Apr 23, 2007 22:04:00 GMT
I'd like to swap a modern manual gearbox in place of the BW 35 in my Minx. I'll be keeping the Rootes engine. Originally I was considering a Toyota 5speed out of an older celica or supra, but then I began to notice Honda S2000 gearboxes popping up on eBay. The S2000 box is a 6 speed, and as the engine is slanted over about 10 degrees, just like my Minx, I suspect it could probably be adapted relatively easily.
Then I remembered a potential problem. I know that late Honda FWD engines rotate in the opposite direction from most the engines of most other manufacturer. Is this the case with the S2000? I'd hate to go to all that trouble and have six reverse gears!
1995 Range Rover 4.0 1995 BMW 320i Saloon 1989 BMW 325i Touring 1991 Mercedes 300TE-24 1991 Mercedes 190e 1970 Sunbeam Imp Sport
1966 Valiant 200 Custom 1964 Ford Fairlane 500 Station Wagon
Apr 23, 2007 22:11:57 GMT
S2000`s rotate in the `right` direction unlike earlier Honda`s
Apr 23, 2007 22:15:36 GMT
I think it will be ok... The FWD units also sit with their gearbox on the right, which is why they must spin backwards.. The S2000 is a front engine rwd usual layout so should spin clockwise as usual (looking from flywheel) and anyway, if you only use the gearbox, and not the diff, it will rotate the way your engine and axle want to.
Apr 23, 2007 22:39:40 GMT
I think it will be ok... The FWD units also sit with their gearbox on the right, which is why they must spin backwards.. The S2000 is a front engine rwd usual layout so should spin clockwise as usual (looking from flywheel) and anyway, if you only use the gearbox, and not the diff, it will rotate the way your engine and axle want to. Gee, you're right. I feel really stupid now.
Apr 23, 2007 22:57:54 GMT
I think it will be ok... The FWD units also sit with their gearbox on the right, which is why they must spin backwards.. The S2000 is a front engine rwd usual layout so should spin clockwise as usual (looking from flywheel) and anyway, if you only use the gearbox, and not the diff, it will rotate the way your engine and axle want to. It can still rotate the other way - the CROWNwheel can be on the opposite side of the diff. As for the box, surely if it's normally mated to an engine that turns the other way, you would then just end up with one forward gear & lots of reverse gears?
