Hi all,
Not wishing to resurrect an old thread but I have to say a big thanks…
This thread got 3rd place in the 'Readers Other Mods' awards this year. That came as a surprise because for some reason I'd missed the fact that it'd even been nominated.
Given the quality of threads on this site I reckon just to get nominated is fairly impressive - but to get third... Well chuffed. Thank you.
Then over on
georgeb 's thread
bstardchild said…
oooh have you finished the roof?
Yes mate!
So to add a bit to the story here's what's happened to the house since.
The steel work was done and the roof tied in back in May but I hadn't put all the loft floor down. That was because of another little project I did in the summer. Painting the side of the house.
I had to work off my neighbours car port so I bought some steel tube and built a set of props for additional support for the roof. Then a few sheets of OSB to cover the plastic top and my scaffold tower on top of that.
When that job was finished the OSB sheets became the flooring in the loft.
Back to the house painting… That's a 9 Mtr tower on top of a 2 Mtr carport. It looks fine in the photo above but it's at least three times higher when you are at the top looking down than from the bottom looking up.
I knew one of the chimney pots was lose so I wanted to re-bed it while I was up there. Well, I started chipping the old flaunching off and the mortar between the top courses of bricks ran out as sand. Bum hats.
The height I could cope with. Just. The chimney pot I could cope with. Even a few courses of lose brick isn't a problem.
But all three - right at the top of the chimney? No chance! Brown trousers time.
So I got a chap called 'Nick the Roofer' to sort it out. He did a cracking job.
Here's a couple of photos of Faversham from the top of my chimney.
Rather nice isn't it? Looks better from up there than it does from the street.
Back inside the loft hatch was a bit of a mess when you last saw it.
But it looks a bit tidier now.
I wasn't working fast enough for Mrs Sweetpea so the coving was put up by the nice chap who replastered the worst bits of the walls. (Plastering is one of those things that I just can't do. I've tried and tried and I just don't get it. So we got a man in.)
Anyway some of the coving fell down a week later. A layer of paint or something higher up came unstuck from the ceiling. Oops. So the poor plasterer came back and we put it all back up again. I actually took the Black and Decker power file to the walls and ceiling and sanded it back to the plaster. It's not coming down again!
In other news we now have a new window surround in white oak. The original was a mess and had woodworm.
It needs architrave to finish it off. The house still has some beautiful architrave from the 30's when it was built. You can't get it or anything like it anymore so I'm making new stuff to match.
The job today was to get rid of the glass from under the banister. It had been fitted in the 70's I reckon.
I got most of it out yesterday - last bit today.
There are two reasons. Firstly glass is really dangerous if you happen to fall down the stairs and break it as you go. Secondly it looked like a 1970's Indian restaurant rather than a 1930's house. Wooden spindles will be going back in. Probably white oak as it's usually a pretty good colour match for the 30's wood once it's all oiled.
Next on the list is to strip the paint off all the wood work and finish in Danish Oil. Not looking forward to that. It'll be messy and take forever.
So that's a quick round up of 'post roof' works and it explains why I've been ignoring the MR2 lately.
Thanks again for voting. Especially if it was for this thread!
James
