Apr 27, 2019 19:35:05 GMT
Intended to finish off the last couple of jobs on the TR today but in the end only got as far as plugging in the cleaned fog light switch and confirming asda's finest white wine vinegar had done a superb job of cleaning the contacts. What I ended up doing was working on father in laws Doblo, not a car I can find anyhing to enthuse about! The centre brake light had packed up, after a bit of searching I found this 3 broken wires in the rubber boot between the boot and D pillar, I replaced them with new cables soldered, heat shrink wrapped and with an extra loop added at both ends and tucked in the tailgate and D pillar respectively. Then took a look at why the engine (1.9 jtd) judders at light throttle no fault codes, egr is blanked off, its worse when cold, tried pulling the injector connectors, all had the same effect, according to my diagnostic kit the temperature boost and rpm reads correctly, after all this the only thing I could think of is the maf, pulling this seemed to make it run better, so we will see tomorrow when it is cold. The only other thing I can find is the alternator pulley one way clutch is seized but I can't imagine hos this wkuld affect the engine running.
Last Edit: Apr 27, 2019 20:02:34 GMT by kevins
Apr 28, 2019 19:58:10 GMT
Went to the Peter Best meet at Braxted Park today, a good selection of cars including 3 other Elan plus 2's, all were immaculate and then there was my well used not polished for months example parked in the middle! I suspect they did't do this on the way home. 3 bags of compost, sawdust and plants! I'm finding myself drawn to pre war cars, there weren't many but this was probably my favourite, bet they never looked this good when new.
Taxed the TR last night, this evening I got it out gave it wash and took it for a short drive, all seems well so its going to work tomorrow and if that is ok its penultimate MOT.
Took the range rover to work today and the steering has gone very lumpy, just when you think you are getting on top of things something else comes along and kicks you in the nuts....
The steering box feels terrible all grauchy and lumpy, I suspect a bearing has failed. Options are: Repair the current one, as the bearings run directly on the shafts this is unlikely to work. Buy a new one, I can't afford the £800 let alone the following divorce! Get a re-con one, likely to be ones like mine with new bearings shoved in and charged £200+ Get a secondhand one, my preferred route at least if it goes wrong it won't have cost me much and its easy enough to change.
Last Edit: May 1, 2019 19:41:36 GMT by kevins
Tr made it to work, Only issues seem to be speedo cable keeps falling off speedo, the barb on the plastic fitting has been missing for years, fix will invole a tie strap, and some of the stitching on the hood has rotted away. Soon sorted with a needle and thread. I'm also picking up a range rover steering box on saturday from a local 4x4 breaker.
Hood sewn up, also stiched up part of the steering wheel which had come undone. Had to move the range rover to get the TR out, steering box seems to be deteriorating fast, now leaking quite heavily.
Last Edit: May 3, 2019 21:05:53 GMT by kevins
I'm finding myself drawn to pre war cars, there weren't many but this was probably my favourite, bet they never looked this good when new. And what a proper pre war car it is too - Jowett Long 4 Tourer - not expensive to own or maintain and under the bonnet is quite different from everything else of that era
Decided to fix the Range Rover today, pulled it out of the garage and parked it in the street while I made some space, came back to find some unpleasant piece of work had done this. Of course they left their name and adress, like hell they did! So before I even start I'm on ebay parting with £30 for x new one. Got stuck into the box change, all came appart easily enough, most of the bolts were still shiny silver, all in it took about 90 minutes, New box is pretty rusty but bone dry, we'll see how it goes but all is well so far and it drives fine. Old one was a right state and the pittman arm was actually loose even though the nut was tight. Lifting that up and down did my dodgy shoulder no good so packed up for the day afterwards. Othet news my son Andrew was 17 yesterday so he's now learning to drive, need to finish all the niggles on the minor before he passes his test! (He'll learn in the Focus as my employer insures it for him).
Driven the range rover for a couple of days, all still bone dry so looks like my £80 steering box was a success. Took the TR for its MOT and in the pouring rain on the way to work the wipers packed up. Turned out the thread had stripped where the steel tube attaches to the motor, a few minutes and a couple of tie straps got it all working again. And at lunchtime it passed the MOT with no advisories and compliments on the amount of work done. All being well the next job will be replacing the rear axle bushes on the KA.
Mirror turned up.fof Range Rover, Fitted easily enough but the electric adjustment doesent work, just about to moan to the seller and realised neither does the passenger one. As its only me who drives it the last time I used them was ages ago, fuse is OK so I suspect one of the switches is at fault. For now adjusted it manually, until I get the time to dig deeper. Thoght about getting the minor back from its lock up so I could start on fome of the odd jobs today but the weather put paid to that.
May 10, 2019 10:33:27 GMT
A bit of idiocy here! Noticed this morning the passenger mirror on the Range rover was pointing down, fiddled around and realised when you have the side switch to the left the right mirror adjusts and visa versa, then I noticed they go up when you adjust down.... Long story short when I had the dash apart to fix the a/c I put the leccy mirror switch in upside down so when I was looking at the right mirror the left was moving etc! The wrong way The right way
Last Edit: May 10, 2019 12:35:50 GMT by kevins
May 24, 2019 21:17:45 GMT
Bit more on the tr tonight, fitted the blos variable mixer, no great problems idles nicely but no chance to drive it yet.I have also bought a throttle body which I intend to use as a mixer by pass when running on petrol.
Also bought the minor home so I can finish all the odd jobs off, so far all I have done is replaced the vw bus mirror with a beetle one which looks much better.
rickygolf83
Mk2 Golf 8v & 16v, VR6, Nova Antibes, Mk4 1.8t & mk4 Gt Tdi 130
May 25, 2019 14:11:27 GMT
Quite a varied fleet you have there! Makes mine look like a walk in the park Mother in law has a Streetka, she moved to Cyprus and left it here and I used it over the winter to keep it moving. Probably a bad idea.... Great wee car, keep the revs up and it fair gets down the road, handles great in the snow and ice with a very versatile handbrake, but other side of 70 it gets a bit twitchy! The Ka went to Cyprus, where after a year both front chassis legs and inner wings gave way and supposedly wheels pointing at very negative camber. Rotten big time according to father in-law! They were going to bin it, but its been welded up and still hooning round the island
May 26, 2019 21:07:56 GMT
Not seen one go that bad, usually seems to be the rear end which goes really badly, the body on ours doesn't seem too bad though there were some areas of surface corrosion on the front inner wings. Today was spent on ka, firstly cleaned up the rusty spots on the bottom of the doors. The rust has got into the clinch flange, but the door inner is fine, for now I have cleaned it all up, treated it, and painted it with epoxy, when its top coated I will treat it with wax which hopefully will keep the rust at bay for a few more years. I then changed the rear twist beam bushes, I made a puller from a TR7 fan hub, a piece of propshaft tube, an old alternator pulley and some studding. First attempt simply snapped the M12 stud. So I heated the axle with a blowlamp for a good 10 minutes tighted the puller as much as I darred then belted the puller with a lump hammer to start it moving, they then came out easily enough, puller pulled the new ones in easily enough. Old ones were definitely past it But it still has the knocking noise, given it made the knock when I started the engine today, I have now changed every piece of rubber in the suspension and it seems to come with heavy vertical loads so I think it could be the gearbox mount. Good news is the new bushes have sharpened up the steering and directional stability.
Last Edit: May 26, 2019 21:14:35 GMT by kevins
May 26, 2019 21:23:51 GMT
On the minor I used a yellow number plate sticker to replace the badly faded yellow backing on the rear plate to give me this Also painted the spare wheel I also noticed the brake reservoir was low, topped it up to find it is dripping out of the chassis leg by the master cylinder, the brakes are fine so i think it is one of the remote reservior to cylinder connections, I will have to take the floor up to see what is going on. Used the TR this morning to go to a local show, drives very well on the blos, only other thing we nkticed is the front brake pads rattle, not the end of the world though.
Been too hot and had a bit of an all day session yesterday so a bit worse for wear.
Been using the TR every day, drives much better on the Blos lpg mixer, couple of minor issues though, the wipers have packed up because the thread has stripped where the cable tube fits to the motor. The speedo has also stopped because the cable has broken (not a major issue as you can drive any speed from 15mph up in top gear and its 320rpm per 10mph), new cable has arrived but I am waiting for the wiper motor ferrule.
On the minor the brake fluid leak is from the seals where the plastic remote reservoir fittings push into the master cylinder, they are only a year old, I have ordered some new ones from just kampers (VW master cylinder).
On the KA my daughter has hit a pot hole and trashed a rear wheel and tyre, will be picking up a set of 4 as spares on wednesday, Otherwise appart from the clonk it seems to be working well.
Samage
Blimey, I can barely keep up with running two cars, you're doing a great job keeping up with this lot!
They keep me out of trouble, tonight i fitted this to the TR. We now have functioning wipers again, it was supringly easy, undo the 1 screw holding the wiper motor, unplug the electrical connection , remove the wipers, and just pull the motor out complete with the inner cable, undo the 5 screws holding the motor gearbox cover on, slide the faoled part out, pop the new one on and put it back together (greasing the cable and turning wiper shafts 180 degrees so the unworn part is used). On the minor I fitted the new grommets to the remote reservoir connections (much more effort to push on) and all seems well. I also pulled the leaking rear hub, no obvious reason it all looks perfect, after pressing the bearing out it feels a bit notchy (you have to push it out using the centre race) , so need to wait for a new one to arrive before it can go back together with a new seal.
Parts arrived for minor yesterday, so today I put it back together. Bearing and seal pressed in. Having a press (even my sh!t Chinese one) makes this so much easier, fortunatelly the back plate had done its job and no oil had got on the brakes. Nut and lock washer back on and torqued up. Halfshaft back in Brake drum on Wheel on Trim on Job done. Also put the new wheel on the ka and had a look at the rear gearbox mount, it is very close to the brace pinifarina added, I'm thinking this is the cause of the knock, when I get a chance U I will get it on the ramp take the brace off and see if there are any witness marks.
Jun 17, 2019 20:57:10 GMT
Spent an hour on the lathe this evening, firstly turned up a blanking plug for the original and now unused fuel pick up on the minor. Then started on the distributor, plan is to fit a A+ electronic distributor, the A series uses a sleeve ( to the right below) which bolts in, the A+ does away with this and goes straight into a smaller hole in the block, fortunatelly the inside diameter is the same as the hole in the A+ Block, they also use a different drive slot. The A+ Distrubtor Also Sits Lower Level With The Face Of The block. The drive slot is easily fixed by using a A+ drive gear, for the sleeve the top flange needs turning off and then it needs fixing to the distributor with a grub screw, I also turned a taper into the base to make assembly easier. Just need to make a clamp and wiring harness now.
Last Edit: Jun 17, 2019 21:01:44 GMT by kevins
Jun 21, 2019 22:49:02 GMT
Took advantage of the improved weather and painted the bumper valances, turned out pretty good considering I virtually end up making the rear one fron scratch. Also made a radio mount and fitted it, Still need to wire it in and will do the heated seats at the same time. Also fitted the beetle mirror which looks much better than the vw bus one we had before.
