Jun 15, 2019 22:06:27 GMT
Ah yes, it’s all coming back to me now. 😃 I might have already said, but my mum had a couple of 1.4 engined Volvos back in the 80s, and I drove one of them a lot after passing my test. It was a willing and revvy unit. I’d think investing in a new CROWNwheel and pinion would be well worth it, once the initial financial shock has worn off. You quite right Glen. Once the money is spent it is soon forgotten. At the moment all the money I have, and some I don't is tied up in other projects. One day🤔
Jun 15, 2019 22:10:06 GMT
i assume the van came from gweek , hence the name? i remember you said it came from helston , so i suppose that's close enough. good job you didn't get it from warleggan! real sign too , not a photoshop!! Twinned with Narnia? I suppose it's better than being twinned with some place in Europe you've never heard of. Yep the vans named after Gweek, the village we picked him up from.
if you had been there you would see why!!
Jun 18, 2019 19:06:28 GMT
Small steps and all that. Went out the garage for half hour (well it felt like half an hour) and decided to cut the tramp bar brackets off. New brackets are around £35, a lot cheaper or you want just bent plate ones - not pressed like the originals. The weld bead was quite small so cut with little damage to the bracket, so I will just clean these up and reweld them once the weight is on the axle. I put the driver side strut together and put it in the car. I still can't mount them onto the TCA as the nuts I ordered were the wrong ones 😩. I put a new shiney boot on the TCA also. I'd like to have it back in it's wheels by the end of the weekend.
I have covers and bump stops to go in mt front struts when I build them up should give added protection to the strut rod.
Jun 19, 2019 12:16:33 GMT
I have covers and bump stops to go in mt front struts when I build them up should give added protection to the strut rod. I do have a set of covers but they're a bit ropey. There were no pump stops on the struts when I dismantled them but according to the book there should be. I might fit some but I don't even run them in the rally car so I think they may be a bit superfluous
Jun 19, 2019 13:27:30 GMT
I was reminded of an interesting fact whilst putting the strut on yesterday. You the see the front springs are off James Bond's car. Now when I say James Bond, I mean Roger Moore. You see Roger once owned a mk2 Cortina 1600E. A series 2 to be exact. These springs are actually off that car. Now these are 2" lowered and I'm not for one moment suggesting Roger was out side is house one Sunday fitting lowering springs to his 1600E. That would be cool though. But the the guy who now owns the car was putting the car back to standard after someone (probably not Roger) had fitted them. I then bought said springs and have fitted them to my Cortina.
So there you go, James Bond's springs (probably not).
Jun 21, 2019 20:35:07 GMT
I've got a 3 day weekend and operation get the Cortina back on its (some) wheels has begun. First off, food shopping 😩, then diff back in. Next was the back plates (after I pondered fo 30 mins about which side was which), half shafts in (I'd labelled these), and all the brakes in (this took a while to work out too). Next it was time to connect up the handbrake cable of which there are 2, one from the lever to the axle, and the other from drum to drum. I've only ordered the front one so had to fit the old axle cable for now (new one ordered). To get the handbrake to work I had to adjust the cable all the way up so there is no adjustment left for stretch. I emailed the clubs parts guru. He checked the cable lengths and confirmed they are correct. He then pointed out that as my axle is off a series 2 with a floor mounted handbrake and mine is a series1 with a dash mounted umbrella handbrake, the lever on the axle is too short. I have a spare series 1 axle which I think is an S1 so I'll see if I can take the one off that and swap. If not, I'll extend this one. I then had to take the Escort for an MOT at my brother's where it eventually passed after retightening both rear calipers as they were completely loose (passed the brake test like that), fitted a new washer pump, and rebuild the number plate light. I had failed to realise that after my brother had crashed in the back of it in Singleton car show, the light was now mangled. When I got back at about 6pm I thought I'd fit the new front wheel bearings I'd bought from eBay to my freshly painted hubs. This was a no go as they were the wrong bl00dy size. Well that's put the mockers on operation get the cortina back on its wheels, I thought. But then I had a brain wave. What if they are the same as the ones I replaced on the Escort? I dug out the old struts, and good old Ford came up trumps - the hubs are identical, but the studs a metric not imperial. I then had to find 4 wheels and tyres that can hold air as I've still not bought tyres for the Lotus Steels. So far I've found 3 as I can't use the minlites I have for the rally car as the wheel nut design is totally different. Before operation get the cortina back on some wheels can be finished, I've got a lot of tidying to do so made a start on that and found these 2 little H shaped plates. These should have goon in the back brakes. Doh! Stripped one side down and fitted. I'll do the other side tomorrow In all, quite a productive day. More tomorrow.
Last Edit: Jun 21, 2019 20:39:37 GMT by jonsey
Jun 22, 2019 18:18:05 GMT
Last Edit: Jun 22, 2019 18:21:49 GMT by jonsey
Jun 22, 2019 20:07:10 GMT
I'm not sure if the Cortina has the same geometry as the Corsair even though it uses a lot of the same parts but I have set my track rods to 340 mm ball joint centres for the Toe setting if it helps.
Jun 22, 2019 20:25:59 GMT
I'm not sure if the Cortina has the same geometry as the Corsair even though it uses a lot of the same parts but I have set my track rods to 340 mm ball joint centres for the Toe setting if it helps. Thanks Pete. I think the Corsair is the same as the mk1. The mk2 is a slightly different set up. I don't know what the difference is though. I've only put the old ball joints on so I can take it over my brothers to get it flatted and polished. I'll get it set up properly once the new ones are on and the engine is in.
Jun 22, 2019 22:08:17 GMT
I like the skinny steering wheel. 👍👍
Jun 22, 2019 22:51:47 GMT
I like the skinny steering wheel. 👍👍 I think it's cool.
Jun 23, 2019 18:38:02 GMT
This is the job I'd been putting off for a while. Fitting the roof gutter stainless trims. I've replmade some of the gutters as they were rotten so was worried they might not fit. The original trims and some spares that I had were dented and bent so I bought some better ones. The seller had a few sets so I picked the best ones out if the lot. Series 1 cars like mine have a little curve in the front trims near the bottom, series 2 are straight at the bottom like the rears. I realised today that in my effort to pick the best ones off the seller I had picked up to S1 fronts and 2 S2 fronts instead of 2 rears. First I panicked, but looking through the trims I have I've managed to turn a curse word pair into a useable pair after a lot of straightening, undenting, paint scraping and polishing. I then masked and taped one of the headlamp trims and painted satin black And then ran out of paint so couldn't do the other. Also made a start scraping all the badly brushed on black paint from the grille ready for repainting and polished the bits that are going to be left chrome anodised. I hate this kind of work.
Jun 29, 2019 18:04:58 GMT
I got fed up of thinking about tyres. I've been walking around car shows and whenever I'd see some Lotus steel wheels I'd be taking pictures of the wheels and tyres looking for a "look" that I like. I'm far to young for 80 series as I'm far to young for that even the the old guard in the Cortina club will tell you they drive better on them - I don't care. I didn't want 185 60's as they looked to wide on a 5.5". I wanted a 70 series look but they all looked a curse word shape like they were just a budget tyre to do a job and aesthetics didn't matter. In the end I gave up and just bought some Yokohama A539 175 60's. If I grow to hate them I'll burn them off on the rally car. I've also resprayed the grille black like a 1600evand refitted. Next I pulled an engine out of the local harbour. Well it looks like it. Removed a broken exhaust stud In guessing a core plug is leaking But a bonus is it dies have a performance air filter fitted. I then spent half an hour removing all the rusty flakey paint. If you ever need to do this get yourself a brrrrt. It's brilliant easy and quick.
Jun 29, 2019 18:06:13 GMT
A couple that didn't come out
Van. I've been using the van. No where far. Just over my brother's garage and picking up Jonsey Junior (The Younger) from school which put a smile on his face. No photos though. I had a few looks. Not sure if they thought it was cool or they're not used to seeing a van being driven with the door open. Cortina. Change of plan on the engine front. I was going to use the engine that came with the car. The PO told me that it ran brilliantly and was really quick up hills etc. But he'd also told me he had done all the welding underneath. Remembering that I had spent 2 years welding this replacing all the chassis rails as they had been covered in what looked like bean tin quality steel and layers of black curse word, I decided that taking his word on the engine condition may not be the best decision. So roll out engine No2. Now this beast isn't really a beast at all. It used to live in the Escort until I converted it to 16v. But I do know its condition. I bought it for £90 about 12years ago. It had been rebuilt with +20 pistons but where most people fit 1300cc pistons to up the compression ratio, they for some reason used 1600cc pistons so a rather uninspiring standard compression ratio exists. I've fitted to it a rebuilt bid valve head with a bit of porting, Rimflow valves, bronze valve guides and double valve springs. I've also fitted an old stool Cosworth A2 cam - nothing to wild there. When this engine was first in the Escort, Jones Junior (The Elder) who was about 5 at the time put some nuts down the carb whilst in the garage with me. The Little Cherub. I subsequently took the car for a little spirited drive where the engine consumed said nuts and made a horrible noise as you can imagine. To fix it I pulled the head off, used a screwdriver and hammer to chisel the damaged valve pockets back into shape as the nuts had managled the piston. I straightened the valve in the vice, relapped it and refitted it all. And it worked good after until I went on a quest for more power. So it's not a brilliant engine, but is a known quantity. But it needs to be converted to fit the Cortina as that has a front bowl sump and the Escort has a rear bowl sump. So sump off, cleaned and sprayed satin black, and timing chain cover off also as the dipstick is now housed there. Flywheel next. On the Escort I ran a Cast flywheel that was that was machined to take a larger pinto clutch and it was also lightened. I used it in competition for about 15 years and it never exploded and killed baby ducks like everyone moans about. Only problem with it is on the Cortina I want to run a standard clutch and the face of the flywheel on the Escort flywheel is 8mm closer to the engine. It might be fine but I've got no time for release bearing issues so I've sent a Cortina flywheel to a mate for it to be lightened (without it exploding and killing baby ducks). I do have a standard GT Cortina flywheel, but I made a lamp out of that so it's no good now. So the engine was attacked with the brrrrt to remove layers of old paint, rearbowl sump fitted with Cortina timing cover and painted satin black too. This morning before work I've fitted new front wheel bearings, vented discs and calipers. I have to change the caliper end brake pipe as it is now metric as these are Escort calipers not Cortina. The thread is the only difference apart from the vented v's non vented bit. Until next time.
Have you ever worked all day on your car and it looks like you've accomplished sweet FA? Well today is one of those days. I was in the garage by 10:15 and was there until 5. I did to a tip run halfway through as I needed to get rid of 30L of used engine oil so take an hour off. Remember big heavy flywheel? Well it know looks like this. I know it looks like a huge amount has been removed, and a huge amount has been removed, but it is now basically a tiny bit lighter than a normal 16 GT flywheel. No baby ducks will be harmed so don't worry. So first thing I did was fit it and torque it up. I can't fit the clutch assembly yet as I needed to buy new dowels and they've not turned up yet. Next I fitted the engine mounts and cleaned and fitted the alternator. I only cleaned it with brake cleaner and some blue roll so hasn't come up that great. I then removed and sprayed the fan pulley satin black, changed the gasket on the thermostat housing, swapped the bung in the water pump for a heater hose take off, removed the breather pipe from the rocker cover and blanked it, cleaned the Bosch Electronic distributor (from a mk2 Fiesta) with some more brake cleaner, dug out the twin Weber manifold I want to use ( and realised I need to order studs) and that was basically it. A whole day's work (there or there abouts) and the engine doesn't look a great deal different to last week. I can't remember if I've said but I'm trying to get it running by the owners club National meet at Stratford Race course on August 4th. I don't think this is likely as the gearbox isn't back yet, carbs aren't back yet, exhaust system is booked for end of a July but work won't tell me if I can have the day off yet to take the car to Cardiff to get it done and god knows if the electrics are going to play ball. Will it make it? Stay tuned.
Really, really happy that the time thief just does not reside exclusively in my workshop in that case - he / she also appears to be making regular visits to your place too - so do me a huge favour next he / she visits - can you lock him / her in your workshop, barricade the doors & windows and call the local nick to have him / her arrested has I'm well & truly sick of the menace on this Corsair job Or could it be that you are getting visited by the Welsh time thief and I other hand find myself visited by the Southern time thief ?
Last Edit: Jul 7, 2019 19:34:27 GMT by Deleted
melle
South West
It'll come out in the wash.
If you wouldn't be spending so much time on here you'd get some actual work done.
