Not much done since last update what with having a cold then having the flu and don't forget the nice cold weather outside, with it being so cold and wet outside I decided that the wiring could wait until it gets a bit warmer ( probably next year ) and have started on the interior trim repair's.
First thing was to tackle was the damaged and cracked dashboard crash padding.
P1010151a by karl stroud, on Flickr
P1010150a by karl stroud, on Flickr
The loose plastic was first removed and the foam underneath ground down slightly, then all the cracks were ground right down with a die grinder.
P1010152a by karl stroud, on Flickr
Next polyurethane was melted into all the damaged area's with a plastic welder then flatted of to just below the level of the plastic finish with a power file.
P1010153a by karl stroud, on Flickr
P1010154a by karl stroud, on Flickr
This was then filled with flexible filler ( the type used for repairing bumpers ) and then sanded by hand to the same shape as the original finish.
P1010155a by karl stroud, on Flickr
P1010156a by karl stroud, on Flickr
P1010157a by karl stroud, on Flickr
P1010158a by karl stroud, on Flickr
P1010160a by karl stroud, on Flickr
This will get painted with texture paint at the same time as the other parts are done. The interior trim parts still to repair are, both door trims ( one very badly damaged and both slightly warped ), rear b-post to rear wheel arch plastic cover ( just needs covering in texture paint as all the texture has rubbed off ), rear shelf plastic trims ( same as the plastic covers ).
On another note I have started sorting out parts for the engine. I have bought the cylinder heads, but I did the one thing I said not to do I bought them with all valves in ( they were a silly cheap price with all the valves in ). I am now in the process of pulling them apart to double check valve fit, clean any casting flash off them with a die grinder and get rid of any sharp edge's and radius oil drain back holes.
P1010162a by karl stroud, on Flickr
P1010163a by karl stroud, on Flickr
P1010164a by karl stroud, on Flickr
P1010165a by karl stroud, on Flickr
Also the engine block is now with the machine shop to be re-bored. I have decided to fit hypereutectic pistons made by speed-pro ( H555cp ) and plasma-moly rings ( r-9903 ), when the block is back I will be ordering a set of eagle con rods ( 5780f3d ) to complete the bottom end build.
Next I have got to choose what camshaft to use, these are the spec's of the ones I am looking at :
Lunati 30320511 ( old code 411a1lun )
In Ex
Duration 272 / 282
Duration @ 0.050 238 / 248
Lift ( gross ) 0.558 / 0.580
Lash 0.018 / 0.020
Valve opening BTDC 28 / 77 BBDC
Valve closing ABDC 64 / 25 ATDC
Overlap 53
LSA 112
RPM 2500 - 6500
Schneider cams 256-64f 254-74f
In Ex In Ex
Duration 256 / 264 264 / 274
Duration @ 0.050 212 / 224 224 / 230
Lift ( gross ) 0.502 / 0.519 0.519 / 0.532
Lash 0.012 / 0.014 0.014 / 0.014
Valve opening BTDC 20 / 68 BBDC BTDC 24 / 73 BBDC
Valve closing ABDC 56 / 16 ATDC ABDC 60 / 21 ATDC
Overlap 36 45
LSA 112 112
RPM 1500 - 5500 2000 - 6000
Howards cams 232342-10
In Ex
Duration 258 / 258
Duration @ 0.050 230 / 230
Lift ( gross ) 0.554 / 0.554
Lash 0.022 / 0.022
Valve opening BTDC 23 / 63 BBDC
Valve closing ABDC 55 / 15 ATDC
Overlap 38
LSA 110
RPM 2000 - 6200
Comp cams 270s 282s
In Ex In Ex
Duration 270 / 270 282 / 282
Duration @ 0.050 224 / 224 236 / 236
Lift ( gross ) 0.540 / 0.540 0.570 / 0.570
Lash 0.022 / 0.022 0.022 / 0.022
Valve opening BTDC 29 / 69 BBDC BTDC 35 / 75 BBDC
Valve closing ABDC 61 / 21 ATDC ABDC 67 / 27 BBDC
Overlap 60 62
LSA 110 110
RPM 1800 - 5800 2000 - 6000
At the moment I am leaning towards the Lunati cam as I have been told that a split pattern cam with a wide LSA and low overlap will suit my heads the best and give me the good vacuum at idle to work my power brakes and maintain low speed drivability, but if I do not go for this cam it will probably be the Schneider 254-74f cam as I have also been told that it is best to have the exhaust valve opening at around 80 BBDC because the later you open the exhaust valve the more it causes high RPM to drop off.
I will also be changing the toque converter to a higher stall to match whichever cam I fit and I will also be changing the rear axle ratio to suit as well.
If anybody has any feed back on these cams or know of any other mechanical flat tappet cams I have overlooked please let me know.
