MiataMark
Club RR Member Number: 29
May 26, 2020 10:18:28 GMT
Funny - there may have been a small trolley jack in one of the pictures above. It wasn't there for effect I don't know of a bodyshop that does not have several lengths of 2 x 4 for door springing along with ply / timber pads for panel jacking - a proper eye opener is to see a accident damaged vehicle mounted to a body jig & the jig being used in vengeance to pull the damage out of the bodyshell There was an episode of Fast & Loud where they straightened out a Ferrari F40 with a jig and some brute force and ignorance.
May 26, 2020 10:51:54 GMT
I don't know of a bodyshop that does not have several lengths of 2 x 4 for door springing along with ply / timber pads for panel jacking - a proper eye opener is to see a accident damaged vehicle mounted to a body jig & the jig being used in vengeance to pull the damage out of the bodyshell There was an episode of Fast & Loud where they straightened out a Ferrari F40 with a jig and some brute force and ignorance. And boy was it a twisted mess!!
melle
South West
It'll come out in the wash.
May 26, 2020 11:57:03 GMT
Professionals use ratchet straps and jacks. Not that I claim to be a professional.
May 26, 2020 12:34:13 GMT
I did the same as above on our minor. Using the blocks of wood is fine if you are skilled enough (not that I am) but I've seen the pros do it and it's just another tool which if you don't use it right you could damage something.
May 26, 2020 16:43:10 GMT
Professionals use ratchet straps and jacks. Not that I claim to be a professional. The problem with using this method is that the bubble in spirt level will be all over the place every time you go round a corner or hit a pothole
Last Edit: May 26, 2020 16:55:36 GMT by Deleted
melle
South West
May 26, 2020 16:48:15 GMT
The problem with using this method is that the bubble in spirt level will be all over the place every time you go round and a corner or hit a pothole The spirit level needs a better location anyway as it's very hard to see from behind the steering wheel.
May 26, 2020 21:55:34 GMT
When my classic Mini was in the bodyshop after I threw it in a hedge, the boss man cut off the bent front wing with an air chisel, then straightened the inner wing by chaining it to the 20ft metal waste bin and then reversing the car. Not sure it was "professional" but it did the trick.
Last Edit: May 28, 2020 15:21:52 GMT by mrbounce
I pulled the front of my Cressida back in to shape* by using a hand winch chained to the front bull bar of my other Cressida. Probably should have used something a bit heavier as now there's some really short elevens on the painted driveway and garage floors where both cars got dragged towards each other a bit.
May 27, 2020 11:54:06 GMT
I use a handy length of 2x4 for twisting doors so they fit properly and it works really well if your careful with it (and also what you are pressing on of course!).
The garage I used to do some work at had a gate post that was probably 8"x8" steel and there was at least 6ft of it in the ground. We used it occassionaly for pulling against and it always worked well.
moglite
Club RR Member Number: 144
May 27, 2020 20:28:45 GMT
Repair panel for the bottom of the door. First held in place with magnets, then some spot welds. The patch is overlapped on the door. I've done the angled edges on purpose, so I fish out any scraps of steel later, when I make the cuts. I could have made this a joddled repair, but my preference is for a butt joint wherever possible - but that is just me. Its no fun working on the ground, so I drilled some 2.5mm holes in the hinges for some index pins - thanks @grumpynorthener for those pins - they work a treat. Now I can put the door back on in the exact position repeatably. Starting on the welding, first run a slitting disc down a small section of the blue line Here you can see as I work across the panel in the various stages of - Ground back
- Fully welded
- Un-started but holding the panel nice'n'flat.
This is where the title of "cool hand Luke" comes in. My name isn't Luke, but it the cool hand piece that is important. I used the blow gun to keep the panel temperature right down, to be cool to the touch. It was surprising just how much air was needed to keep the panel cool.
But the flap wheel used for the grinding back produced an awful lot of heat too. Not something I've done before, but I used the blow gun to keep the grinding temperature down too. For me, the flap wheel was putting more heat into the panel than the welder !! It took me 2-3 hours to weld/cool/dress just that joint. But it was worth it front <-> back the panel has stayed distortion free, which I'm very happy about. Top <-> bottom, the joint is slightly concave. That is the way I prefer to setup the panels. It means I don't risk thining the metal when grinding, and a light skim of filler will get it perfectly flat. Hardly the most exciting piccie, but the seam on the back has folded over, and the fillet joints at the end have been welded up. Thanks for looking
eternaloptimist
Great job on that door.
moglite
I'm not a fan of China currently, along with a lot of others, but I couldn't find these stainless plates anywhere else. They are 119mm OD and about 4mm thick, end caps for pipes in food production I believe. They along with a 90 degree bend and some laser cut flanges from @johnnybravo are to form the basis of my air-filter. It is rare that my cordless gets a day off, but today is its day, with a fresh Starrett holesaw in the pillar drill, and lots of lube. I chose a K&N element to sandwich between those two plates (via some welded on nuts, inside the top plate) But K&N's aren't pretty. I was after some decorative mesh as fitted to my dashboard. I thought it would be a nice touch to tie things together. Yes I'm liking that a lot. The mesh from the dashboard is only long enough to cover 3/4 of the filter. But I've got a 2nd piece on the way to fill the gap The joins on the mesh will largely be hidden once the bonnet is back on. But it should be possible to make them neat with a small vertical of H-section on each join. I even though about lacing them together - with welding wire - might have to play with that on some scraps and see if it works. A that stainless top is 4-5mm thick I've got some scope for machining or engraving a design into it. I've not come up with anything I love yet, so it can stay plain for now. Thanks for looking
adam73bgt
Club RR Member Number: 58
Love the look of the mesh on the air filter, just looks "right"
moglite
Had a bit of garage time this evening. Fully welded the pipe to the air-filter. Ground it back some. This I believe will get powdercoated, rather than polished. So, I can call this one good and move back to the bodywork.
lebowski
Hillman Avenger, Clan Clover
Although it looks nice, that dense mesh will hugely reduce the airflow capabilities through your filter.
That looks cool. It might be a bit restrictive, dead easy to diagnose it is though. I think with the supercharger pulling air through and relatively low rpm you'll be spinning the engine to it probably won't make a huge difference.
I think it will be just fine but the bigger question is can it double up and tune into Radio 2 at the same time
jamesd1972
Club RR Member Number: 40
I think it will be just fine but the bigger question is can it double up and tune into Radio 2 at the same time Doubt it but will probably make some nice noise all the same. Lovely detail. James
hohocc
Had a bit of garage time this evening. Fully welded the pipe to the air-filter. Hmmm everyone says you can't weld to (for example) rust and here's someone claiming they can weld to an air filter? ?
moglite
Had a bit of garage time this evening. Fully welded the pipe to the air-filter. Hmmm everyone says you can't weld to (for example) rust and here's someone claiming they can weld to an air filter? ? Does "Fully welded the pipe WHICH GOES to the air-filter" make you happier ??
