what Jonsey stated that the corners will always attempt to pull up - but with a circle you will not get the distortion on welding that you would with a straight line weld i.e. if I had cut out and welded a square plate back in - I was always taught to work across the centres - so tack on one side of the circle then go directly in line to the opposite side - keep working around in quarter / 90 degree increments cooling each weld with the airline - and for some reason this works far better than any other way piecing in by welding on a large flattish panel - there is probably a more scientific engineering reason behind it but I'm just a simple bloke that makes cars look shiny and I hated physics when I was at school so I have never delved much deeper than 'This method works so I'll keep using it'
Last Edit: Feb 20, 2019 16:52:40 GMT by Deleted
Feb 20, 2019 16:48:30 GMT
chris, whats your thoughts on using wax/bitumen based cavity treatments contained by intersecting panels and PU seam sealers ? what i'm getting at really, we are making liquid tight areas with the seam sealing, then oil based chemicals sitting on rubber for decades.. ? is this ok? It's done at the OEM stages on premium branded cars - and I have never had any issues - cavity wax tends solidify over a period once its been injected to create a film type surface covering and all automotive sealers used in body seams to my understanding have a high resistance to oil based products purely on the basis that they may well at some stage for whatever reason come into contact with a oil based product - either accidently or intended use
Feb 20, 2019 18:55:13 GMT
Thanks Chris, interesting to note to do circular repairs in any future projects.
Feb 20, 2019 19:28:04 GMT
Last Edit: Feb 20, 2019 19:31:05 GMT by Deleted
Feb 20, 2019 19:36:33 GMT
nearly up to date?...rats....that means real time updates...rats!!
Feb 20, 2019 19:41:13 GMT
nearly up to date?...rats....that means real time updates...rats!! I think I can creep it to the start of next week before we go to RTU 'real time updates'
Last Edit: Feb 20, 2019 20:19:40 GMT by Deleted
Feb 20, 2019 19:41:48 GMT
phew... i was getting the shakes!
vulgalour
Club RR Member Number: 146
Feb 20, 2019 19:58:50 GMT
RTU is better than the several months of update drought we had to endure. Your readers need their regular Grumpy fix!
Feb 20, 2019 20:26:08 GMT
RTU is better than the several months of update drought we had to endure. Your readers need their regular Grumpy fix! This. 😀
keyring
Club RR Member Number: 47
Feb 20, 2019 21:48:13 GMT
Well, it has took me a while reading from page 1 over the last couple of days, but that’s me up to date. What a journey it has been, and without sounding like a broken record, your work really does amaze me! The hidden horrors in this car were unreal, but you always have a solution and make it look better than new! I’ve actually started taking notes in my note pad when I see a tip/method on something I think will come in useful once I start on the corrado, really looking forward to the next update!
Feb 20, 2019 23:04:40 GMT
Looking sharp......see what I did there......mmmm....
I have absolutely nothing to say or add, except sheer admiration.
This is a restoration most of us can relate to.
Your work and attention to detail is amazing and just makes me grin non stop, along with the odd head shake of amazement, like the roof patch.
Last Edit: Feb 21, 2019 7:19:14 GMT by grizz
samta22
Stuck in once more...
Club RR Member Number: 32
Feb 21, 2019 10:44:32 GMT
Top work as always sir - great to see the lift coming into its own as well, bet that made the front valance profiling a little easier
Feb 21, 2019 11:44:20 GMT
What is the coating on the wing in this picture? It almost looks brushed on.
Feb 21, 2019 12:27:53 GMT
In 100 years, when this is ready for it's next rebuild, I can just hear the restorer saying, "These earthlings used to write and draw all over their travel machines"
vulgalour
Feb 21, 2019 13:12:04 GMT
bjornagn: I could be wrong, but it looks a lot like vanilla frosting, so it's probably that.
Feb 21, 2019 13:37:50 GMT
I've been using something called "Dolphin glaze" recently, which is a very fine and slightly runny version of "ordinary" polyester filler. This is a different colour (Dolphin glaze has a greenish tint), but I reckon it's a very similar product from a different manufacturer. Really nice stuff for the fine finishing work.
I haven't checked to see if it tastes of vanilla...... smells like filler though!
Nick
Feb 21, 2019 16:04:47 GMT
I've been using something called "Dolphin glaze" recently, which is a very fine and slightly runny version of "ordinary" polyester filler. This is a different colour (Dolphin glaze has a greenish tint), but I reckon it's a very similar product from a different manufacturer. Really nice stuff for the fine finishing work. I haven't checked to see if it tastes of vanilla...... smells like filler though! Nick Interesting. Had not heard of this kind of product and what I know of as "Glaze putty" is used mostly in small areas towards the end of the project and is very expensive. Might be a substitute for the highbuild polyester coat ( featherfill) that I use. In my world, the less spray in the air the better. Plus the time and $$$ to tape and mask.
Feb 21, 2019 16:21:56 GMT
I've been using something called "Dolphin glaze" recently, which is a very fine and slightly runny version of "ordinary" polyester filler. This is a different colour (Dolphin glaze has a greenish tint), but I reckon it's a very similar product from a different manufacturer. Really nice stuff for the fine finishing work. I haven't checked to see if it tastes of vanilla...... smells like filler though! Nick Yes, it's a finishing glaze or "stopper". We get through it like water. Made by Upol, but other companies make their versions, such as 3M Premium Glaze, which looks like melted cheese slices when you put it on. Dolphin is our go to product though. For the price it's hard to beat.
Specialist Bodyshop & Fabrication Classic, Retro, Prestige & Custom Small Repairs to Concours Restorations Mechanical Work Vintage to Modern
Feb 21, 2019 17:58:12 GMT
This is looking nice now, when its your full time job you can just get so much more done at an amazing pace, at this rate we will see it at the shows soon!
