Anyone done it on here at all? I'm doing the Sebring conversion for mine, I have the Chrome Bumper wings modified with the arches in place so that's the wings done. However, I could do with a little guidance on what to do with the grille. From what I understand I need to cut the chassis legs back is that right? About 4 inches on the top and and 2 on the bottom bit and weld the ends up? What about the plate that sits between the legs? Currently I have the grille only. What other fixings would I need? All help would be appreciated .
Nathan
May 20, 2007 16:24:37 GMT
I have done it to a friends MGB and TBH its a complete pain, but yes you have the right idea cus it back 4 inches including the plate, weld the ends up and job done matey.
Nathan
May 20, 2007 16:25:58 GMT
The new grille fixes to the front panel at the top with just a 3 peices of steel, it also fixes to the bottom of the front bulkhead (or whatever you call it) with some bolts.
May 20, 2007 16:27:37 GMT
Can't offer much help as I know nothing about MG's! But, I can enthuse over the planned Sebring conversion... sounds excellent! Have you tried asking on an MG forum? You might get a load of beardies whinging about originality etc., but I'm sure someone will know the answer to your question. Oh, hang on... maybe you don't need the beardies after all... Clicky HTH
May 20, 2007 22:36:11 GMT
May 20, 2007 23:24:42 GMT
yep when i lost the rubber bumpers on my midge i, as you say. cut about 4inchess off and weld a plate over, but i also had to fill the old chrome bumper indicator holes too. not sure how the chrome bit fit tho RoB
chuck the bumpers away, tape over the headlights, job done...
Nathan
Remeber you will need to modd the wings as you don't get a proper hole for the indicators.
I say don't fit the chrome bumpers just have it smooth bud.
