ET
Feb 22, 2017 18:27:01 GMT
It's alivee!! and now running better/smoother than ever! really chuffed with that! Mind you that's an iphone recording so it sounds a bit rough:P Got the last tweeks done at Imparts in Ede (for the dutchies), really nice company with some nice machinery standing there picture from the internet* ET - To me it sounds a little rougher on idle than a car fitted with the stock cam should so you may find a rolling road tune gets it even better? I have a favour to ask: Your installation of a Peter Burgess head has stirred dormant ideas of how to go about upgrading a series 1 BL / Austin Princess with the 1800 B series as a more usable daily that I mentioned I wanted to do as a fun tinkering experiment in this thread - click here. At the time, like you I knew that he is the authority on head upgrades which in-turn are key to the biggest gains in efficiency / power, however I assumed his work would be way out of my budget. As you can see most people who posted in that thought the "boat anchor" B is not worth upgrading - which in pure monetary terms is probably definitely true if the whole lump is to be refreshed (minimum rings, shells, gaskets, ideally balanced for smooth higher speed cruising) at the same time - so I'm going to be swayed (or not) by what can be achieved with medium outlay on a sound example of this engine that just needs such a refresh as good practice / for greater longevity: Hence once It has bedded in, would you mind being very detailed on the difference it's made to performance and fuel consumption? I would like to use your experience to finalise a plan and begin costing. Also, for what my opinion is worth, I didn't read your rocker cover as anything other than what was intended and I would leave as-is. Hey DJefk! apologies for the late reply, i'm in Denmark currrently for my study and i don't have my car with me:( I hope that i can bring it in April, than I can give you a bit clearer picture on how the car behaves with the new head:) especially the consumption Power wise is hard to say, i think i have been driving the car with 1 poorly compressed cilinder. So having 4 higher compression ones with efficient intakes makes a lot of difference, what this difference is with a good working standard unit. Not a clue haha sorry. Rolling road tuning would obviously make it run even better, but this is just not in my budget. The garage which tuned my car has a lot op experience with B's, the mechanic told me that the idle is a bit rough but he was not sure if this could be taken out totally. On the power story: I'm quite satisfied with the 1800 engine, it makes the right noise and you don't get a ticket too fast haha! drifting would be a bit difficult maybe but hey. My plan is to tweak it a bit and maybe use it semi-competitively on a track day or 2. As far as the head modification goes, it is reasonably cheap for the work being done. Head is cleaned, reworked, and fitted with new valves and springs. Curious how your Austin will play out!
ET
Apr 18, 2017 19:55:10 GMT
Last Edit: Apr 18, 2017 20:09:40 GMT by ET
ET
Apr 18, 2017 20:09:57 GMT
ET
Apr 18, 2017 20:16:14 GMT
Some pictures made by the Girlfriend! In my honest opinion they look really cool, starting to look the way I want. Furthermore the MG has joined me in Denmark, had a really nice 900km trip yesterday. A lot of thumbs up, pictures and even some traffic jam flirting (not sure if that was me or the car haha!) The B was purring very very smoothly, cruising at around 3000/3500 rpm on the overdrive. Managed to do around 13 km per liter, which is not bad at all. No idea what is was before the ecotune head, any experience here? So now I have my Car in Denmark, any danes around with some nice tips regarding driving roads?
ET
SO a bit of catch-up to do, there have been some adjustments to the B in the last couple of months. The last things done on the B was of course the head build, and the tuning of the carbs. Besides that there where quite some more things to do before it was able to drive all the way to Denmark. The car had failed his MOT pre-test, unfortunately not on just one point (parts of things i guess). As it sits now it has new nice looking toyo tires, i went for a lower profile (from 60 to 55) so the rims look a bit bigger. I am now on the lookout for lowering springs for the MG, if you have a second hand pair or have some tips: let me know The rear brake assembly has been completely changed, the oil leak in the rear diff had splattered a load of oil all in the disc brake. The brake shoes where fully saturated with oil, even on full brake the car was still able to roll haha! It also seemed that there was no image in the headlights of the car, so was able to quickly source a second hand h4 pair from the MGB facebook group. The light difference is enormous comparing to my old bulbs! The new lights don't have a yellow color, will look for them on the fleabay or maybe look for a LED set (although I'm doubting a bit if it will blind the other road users). The biggest visual thing is of course the hood or bonnet (pick your favorite), the one i had still had a dent in it from the small kiss it had in the past. Finding one in matching colour was harder said than done, so when coming across a very cheap red one i jumped the boat. The paint was not that good but the metal was a lot better than the current one so it was an easy choice. Ordered a couple sheets of vinyl from china to make my own retro style racing numbers ET VOILA! 673= june 1973, the birth of this voiture! As i left for Denmark the car was parked at my parents place, this proved to be putting drugs in the hands of an addict for my dad haha! The lancia we both restored had problems with the tensionbelt bearing (not sure if this is the right name for the part), resulting in him removing the head for at least 5 times. I guess he was fed up with the Lancia for a bit, so having the B standing in the garage gave him a nice toy to play with. Long story short, all my interior lights work all of a sudden (on LED). He found a 5 panel window via a friend (I mentioned that i was looking for one on ebay) for a crate of beer. And he was kind enough to drive it around when I was not there, although I would have liked to look at those mini problems myself it is really nice that was tinkering on my car a bit. Mostly because it's just good fun to have a shared interest like that, so if you have a son.... So now the car is in Denmark i cannot do a lot of mechanical work on it (that will have to wait until august), but I can finish the appearance of the car. I want to make another set of stickers for the sides (jep the number thing again), maybe have to order a bit more black vinyl from china so hope it will arrive on time. Got some mixed opinions on the stickers, some love em some hate em. I guess thats how it is with cars right?! Thing is, i like the look. It is not the cleanest car (yet), it is a work in progress and I rather drive around in something that looks a bit less perfect but with the old racing theme, than something that looks not finished (hope this makes any sense haha). Hope i can upload some pictures tonight, threads with pictures are nicer to read right? Thanks for reading and let me know what you think of the look!
Last Edit: Apr 21, 2017 7:24:56 GMT by ET
ET
So a small picture update to my last written update Swedish part transport! Really useful that the boot in an amazon is that big! sanded the hood/bonnet and filled the nicks and dents with some filler Sprayed it with some 2k left from the Lancia Beta Spider we had, colour came out a bit brighter than expected. Now fixed on the car it looks cool, but when first sprayed i wasn't that sure haha:D Removed the chrome bumper and mounted lighted registration plate holders (i think these are from a mgb convertible but not sure) The studs from the bumper are still on there, made them into tow eyes. I want to buy a valence this summer, but i'm not completely sure if i want to remove the mounting points for the bumper, maybe this is a nice middle way solution. New secondhand fuel sender unit! The floater in the tank was completely destroyed, so it never went above half a tank. Especially when i drove to denmark it is nice to have an idea when you need to stop for fuel haha! How much liter is the tank capacity of a MGB? When on the meter i would have less than a quarter left, it would fill up with 36/38 liter. The 5-panel rearview mirror! Kind of a tuner modification but since one of my sun visors had gave up hope, and my rearview mirror couldn't get a grip on itself it was time for a solution. This thing works like a charm! Really good view all around the car, and it sits at the right height to block out the sun when it's at an inconvenient height. And it was second hand, had a small crack in the last mirror so bargain hunting! Couple of weeks later, the man from the 5-panel window gave a call. A friend of his had some MGB fender laying about and wanted to get rid of it. Bonus! 2 neat looking fender for free! This summer i need to take a look at the known rusting points of the B (top of the front and rear fender), if these really are bad i can just switch them out!
79cord
Apr 23, 2017 10:18:32 GMT
Love the look, though perhaps the number font does look a bit fussy (& Dukes-of-Hazzard American ?) Congratulations on additional fenders.
adam73bgt
Club RR Member Number: 58
Apr 23, 2017 11:06:37 GMT
I do like the look, the numbers remind me somewhat of the Mille Miglia Mercs of the 50s I think all it needs now is a little lowering and it'll look perfect Nice mirror too, I've seen them before but never in a B!
Apr 23, 2017 11:40:33 GMT
Sweet ride! Where in DK are you located?
Nothing beats Patina when you are broke
73 TRIUMPH 2000 MK II, SHEDTASTIC SEMI SUMMER DAILY
72 TRIUMPH 2000 MK II, BLING BLING SHINY BUT IN BITS
68 TRIUMPH SPITFIRE MK III (MY FIRST CAR)
95 SKODA FELICIA DAILY (FORMER OAP CAR)
Apr 23, 2017 12:17:49 GMT
I love that this car is enjoying it's life to the fullest, it is a lucky car to have you and your dad as an owner.
You mention that you are going to lower the car. I have had the ride height from stock all the way to where it was too low to drive on the street. (but I did).
What I found during my experiments:
The best ride and handling for road use was the stock 1967 suspension AFTER it was fully overhauled. I originally made the same move that everyone makes where I decide, based on tired old suspension, that I am going to improve the car by lowering it.
Of course I liked the looks of the lowered car, but ran into bump stop issues causing snap over-steer on the track. Easy to fix. Then I realized that there was a bit of tram-lining and bump-steer, decided I could live with it.
After literally getting stuck on a speed-bump one day, I decided to put the car back to stock height. Of course, this time it was with all brand new suspension components. MUCH nicer to drive and to my shame as a driver, it was no different when timed around the racetrack.
Have since converted the rear suspension to 4 link coil over as sold by Classic Car Conversions, and it has been a great improvement comfort wise, but have not had it on the track since.
Last Edit: Apr 23, 2017 12:47:40 GMT by bjornagn
smeden
"Full throttle until you see God,then shift to second"
Apr 23, 2017 12:48:42 GMT
Welcome to Denmark!
What a nice B! There are a lot of nice driving roads in Denmark but it all depends upon which part of the country you are in! Feel free to ask! I know a lot of them ;-) Keep up the good work!
Cheers Og hilsner fra Christian
Jaguar xj6 S1 swb manual VW Bay Camper Audi A3 1998 1.8 VW Beach Buggy (sold) Ford Mondeo mrk I RS Celebration (written off) Ford Escort Mrk II RS 2000 (rust in peace)
ET
Apr 24, 2017 17:52:42 GMT
Welcome to Denmark! What a nice B! There are a lot of nice driving roads in Denmark but it all depends upon which part of the country you are in! Feel free to ask! I know a lot of them ;-) Keep up the good work! Cheers Og hilsner fra Christian Tak for det! I'm in Aarhus, or as I like to call it: the windy city haha Really like it here, they said Denmark was flat. Well not this part! So yeah any tips for nice roads are more than welcome, my colleagues said i definitely need to ride over the big bridge Went to a car meet in Fredericia a couple of weeks ago, maybe i'll visit one again with the B
ET
Apr 24, 2017 17:53:59 GMT
Sweet ride! Where in DK are you located? Thanks I'm in Ă…rhus!
ET
Apr 24, 2017 17:55:25 GMT
I do like the look, the numbers remind me somewhat of the Mille Miglia Mercs of the 50s I think all it needs now is a little lowering and it'll look perfect Nice mirror too, I've seen them before but never in a B! That's kind of the look that i'm going for, except the million dollar car underneath the sticker haha! Need to order some vinyl and than i can cut out the side stickers
ET
Apr 24, 2017 18:02:06 GMT
I love that this car is enjoying it's life to the fullest, it is a lucky car to have you and your dad as an owner. You mention that you are going to lower the car. I have had the ride height from stock all the way to where it was too low to drive on the street. (but I did). What I found during my experiments: The best ride and handling for road use was the stock 1967 suspension AFTER it was fully overhauled. I originally made the same move that everyone makes where I decide, based on tired old suspension, that I am going to improve the car by lowering it. Of course I liked the looks of the lowered car, but ran into bump stop issues causing snap over-steer on the track. Easy to fix. Then I realized that there was a bit of tram-lining and bump-steer, decided I could live with it. After literally getting stuck on a speed-bump one day, I decided to put the car back to stock height. Of course, this time it was with all brand new suspension components. MUCH nicer to drive and to my shame as a driver, it was no different when timed around the racetrack. Have since converted the rear suspension to 4 link coil over as sold by Classic Car Conversions, and it has been a great improvement comfort wise, but have not had it on the track since. Thanks for that review Bjorn! I would like to take the B on the track when I know it's ready, really doubting on what to do with the ride height. Especially with these "old" suspension set-ups it's easy to mess up the intention of the engineers with something like another spring. The thing is that the gap between the top of the tire and the edge of the fender is about 8cm (3 inch+-) and it just looks poop. Maybe I will buy a second hand stock spring and cut a ring out of it (not sure if this will help). Reading from people who had completely overhauled their suspension the majority of the cars even sat higher in the beginning until it settled in a bit. Let's say the issue is still grinding my gears a bit haha!
Apr 24, 2017 20:52:37 GMT
You are safe with the lowering up to when the lower a-arm starts to go uphill from the chassis to the kingpin. Ideal would be level.
So start by looking at where you are now.
melle
South West
It'll come out in the wash.
Apr 30, 2017 13:20:53 GMT
I've lived in Aarhus for four years, nice city.
To avoid grief, make sure sure you can legally drive your car on a Dutch reg in DK. Especially if it's regularly parked in a residential area, Danes love to report assumed tax dodgers to SKAT. One of my mates has found out the hard way, ain't no fun if they catch you...
ET
I've lived in Aarhus for four years, nice city. To avoid grief, make sure sure you can legally drive your car on a Dutch reg in DK. Especially if it's regularly parked in a residential area, Danes love to report assumed tax dodgers to SKAT. One of my mates has found out the hard way, ain't no fun if they catch you... Hey Melle, Yes it is quite a nice city! And the season of classic car races is coming up so there is a lot to see Thanks for the tip! I will be staying here till the end of july, if I checked correctly I will be out of trouble. Definitely don't want to pay danish taxes
melle
South West
Have you already been to the Kalø Slotsruin classic meets? Every Tuesday night (iirc) if the weather is acceptable. Up to a couple hundred cars and even more motorbikes if the weather is good; don't forget to bring your barbecue!
ET
Sooo back again in Holland! luckily with the MG (it almost got stolen in Denmark ) The last week in Denmark the rear muffler decided to make a break for it. But I decided that the sound without rear silencer is waay better! So when I had the car at my parents house, I wanted to put a straight pipe from the middle muffle. Quite a simple job but I noticed that the mid mounting point was completely separated, after fixing that is used a pipe that we had lying around as an exhaust. The diameter was a bit too small for my taste but it worked as a temporary solution! new exhaustAfter starting the car again I noticed that the car ran like an old horse, no idle and it felt like she was holding in on higher RPM. Maybe a too narrow pipe? Not a good spark? Did my engine clean put water at some weird place? Checked all these things but nothing seemed out of place. To get a small tip I asked the question on Facebook. As a tip they gave me to check the intake manifold, and indeed. Due to the wrenching on the mid-demper I probably pulled the manifold a bit loose(these were not re-tightened after the head rebuild). After re-tighting the bolts the engine seemed to be running a lot better! After that I started to remove the rear seat and spare wheel assembly. I want to tidy it up a bit, than maybe some smart idea to create some nice space (good ideas are always welcome). spare wheel compartment
Last Edit: Aug 8, 2017 11:42:40 GMT by ET
