Okay!
So I managed to attract a Jono around to give me a hand with the Cressida with promises of dinner and beer this evening.
Main thing to check at this point was a compression test. This was my first time, but it's pretty simple!
Took the air box off, sludginess observed coming from crank case breather is more syrupy than oil at the moment. Moisture around the carb throat.
That'll be the water, then.
Fired her up and waited an age for her to get to her normal operating temp of about 1/3. Wouldn't get there.
Have a look in the rad (had added some water) and it's not really flowing. Jono thinks might be a pump issue but easier to check stat, so do that first.
So I start disassembling the stat housing again while also learning how to do a compression test.
The stat was removed, some goop slapped on the mating faces and the car started up and the pump is definitely pushing enough coolant around.
So dud stat maybe? Turns out, nope. So... really efficient cooling system it is! Barely needs to run through the radiator... :/
But there is a chunk out of the stat housing on the block side that squirts like a little boy, if there isn't gasket plus goop. Will have to sort at some point but for now a bit of silicone where the corrosion is and a gasket instead of the goop that doesn't seem to have done much/may have lost me some coolant.
But really efficient cooling system head gasket failure does not equal.
So back to the compression test. But first, another diversion!
Pulled the plugs out, and the only plug that showed an issue was cylinder six, and looked like it had a bit of oily water baked on to it.
Apparently the 4M is known to lift the head at the back of the motor.
First I've heard, but I'll be honest, I didn't go around asking everyone!
So.. compression test I heard you wondering!
From 1-6:
155
145
150
155
150
155
So... that seems okay, doesn't it?
A brief google brings up that around 150 should be about right. (scientific, I know!)
So the theory of the head lifting a little could be correct?
We took the rocker cover off and tightened the head bolts. Or tried to. Only the back ones had some movement in them (further pointing towards aforementioned theory).
For now, I need to get a new stat gasket, plug the hole in the housing, and fill the radiator back up again. I will get a new plug to replace the fouled one.
Then the plan is to take her for a couple of not short but not long runs and see what she does. And then take her for a long run.
I asked should I not swap the oil and flush it, so I can see if I get more water in there.
Jono says it's not worth the money, the water in there will evaporate and it will stop looking like a latte, or I'll have to add more water to the radiator.
Either way will indicate failure or win.
So I will run it as is for a few 100km and see what happens, and then probably run some diesel oil for a few 100km as it's pretty sludgy under the rocker cover and it looks like it's been there a while.
So it should be nice and clean after that.
So.. who knows? Maybe not as big an issue as I thought?
Time will tell. Going to need to have my Personal Assistance Jono on speed dial when I take her out for a test run I think.
Cheers,
Matt
